An Implementation of DES and AES, Secure against Some Attacks, LNCS, vol.2162, pp.309-318, 2001. ,
DOI : 10.1007/3-540-44709-1_26
Template Attacks in Principal Subspaces, LNCS, vol.4249, pp.1-14, 2006. ,
DOI : 10.1007/11894063_1
Some aspects of military line communication as deployed by the German armed forces prior to 1945, 2004. ,
Compositional Verification of Higher-Order Masking: Application to a Verifying Masking Compiler, Cryptology ePrint Archive, vol.506, issue.71, pp.94-96 ,
Verified Proofs of Higher-Order Masking, LNCS, vol.9056, issue.100, pp.457-485, 2015. ,
DOI : 10.1007/978-3-662-46800-5_18
URL : https://hal.archives-ouvertes.fr/hal-01216699
Randomness Complexity of Private Circuits for Multiplication, pp.978-981, 2016. ,
DOI : 10.1007/978-3-662-49896-5_22
Correlation Power Analysis with a Leakage Model, LNCS, vol.3156, issue.23, pp.16-29, 2004. ,
DOI : 10.1007/978-3-540-28632-5_2
Easing Coppersmith Methods Using Analytic Combinatorics: Applications to Public-Key Cryptography with Weak Pseudorandomness, pp.36-66, 2016. ,
DOI : 10.1007/978-3-662-49387-8_3
URL : https://hal.archives-ouvertes.fr/hal-01278460
Inner Product Masking Revisited, LNCS. Springer, vol.9056, issue.28, pp.486-510, 2015. ,
DOI : 10.1007/978-3-662-46800-5_19
URL : https://lirias.kuleuven.be/bitstream/123456789/489849/2/article-2515.pdf
Theory and Practice of a Leakage Resilient Masking Scheme, Xiaoyun Wang and Kazue Sako. LNCS, vol.7658, pp.758-775, 2012. ,
DOI : 10.1007/978-3-642-34961-4_45
On the Cost of Lazy Engineering for Masked Software Implementations, pp.64-81978, 2014. ,
DOI : 10.1007/978-3-319-16763-3_5
A More Efficient AES Threshold Implementation, LNCS, vol.8469, pp.267-284, 2014. ,
DOI : 10.1007/978-3-319-06734-6_17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.5454
Higher-Order Threshold Implementations, Palash Sarkar and Tetsu Iwata. LNCS, vol.8874, pp.326-343, 2014. ,
DOI : 10.1007/978-3-662-45608-8_18
URL : http://doc.utwente.nl/92489/1/chp_10.1007_978-3-662-45608-8_18.pdf
Low-randomness constantround private XOR computations, In: Int. J. Inf. Sec, vol.61, pp.15-26, 2007. ,
DOI : 10.1007/s10207-006-0007-5
SP 800-90A. Recommendation for Random Number Generation Using Deterministic Random Bit Generators, pp.2012-69 ,
Multi-prover interactive proofs: how to remove intractability, Proceedings of the twentieth annual ACM symposium on Theory of computing , STOC '88, pp.113-131, 1988. ,
DOI : 10.1145/62212.62223
Completeness Theorems for Non-Cryptographic Fault-Tolerant Distributed Computation (Extended Abstract), 20th ACM STOC, pp.1-10, 1988. ,
DOI : 10.1145/62212.62213
Entropy Measures and Unconditional Security in Cryptography, p.44 ,
Algebraic Geometric Secret Sharing Schemes and Secure Multi-Party Computations over Small Fields, Cynthia Dwork. LNCS, vol.4117, pp.521-536, 2006. ,
DOI : 10.1007/11818175_31
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.363.2451
Differential Power Analysis in the Presence of Hardware Countermeasures, LNCS, vol.1965, pp.252-263, 2000. ,
DOI : 10.1007/3-540-44499-8_20
Multiparty Unconditionally Secure Protocols (Extended Abstract), 20th ACM STOC, pp.11-19, 1988. ,
DOI : 10.1007/3-540-48184-2_43
Secure Computation from Random Error Correcting Codes, Ed. by Moni Naor. LNCS, vol.4515, pp.291-310, 2007. ,
DOI : 10.1007/978-3-540-72540-4_17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.110.3742
Higher-Order Masking Schemes for S-Boxes, Anne Canteaut. LNCS, vol.7549, pp.366-384, 2012. ,
DOI : 10.1007/978-3-642-34047-5_21
Faster Evaluation of SBoxes via Common Shares, Cryptographic Hardware and Embedded Systems -CHES 2016 -18th International Conference, pp.498-514, 2016. ,
DOI : 10.1007/978-3-662-53140-2_24
