Implications of scarcity for materials research, AIP Conference Proceedings, pp.1-3199, 1982. ,
DOI : 10.1063/1.30806
A simple scheme for developing ???upwind??? finite elements, International Journal for Numerical Methods in Engineering, vol.11, issue.9, pp.1359-1365, 1978. ,
DOI : 10.1002/nme.1620120904
A method for the numerical calculations of hydrodynamical schocks, J.Appl.Phys, issue.21, pp.232-238, 1950. ,
Calculation of elastic plastic flow, Methods in Computational Physics, issue.3, 1964. ,
Use of artificial viscosity in multidimensional fluid dynamic calculations, Journal of Computational Physics, vol.36, issue.3, pp.381-403, 1980. ,
DOI : 10.1016/0021-9991(80)90161-8
Résolution numérique desprobì emes multidimensionnels de la dynamique des gaz, 1979. ,
Nonlinear magnetohydrodynamis simulation using high-order finite elements, Journal of Computational Physics, issue.195, pp.355-386, 2004. ,
DOI : 10.1016/j.jcp.2003.10.004
Some properties of the M3D-C1 form of the three-dimensional magnetohydrodynamics equations, Physics of Plasmas, vol.16, issue.9, 2009. ,
DOI : 10.1063/1.3224035
B??zier surfaces and finite elements for MHD simulations, Journal of Computational Physics, vol.227, issue.16, pp.7423-7445, 2008. ,
DOI : 10.1016/j.jcp.2008.04.001
Non-linear MHD simulations of edge localized modes (ELMs) Plasma Physics and Controlled Fusion, p.51, 2009. ,
Semi-implicit method for three-dimensional compressible magnetohydrodynamic simulation, Journal of Computational Physics, vol.60, issue.1, pp.62-75, 1985. ,
DOI : 10.1016/0021-9991(85)90017-8
Review of implicit methods for the magnetohydrodynamic description of magnetically confined plasmas, Journal of Computational Physics, vol.231, issue.3, pp.822-838, 2012. ,
DOI : 10.1016/j.jcp.2010.12.025
XTOR-2F: A fully implicit Newton???Krylov solver applied to nonlinear 3D extended MHD in tokamaks, Journal of Computational Physics, vol.229, issue.21, pp.8130-8143, 2010. ,
DOI : 10.1016/j.jcp.2010.07.013
A new finite element formulation for computational fluid dynamics: II. Beyond SUPG, Computer Methods in Applied Mechanics and Engineering, vol.54, issue.3, pp.341-355, 1986. ,
DOI : 10.1016/0045-7825(86)90110-6
Stabilized Methods for Compressible Flows, Journal of Scientific Computing, vol.190, issue.10, pp.343-368, 2010. ,
DOI : 10.1007/s10915-008-9233-5
Time-accurate solution of advection-diffusion problems by finite elements, Computer Methods in Applied Mechanics and Engineering, vol.45, issue.1-3, pp.1-3123, 1984. ,
DOI : 10.1016/0045-7825(84)90153-1
An analysis of time discretization in the finite element solution of hyperbolic problems, Journal of Computational Physics, vol.70, issue.2, pp.463-499, 1987. ,
DOI : 10.1016/0021-9991(87)90191-4
A Taylor???Galerkin Method for Simulating Nonlinear Dispersive Water Waves, Journal of Computational Physics, vol.146, issue.2, pp.546-569, 1998. ,
DOI : 10.1006/jcph.1998.6027
Calculations of two-fluid magnetohydrodynamic axisymmetric steady-states, Journal of Computational Physics, vol.228, issue.20, pp.7742-7770, 2009. ,
DOI : 10.1016/j.jcp.2009.07.015
PaStiX: a high-performance parallel direct solver for sparse symmetric positive definite systems, Parallel Computing, vol.28, issue.2, pp.301-321, 2002. ,
DOI : 10.1016/S0167-8191(01)00141-7
Ist die Trägheit eines Körpers von seinem Energieinhalt abhängig? Annalen der Physik, pp.639-641, 1905. ,
Nuclear Physics A. Stationary States of Nuclei, Reviews of Modern Physics, vol.8, issue.2, pp.8-229, 1936. ,
DOI : 10.1103/RevModPhys.8.82
On transformations of elements in the interiors of stars. I) ,
Some Criteria for a Power Producing Thermonuclear Reactor, Proceedings of the Physical Society. Section B, vol.70, issue.1, 1957. ,
DOI : 10.1088/0370-1301/70/1/303
Intrinsic momentum transport in updown asymmetric tokamaks, Plasma Physics and Controlled Fusion, issue.9, pp.56-2014 ,
Magnetic-confinement fusion, Nature Physics, vol.47, pp.398-410, 2016. ,
