New interface
Theses
The Discrete Ordered Median Problem revisited: new formulations, properties and algorithms
Diego Ponce Lopez 1, 2
2 INOCS - Integrated Optimization with Complex Structure
Inria Lille - Nord Europe, ULB - Université libre de Bruxelles, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : This dissertation studies in depth the structure of the Discrete Ordered Median Problem (DOMP), to define new formulations and resolution algorithms. Furthermore we analyze an interesting extension for DOMP, namely MDOMP (Monotone Discrete Ordered Median Problem). This thesis is structured in three main parts.First, a widely theoretical and computational study is reported. It presents several new formulations for the Discrete Ordered Median Problem (DOMP) based on its similarity with some scheduling problems. Some of the new formulations present a considerably smaller number of constraints to define the problem with respect to some previously known formulations. Furthermore, the lower bounds provided by their linear relaxations improve the ones obtained with previous formulations in the literature even when strengthening is not applied. We also present a polyhedral study of the assignment polytope of our tightest formulation showing its proximity to the convex hull of the integer solutions of the problem. Several resolution approaches, among which we mention a branch and cut algorithm, are compared. Extensive computational results on two families of instances, namely randomly generated and from Beasley's OR-library, show the power of our methods for solving DOMP. One of the achievements of the new formulation consists in its tighter LP-bound. Secondly, DOMP is addressed with a new set partitioning formulation using an exponential number of variables. This chapter develops a new formulation in which each variable corresponds to a set of demand points allocated to the same facility with the information of the sorting position of their corresponding distances. We use a column generation approach to solve the continuous relaxation of this model. Then, we apply a branch-cut-and-price algorithm to solve to optimality small to moderate size of DOMP in competitive computational time.To finish, the third contribution of this dissertation is to analyze and compare formulations for the monotone discrete ordered median problem. These formulations combine different ways to represent ordered weighted averages of elements by using linear programs together with the p-median polytope. This approach gives rise to two efficient formulations for DOMP under a hypothesis of monotonicity in the lambda vectors. These formulations are theoretically compared and also compared with some other formulations valid for the case of general lambda vector. In addition, it is also developed another new formulation, for the general case, that exploits the efficiency of the rationale of monotonicity. This representation allows to solve very efficiently some DOMP instances where the monotonicity is only slightly lost. Detailed computational tests on all these formulations is reported in the dissertation. They show that specialized formulations allow to solve to optimality instances with sizes that are far beyond the limits of those that can solve in the general case.
Document type :
Theses
Complete list of metadata
Cited literature [73 references]  Display  Hide  Download
https://hal.inria.fr/tel-01421868
Contributor : Bernard Fortz Connect in order to contact the contributor
Submitted on : Friday, December 23, 2016 - 11:11:26 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Monday, March 20, 2017 - 8:19:47 PM
Identifiers
  • HAL Id : tel-01421868, version 1
Collections
Citation
Diego Ponce Lopez. The Discrete Ordered Median Problem revisited: new formulations, properties and algorithms. Operations Research [cs.RO]. Université Libre de Bruxelles (U.L.B.), Belgium, 2016. English. ⟨NNT : ⟩. ⟨tel-01421868⟩
Share
Metrics
Record views
295
Files downloads
250