The dining cryptographers problem: Unconditional sender and recipient untraceability, Journal of Cryptology, vol.1, issue.1, pp.65-75, 1988. ,
DOI : 10.1007/BF00206326
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.127.4293
Towards Sound Approaches to Counteract Power-Analysis Attacks, Ed. by Michael J. Wiener. LNCS, vol.1666, issue.28, pp.398-412, 1999. ,
DOI : 10.1007/3-540-48405-1_26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.94.8951
Template Attacks on Different Devices Cryptology ePrint Archive ,
DOI : 10.1007/978-3-319-10175-0_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.476.3896
Randomness versus Fault-Tolerance, Journal of Cryptology, vol.13, issue.1, pp.107-142, 2000. ,
DOI : 10.1007/s001459910005
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.21.4208
On the use of Shamir's secret sharing against side-channel analysis, p.31, 2012. ,
Higher-Order Side Channel Security and Mask Refreshing, Ed. by Shiho Moriai. LNCS, vol.8424, pp.410-424, 2014. ,
Algebraic Decomposition for Probing Security, J. B. Robshaw. LNCS, vol.9215, pp.742-763, 2015. ,
DOI : 10.1007/978-3-662-47989-6_36
Template Attacks, LNCS, vol.2523, pp.13-28, 2003. ,
DOI : 10.1007/3-540-36400-5_3
Fast Evaluation of Polynomials over Binary Finite Fields and Application to Side-Channel Countermeasures, LNCS, vol.8731, pp.170-187, 2014. ,
Redefining the transparency order, Designs, Codes and Cryptography, vol.82, issue.1-2 ,
DOI : 10.1007/s10623-016-0250-3
URL : https://hal.archives-ouvertes.fr/hal-01399584
Unifying Leakage Models: From Probing Attacks to Noisy Leakage., LNCS, vol.8441, issue.68, pp.423-440, 2014. ,
DOI : 10.1007/978-3-642-55220-5_24
URL : http://infoscience.epfl.ch/record/198833
Making Masking Security Proofs Concrete -Or How to Evaluate the Security of Any Leaking Device In: EUROCRYPT 2015, Part I, LNCS, vol.9056, issue.68, pp.401-429, 2015. ,
Noisy Leakage Revisited, EUROCRYPT 2015, Part II, pp.159-188, 2015. ,
DOI : 10.1007/978-3-662-46803-6_6
Leakage-Resilient Cryptography, 2008 49th Annual IEEE Symposium on Foundations of Computer Science, pp.49-293, 2008. ,
DOI : 10.1109/FOCS.2008.56
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.175.4006
Univariate side channel attacks and leakage modeling, Journal of Cryptographic Engineering, vol.34, issue.9, p.55, 2011. ,
DOI : 10.1007/s13389-011-0010-2
Electromagnetic Radiation from Video Display Units: An Eavesdropping Risk?, 1985. ,
A mathematical examination of the methods of determining the accuracy of an observation by the mean error, and by the mean square error, In: Mon. Notices Roy. Astron. Society, 1920. ,
On the mathematical foundations of theoretical statistics, Philosophical Transactions of the Royal Society, vol.38, p.22, 1922. ,
Fault Attacks on AES with Faulty Ciphertexts Only, 2013 Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.108-118, 2013. ,
DOI : 10.1109/FDTC.2013.18
A Statistical Model for DPA with Novel Algorithmic Confusion Analysis, LNCS, vol.7428, issue.46, pp.233-250, 2012. ,
DOI : 10.1007/978-3-642-33027-8_14
Protecting Circuits from Leakage: the Computationally-Bounded and Noisy Cases, LNCS, vol.6110, pp.135-156, 2010. ,
DOI : 10.1007/978-3-642-13190-5_7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.170.540
Parity, Circuits, and the Polynomial-Time Hierarchy, Mathematical Systems Theory, vol.171, 1984. ,
DOI : 10.1007/bf01744431
Homomorphic Evaluation of the AES Circuit, LNCS, vol.7417, pp.850-867, 2012. ,
DOI : 10.1007/978-3-642-32009-5_49
Templates vs. Stochastic Methods, LNCS, vol.4249, pp.15-29, 2006. ,
DOI : 10.1007/11894063_2
Protecting AES with Shamir???s Secret Sharing Scheme, LNCS, vol.6917, pp.79-94, 2011. ,
DOI : 10.1007/978-3-642-23951-9_6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.6427