DOI : 10.1038/nphys3745
A quarter century of H-mode studies. Plasma Physics and Controlled Fusion, 2007. ,
Simulation magnéto-hydro-dynamique des edge localized modes dans un tokamak, 2010. ,
Non-linear MHD modeling of edge localized mode cycles and mitigation by resonant magnetic perturbations, Plasma Physics and Controlled Fusion, vol.57, issue.1, p.2014 ,
DOI : 10.1088/0741-3335/57/1/014020
Internal Kink Modes in Toroidal Plasmas with Circular Cross Sections, Physical Review Letters, vol.35, issue.24, p.1638, 1975. ,
DOI : 10.1103/PhysRevLett.35.1638
Existence of Electromagnetic-Hydrodynamic Waves, Nature, vol.150, issue.3805, pp.405-406, 1942. ,
DOI : 10.1038/150405d0
Existence of Electromagnetic-Hydrodynamic Waves, Nature, vol.150, issue.3805, pp.1-7, 1943. ,
Wall forces produced during ITER disruptions, Physics of Plasmas, vol.17, issue.8, 2010. ,
DOI : 10.1063/1.3474922
Magnetic X-points, edge localized modes, and stochasticity, Physics of Plasmas, vol.17, issue.6, 2010. ,
DOI : 10.1063/1.3449301
BOUT++: A framework for parallel plasma fluid simulations, Computer Physics Communications, vol.180, issue.9, pp.1467-1480, 2009. ,
DOI : 10.1016/j.cpc.2009.03.008
Fundamentals of plasma physics, 2006. ,
DOI : 10.1017/CBO9780511807183
Reviews of plasma physics, 1965. ,
Introduction to plasma physics and controlled fusion, 1984. ,
DOI : 10.1007/978-1-4757-5595-4
Plasma transport coefficients in a magnetic field by direct numerical solution of the Fokker???Planck equation, Physics of Fluids, vol.29, issue.4, pp.1029-1041, 1986. ,
DOI : 10.1063/1.865901
An introduction to plasma physics, 1962. ,
Modlisations fluides pour les plasmas de fusion : approximation par lments finis C1 de Bell, 2013. ,
Hyperbolic Divergence Cleaning for the MHD Equations, Journal of Computational Physics, vol.175, issue.2, pp.645-673, 2002. ,
DOI : 10.1006/jcph.2001.6961
Fluid modeling of magnetized plasmas, Space Science Reviews, vol.31, issue.1-2, pp.153-167, 1985. ,
DOI : 10.1007/BF00218230
The Effect of Nonzero ??? ?? B on the numerical solution of the magnetohydrodynamic equations, Journal of Computational Physics, vol.35, issue.3, pp.426-430, 1980. ,
DOI : 10.1016/0021-9991(80)90079-0
A Staggered Mesh Algorithm Using High Order Godunov Fluxes to Ensure Solenoidal Magnetic Fields in Magnetohydrodynamic Simulations, 54] J. Vides. Godunov-type schemes for hydrodynamic and magnetohydrodynamic modeling, pp.270-292, 2014. ,
DOI : 10.1006/jcph.1998.6153
Some Criteria for a Power Producing Thermonuclear Reactor, Proceedings of the Physical Society, 1957. ,
An approximate Riemann solver for the magnetohydrodynamics (that works in more than one dimension), ICASE Report, pp.92-94, 1994. ,
Eigenvalues, eigenvectors and symmetrization of the magnetohydrodynamic . AFOSR, Grantees and contractors meeting, 2006. ,
An upwind differencing scheme for the equations of ideal magnetohydrodynamics, Journal of Computational Physics, vol.75, issue.2, p.75, 1988. ,
DOI : 10.1016/0021-9991(88)90120-9
Nonlinear, three-dimensional magnetohydrodynamics of noncircular tokamaks, Physics of Fluids, vol.19, issue.1, pp.134-140, 1976. ,
DOI : 10.1063/1.861310
Hybrid magnetohydrodynamic-particle simulation of linear and nonlinear evolution of Alfv??n modes in tokamaks, Physics of Plasmas, vol.5, issue.9, pp.3287-3301, 1998. ,
DOI : 10.1063/1.872997
Effects of toroidicity on resistive tearing modes, Physics of Fluids, vol.19, issue.1, pp.134-140, 1983. ,
Dynamics of high ?? tokamaks, Physics of Fluids, vol.20, issue.8, pp.1354-1360, 1977. ,
DOI : 10.1063/1.862018
MHD stability in X-point geometry: simulation of ELMs, Nuclear Fusion, vol.47, issue.7, p.47, 2007. ,
DOI : 10.1088/0029-5515/47/7/016
Hydromagnetic equilibria and force-free fields, 2nd UN Conf. on the Peaceful Uses of Atomic Energy, p.31, 1958. ,
DOI : 10.1016/0891-3919(58)90139-6
Plasma equilibrium in a magnetic field, Reviews of Plasma Physics, 1966. ,
