Identification de fractures dans un milieu poreux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Identification of fractures in porous medium
This PhD is dedicated to the mathematical study of an inverse problem in hydro- geology : the goal is to identify fractures in porous medium, knowing measurements of the underground flow. The number, the location and the physical parameters of the fracture are looked for. This problem is formulated as the least squares minimization of a function evalua- ting the misfit between measurements and the result of the direct model. We used a model describing the flow of a monophasic incompressible fluid (Darcy’s law), in a po- rous medium containing some fractures represented by interfaces. The direct problem is the fracture model discretized by the mixed hybrid finite element method. To solve this inverse problem, we developed an iterative algorithm, which is based on the use of fracture indicators that have been developed durig the thesis. These indicators give a first order information concerning the effect of the addition of a new fracture. As these indicators are inexpensive, a large number of configurations of new fractures is tested at each iteration. The algorithm was programmed, validated and tested numerically in various situations, using synthetic measurements. It gives very satisfactory results, although this problem is considered difficult. Finally, an early study of identifiability of the inverse problem of fractures in porous medium has been achieved. It allowed to prove the identifiability for a simplified model (very permeable faults, which is common in the underground). The question of identifiability for the full fracture model remains open.
Cette thèse est consacrée à l’étude mathématique d’un problème inverse en hydrogéologie : le but est d’identifier des fractures en milieu poreux, connaissant des mesures de l’écoulement dans le sous-sol. Le nombre, la localisation et les paramètres physiques des fractures sont recherchés. Ce problème est formulé comme la minimisation au sens des moindres carrés d’une fonctionnelle évaluant l’écart entre les mesures et les résultats du modèle direct. L’écoulement est celui d’un fluide monophasique incompressible (loi de Darcy). Un modèle traitant les fractures comme des interfaces est utilisé. Le problème direct est le modèle de fracture discrétisé par la méthode des éléments finis mixtes hybrides. Pour résoudre ce problème inverse, un nouvel algorithme itératif a été développé, basé sur l’utilisation d’indicateurs de fractures mis au point pendant la thèse. Ces indi- cateurs donnent une information au premier ordre concernant l’effet de l’ajout d’une nouvelle fracture. Comme ces indicateurs sont peu coûteux, un grand nombre de confi- gurations de fractures sont testées à chaque itération. L’algorithme a été programmé, validé puis testé dans des situations variées, en utilisant des mesures synthétiques. Il donne des résultats très satisfaisants, bien que ce problème soit réputé difficile. Enfin, l’étude de l’identifiabilité du problème inverse a été amorcée. Pour un modèle simplifié de fractures (failles très perméables, cas le plus courant dans le sous-sol), on a montré que le problème est identifiable. La question reste ouverte pour le modèle complet.
These_Cheikh.pdf (9.76 Mo) Télécharger le fichier
tel-01415825 , version 1 (13-12-2016)
tel-01415825 , version 2 (21-03-2017)
  • HAL Id : tel-01415825 , version 1
Fatma Cheikh. Identification de fractures dans un milieu poreux. Mathématiques [math]. UPMC - Université Paris 6 Pierre et Marie Curie; ENIT Tunis, 2016. Français. ⟨NNT : ⟩. ⟨tel-01415825v1⟩
Collections
UPMC
722 Consultations
365 Téléchargements