How to Play any Mental Game or A Completeness Theorem for Protocols with Honest Majority, 19th ACM STOC, pp.218-229, 1987. ,
DES and Differential Power Analysis The ???Duplication??? Method, LNCS, vol.1717, issue.28, pp.158-172, 1999. ,
DOI : 10.1007/3-540-48059-5_15
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.8254
Physical key extraction attacks on PCs, Commun. ACM, vol.596, 2016. ,
Stealing Keys from PCs Using a Radio: Cheap Electromagnetic Attacks on Windowed Exponentiation, LNCS, vol.9293, pp.207-228, 2015. ,
DOI : 10.1007/978-3-662-48324-4_11
ECDH Key- Extraction via Low-Bandwidth Electromagnetic Attacks on PCs In: Topics in Cryptology -CT-RSA 2016 -The Cryptographers' Track at the RSA Conference 2016, pp.219-235, 2016. ,
Secure Multiplicative Masking of Power Functions, LNCS, vol.6123, pp.200-217, 2010. ,
DOI : 10.1007/978-3-642-13708-2_13
URL : https://hal.archives-ouvertes.fr/hal-00639298
Efficient Masked S-Boxes Processing ??? A Step Forward ???, LNCS, vol.8469, pp.251-266, 2014. ,
DOI : 10.1007/978-3-319-06734-6_16
Get your hands off my laptop: physical side-channel key-extraction attacks on PCs -Extended version, In: J. Cryptographic Engineering, vol.52, pp.95-112, 2015. ,
Comparing Elliptic Curve Cryptography and RSA on 8-bit CPUs, LNCS, vol.3156, pp.119-132, 2004. ,
DOI : 10.1007/978-3-540-28632-5_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.585.9481
Lower bounds on the amount of randomness in private computation, Proceedings of the thirty-fifth ACM symposium on Theory of computing , STOC '03, pp.659-666, 2003. ,
DOI : 10.1145/780542.780638
Simplified VSS and Fact-Track Multiparty Computations with Applications to Threshold Cryptography, pp.101-111, 1998. ,
DOI : 10.1145/277697.277716
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.27.3164
RSA Key Extraction via Low- Bandwidth Acoustic Cryptanalysis In: CRYPTO 2014, Part I, LNCS, vol.8616, issue.9, pp.444-461, 2014. ,
Multiplicative Masking and Power Analysis of AES, LNCS, vol.2523, pp.198-212, 2003. ,
Cryptanalysis of iterated block ciphers, ETH Series in Information Processing, 1996. ,
High-Resolution Side-Channel Attack Using Phase-Based Waveform Matching, LNCS, vol.4249, pp.187-200, 2006. ,
DOI : 10.1007/11894063_15
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.3061
The Temperature Side Channel and Heating Fault Attacks Cryptology ePrint Archive, 2014. ,
DOI : 10.1007/978-3-319-14123-7_15
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.646.9815
Robust Pseudorandom Generators, ICALP 2013, Part I. Ed. by Fedor V. Fomin, Rusins Freivalds, pp.576-588, 2013. ,
DOI : 10.1007/978-3-642-39206-1_49
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.5226
On the Power of Correlated Randomness in Secure Computation, Ed. by Amit Sahai. LNCS, vol.7785, pp.600-620, 2013. ,
DOI : 10.1007/978-3-642-36594-2_34
Information technology ? Security techniques ? Evaluation criteria for IT security ,
Private Circuits: Securing Hardware against Probing Attacks, Ed. by Dan Boneh. LNCS, vol.2729 ,
DOI : 10.1007/978-3-540-45146-4_27
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.115.9436
Principal Component Analysis, 1986. ,
Differential Power Analysis " . In: CRYPTO'99, Ed. by Michael J. Wiener. LNCS, vol.1666, issue.24, pp.388-397, 1999. ,
On Information and Sufficiency, Annals of Mathematical Statistics, pp.79-86, 1951. ,
DOI : 10.1214/aoms/1177729694
Randomness in Private Computations, pp.181-190, 1996. ,
Timing Attacks on Implementations of In: CRYPTO'96, Ed. by Neal Koblitz. LNCS, vol.1109, issue.19, pp.104-113, 1996. ,
Amortizing Randomness in Private Multiparty Computations, In: SIAM J. Discrete Math, vol.164, pp.533-544, 2003. ,
DOI : 10.1145/277697.277710