Nonlinear magnetohydrodynamics, 1997. ,
Plasma physics and fusion energy, 2007. ,
DOI : 10.1017/CBO9780511755705
Multiscale phenomena: Green's functions, the Dirichlet-to-Neumann formulation, subgrid scale models, bubbles and the origins of stabilized methods, Computer Methods in Applied Mechanics and Engineering, vol.127, issue.1-4, pp.1-4, 1995. ,
DOI : 10.1016/0045-7825(95)00844-9
Analysis of a stabilized finite element approximation of the Oseen equations using orthogonal subscales, Applied Numerical Mathematics, vol.58, issue.3, pp.264-283, 2008. ,
DOI : 10.1016/j.apnum.2006.11.011
Analysis of a pressure stabilized finite element approximation of the stationary Navier-Stokes equations, Numerische Mathematik, vol.87, pp.59-81, 2000. ,
On stabilized finite element methods for linear systems of convection???diffusion-reaction equations, Computer Methods in Applied Mechanics and Engineering, vol.188, issue.1-3, pp.61-82, 2000. ,
DOI : 10.1016/S0045-7825(00)00177-8
Multiscale and stablized methods. Chapter, 2004. ,
Finite element methods for second order differential equations with significant first derivatives, International Journal for Numerical Methods in Engineering, vol.22, issue.6, pp.1389-1396, 1976. ,
DOI : 10.1002/nme.1620100617
A better consistency for low-order stabilized finite element methods, Computer Methods in Applied Mechanics and Engineering, vol.174, issue.1-2, pp.153-170, 1999. ,
DOI : 10.1016/S0045-7825(98)00284-9
Hierarchical basis for stabilized finite element methods for compressible flows, Computer Methods in Applied Mechanics and Engineering, vol.192, issue.47-48, pp.5167-5185, 2003. ,
DOI : 10.1016/j.cma.2003.07.011
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.17.4634
Stabilization and shock-capturing parameters in SUPG formulation of compressible flows, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.13-16, pp.1621-1632, 2006. ,
DOI : 10.1016/j.cma.2005.05.032
The design and applicatioin of upwind schemes on unstructured meshes, 27th AIAA Aerospace Sciences Meeting Paper 89, 1989. ,
Finite element solution of compressible viscous flows using conservative variables Computer methods in applied mechanics and engineering An unstructured finite element method for solving the compressible RANS equations and the Spalart-Allmaras turbulence model, Computer methods in applied mechanics and engineering, pp.319-3502261, 1994. ,
Stabilization and shock-capturing parameters in SUPG formulation of compressible flows Computer methods in applied mechanics and engineering, pp.9-121272, 2011. ,
A fully coupled RANS Spalart- Allmaras SUPG formulation for turbulent compressible flows on stretchedunstructured grids. Computer methods in applied mechanics and engineering, pp.233-236109, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00725797
Alternating Direction Implicit Methods for Parabolic Equations with a Mixed Derivative, SIAM Journal on Scientific and Statistical Computing, vol.1, issue.1, pp.131-159, 1980. ,
DOI : 10.1137/0901007
A triangular finite element with first-order continuity applied to fusion MHD applications, Journal of Computational Physics, pp.133-152, 2004. ,
Démonstration du théorème de Weierstrass, fondé sur le calcul des probabilités, Communications of the Society of Mathematics, vol.13, issue.2, pp.1912-1913 ,
C1 continuity conditions between two adjacent rational Bézier surface patches, Computer aided geometric design, issue.7, pp.151-163, 1990. ,
DOI : 10.1016/0167-8396(90)90027-o
PHOENIX: MHD spectral code for rotating laboratory and gravitating astrophysical plasmas, Journal of Computational Physics, vol.226, issue.1 ,
DOI : 10.1016/j.jcp.2007.04.018
Unstable continuous spectra of transonic axisymmetric plasmas, Physics of Plasmas, vol.11, issue.1, pp.28-54, 2004. ,
DOI : 10.1063/1.1631812
Stability of ideal and resistive internal kink modes in toroidal geometry, Physics of Fluids, vol.30, issue.6, pp.1756-1766, 1987. ,
DOI : 10.1063/1.866242