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.3112
Characterizing Linear Size Circuits in Terms of Pricacy, J. Comput. Syst. Sci, vol.581, issue.119, pp.129-136, 1999. ,
Breaking Ciphers with COPACOBANA ???A Cost-Optimized Parallel Code Breaker, LNCS, vol.4249, pp.101-118, 2006. ,
DOI : 10.1007/11894063_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.105.7799
A Randomness-Rounds Tradeoff in Private Computation, SIAM Journal on Discrete Mathematics, vol.11, issue.1, pp.61-80, 1998. ,
DOI : 10.1137/S089548019427634X
Non-interactive Zero-Sharing with Applications to Private Distributed Decision Making, Ed. by Rebecca Wright. LNCS, vol.2742, pp.303-320, 2003. ,
DOI : 10.1007/978-3-540-45126-6_22
An Observation on the Security of McEliece???s Public-Key Cryptosystem, LNCS, vol.330, pp.275-280, 1988. ,
DOI : 10.1007/3-540-45961-8_25
A probabilistic algorithm for computing minimum weights of large error-correcting codes, IEEE Transactions on Information Theory, vol.34, issue.5, pp.1354-1359, 1988. ,
DOI : 10.1109/18.21270
How to Estimate the Success Rate of Higher-Order Side-Channel??Attacks, LNCS, vol.8731, pp.35-54, 2014. ,
DOI : 10.1007/978-3-662-44709-3_3
On the Need of Randomness in Fault Attack Countermeasures - Application to AES, 2012 Workshop on Fault Diagnosis and Tolerance in Cryptography, pp.85-94, 2012. ,
DOI : 10.1109/FDTC.2012.19
The Byzantine Generals Problem, ACM Transactions on Programming Languages and Systems, vol.4, issue.3, pp.382-401, 1982. ,
DOI : 10.1145/357172.357176
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.1697
Hardware Countermeasures against DPA ??? A Statistical Analysis of Their Effectiveness, Ed. by Tatsuaki Okamoto. LNCS, vol.2964, pp.222-235, 2004. ,
DOI : 10.1007/978-3-540-24660-2_18
Minimal Codewords and Secret Sharing, Proceedings of the 6th Joint Swedish-Russian International Workshop on Information Theory, pp.276-279, 1993. ,
Guessing and Entropy, IEEE International Symposium on Information Theory, 1994. ,
A public-key cryptosystem based on algebraic coding theory, DSN progress report 42, pp.114-116, 1978. ,
Improving smart card security using self-timed circuits, Proceedings Eighth International Symposium on Asynchronous Circuits and Systems, p.211, 2002. ,
DOI : 10.1109/ASYNC.2002.1000311
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.7842
Power Analysis Attacks - Revealing the Secrets of Smartcards, 2007. ,
Physically Observable Cryptography (Extended Abstract) . In: TCC, Ed. by Moni Naor. LNCS, vol.2951, pp.278-296, 2004. ,
DOI : 10.1007/978-3-540-24638-1_16
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.6299
A dynamic current mode logic to counteract power analysis, DCIS Conference on Design Of Circuits and Integrated Systems, pp.186-191, 2004. ,
On the problem of the most efficient tests of statistical hypotheses In: Philosophical Transactions of the Royal Society of London, series A, Containing Papers of a Mathematical or Physical Character (1933) (cit. on p. 40). [NRS11] Svetla Nikova, Vincent Rijmen, and Martin Schläffer Secure Hardware Implementation of Nonlinear Functions in the Presence of Glitches, Journal of Cryptology, vol.24, issue.2, pp.292-321, 2011. ,
TEMPEST: A Signal Problem (cit, p.19 ,
???Rank Correction???: A New Side-Channel Approach for Secret Key Recovery, p.InfoSecHiComNet, 2011. ,
DOI : 10.1007/978-3-642-01001-9_26
Note on Regression and Inheritance in the Case of Two Parents, Proceedings of the Royal Society of London. 1895, pp.240-242 ,
DOI : 10.1098/rspl.1895.0041
Masked Dual-Rail Pre-charge Logic: DPA-Resistance Without Routing Constraints, CHES 2005, pp.172-186, 2005. ,
DOI : 10.1007/11545262_13
Masking against Side-Channel Attacks: A Formal Security Proof, LNCS, vol.7881, pp.142-159, 2013. ,
DOI : 10.1007/978-3-642-38348-9_9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.460.3576
The use of information sets in decoding cyclic codes In: Information Theory, IRE Transactions on, vol.85, pp.71-99, 1962. ,
Statistical Analysis of Second Order Differential Power Analysis, IEEE Transactions on Computers, vol.58, issue.6, p.47, 2010. ,
DOI : 10.1109/TC.2009.15
DPA Attacks and S-Boxes, LNCS, vol.3557, pp.424-441, 2005. ,
DOI : 10.1007/11502760_29
ElectroMagnetic Analysis (EMA): Measures and Counter-measures for Smart Cards, pp.2140-200, 2001. ,
DOI : 10.1007/3-540-45418-7_17
Consolidating Masking Schemes, J. B. Robshaw. LNCS, vol.9215, pp.764-783, 2015. ,
DOI : 10.1007/978-3-662-47989-6_37
Defeating classical hardware countermeasures, Proceedings of the conference on Design, automation and test in Europe, DATE '08, 2008. ,
DOI : 10.1145/1403375.1403684
On the Exact Success Rate of Side Channel Analysis in the Gaussian Model, LNCS, vol.94, issue.2, pp.165-183, 2009. ,
DOI : 10.1109/JPROC.2005.862437
Provably Secure Higher-Order Masking of AES, Stefan Mangard and François-Xavier Standaert. LNCS, vol.6225, issue.34, pp.413-427, 2010. ,
DOI : 10.1007/978-3-642-15031-9_28
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.7885
Analysis and Improvement of the Generic Higher-Order Masking Scheme of FSE 2012, LNCS, vol.8086, pp.417-434, 2013. ,
DOI : 10.1007/978-3-642-40349-1_24
A Mathematical Theory of Communication, pp.379-423, 1948. ,
How to share a secret, Communications of the ACM, vol.22, issue.11, pp.612-613, 1979. ,
DOI : 10.1145/359168.359176
A Stochastic Model for Differential Side Channel Cryptanalysis, CHES 2005, pp.30-46, 2005. ,
DOI : 10.1007/11545262_3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.363.2705
A Unified Framework for the Analysis of Side-Channel Key Recovery Attacks (extended version) Cryptology ePrint Archive, Report, vol.139139, 2006. ,
An Overview of Power Analysis Attacks Against Field Programmable Gate Arrays, Proceedings of the IEEE 94, 2006. ,
Leakage Resilient Cryptography: a Practical Overview, Proceedings of the ECRYPT Workshop on Symmetric Encryption, 2011. ,
DOI : 10.1007/978-3-642-14452-3_5
URL : http://hdl.handle.net/2078.1/87809
Performance Analysis of Contemporary Lightweight Block Ciphers on 8-bit Microcontrollers In: SPEED Software Performance Enhancement for Encryption and Decryption, 2007. ,
A method for finding codewords of small weight, Coding Theory and Applications, 3rd International Colloquium Proceedings. Ed. by Gérard D. Cohen and Jacques Wolfmann, pp.106-113, 1988. ,
DOI : 10.1007/BFb0019850
Non-Interactive CryptoComputing For NC1, pp.40-554, 1999. ,
DOI : 10.1109/sffcs.1999.814630
Success through Confidence: Evaluating the Effectiveness of a Side-Channel Attack, LNCS, vol.8086, pp.978-981, 2013. ,
Detection, Estimation, and Modulation Theory, 1968. ,
An optimal Key Enumeration Algorithm and its Application to Side- Channel Attacks. Cryptology ePrint Archive, Report, vol.610610, 2011. ,
DOI : 10.1007/978-3-642-35999-6_25
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.7441
A Comprehensive Evaluation of Mutual Information Analysis Using a Fair Evaluation Framework, Ed. by Phillip Rogaway. LNCS, vol.6841, pp.316-334, 2011. ,
DOI : 10.1007/978-3-642-22792-9_18
A Fair Evaluation Framework for Comparing Side-Channel Distinguishers. Cryptology ePrint Archive, 2011. ,
DOI : 10.1007/s13389-011-0011-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.6495
Protocols for Secure Computations (Extended Abstract), pp.23-160, 1982. ,
DOI : 10.1109/sfcs.1982.38
How to Generate and Exchange Secrets (Extended Abstract ), pp.27-162, 1986. ,
DOI : 10.1109/sfcs.1986.25
