Residual Distribution Schemes for Conservation Laws via Adaptive Quadrature, SIAM Journal on Scientific Computing, vol.24, issue.3, pp.732-769, 2003. ,
DOI : 10.1137/S106482750138592X
An immersed boundary method using unstructured anisotropic mesh adaptation combined with level-sets and penalization techniques, Journal of Computational Physics, vol.257, pp.83-101, 2014. ,
DOI : 10.1016/j.jcp.2013.08.052
URL : https://hal.archives-ouvertes.fr/hal-00786853
Linear and non-linear high order accurate residual distribution schemes for the discretization of the steady compressible Navier???Stokes equations, Journal of Computational Physics, vol.283, pp.329-359, 2015. ,
DOI : 10.1016/j.jcp.2014.11.031
Construction of very high order residual distribution schemes for steady inviscid flow problems on hybrid unstructured meshes, Journal of Computational Physics, vol.230, issue.11, pp.4103-4136, 2011. ,
DOI : 10.1016/j.jcp.2010.07.035
URL : https://hal.archives-ouvertes.fr/inria-00464799
A simple construction of very high order non-oscillatory compact schemes on unstructured meshes, Computers & Fluids, vol.38, issue.7, pp.1314-1323, 2009. ,
DOI : 10.1016/j.compfluid.2008.01.031
URL : https://hal.archives-ouvertes.fr/inria-00333756
High order fluctuation schemes on triangular meshes, Journal of Scientific Computing, vol.19, issue.1/3, pp.3-36, 2003. ,
DOI : 10.1023/A:1025335421202
An Example of High Order Residual Distribution Scheme Using non-Lagrange Elements, Journal of Scientific Computing, vol.59, issue.7, pp.3-25, 2010. ,
DOI : 10.1007/s10915-010-9405-y
URL : https://hal.archives-ouvertes.fr/inria-00403691
p-adaptation using Residual Distribution schemes with continuous finite elements, Inria Bordeaux Sud-Ouest, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01225583
An hp-adaptive Petrov-Galerkin method for steady-state and unsteady flow problems. PhD, 2015. ,
High-order finiteelement method and dynamic adaptation for two-dimensional laminar and turbulent Navier-Stokes, 2014. ,
An adjoint-based hpadaptive Petrov-Galerkin method for turbulent flows, 2015. ,
Computational fluid dynamics: the basics with applications, 1995. ,
A penalization method to take into account obstacles in incompressible viscous flows, Numerische Mathematik, vol.81, issue.4, pp.497-520, 1999. ,
DOI : 10.1007/s002110050401
The p- and h-p versions of the finite element method, an overview, Computer Methods in Applied Mechanics and Engineering, vol.80, issue.1-3, pp.5-26, 1990. ,
DOI : 10.1016/0045-7825(90)90011-A
The h, p and h-p version of the finite element method; basis theory and applications, Advances in Engineering Software, vol.15, issue.3-4, pp.3-4159, 1992. ,
DOI : 10.1016/0965-9978(92)90097-Y
Unsteady residual distribution schemes adapted to immersed boundary methods on unstructured grids to account for moving bodies, 13th US National Congress on Computational Mechanics, p.2015 ,
URL : https://hal.archives-ouvertes.fr/hal-01257678
A high-resolution penalization method for large mach number flows in the presence of obstacles. Computers and fluids, pp.703-714, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00259907
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.199-259, 1982. ,
DOI : 10.1016/0045-7825(82)90071-8
A Problem-Independent Limiter for High-Order Runge???Kutta Discontinuous Galerkin Methods, Journal of Computational Physics, vol.169, issue.1, pp.111-150, 2001. ,
DOI : 10.1006/jcph.2001.6718
Implementation of the Continuous-Discontinuous Galerkin Finite Element Method, Numerical Mathematics and Advanced Applications, p.315, 2011. ,
DOI : 10.1007/978-3-642-33134-3_34
High order schemes for cfd: A review, Chinese Journal of Computational Physics, vol.5, p.2, 2009. ,
TVB Runge-Kutta local projection discontinuous Galerkin finite element method for conservation laws III: One-dimensional systems, Journal of Computational Physics, vol.84, issue.1, pp.90-113, 1989. ,
DOI : 10.1016/0021-9991(89)90183-6
Computation of the signed distance function to a discrete contour on adapted triangulation, Calcolo, vol.74, issue.3, pp.193-219, 2012. ,
DOI : 10.1007/s10092-011-0051-z
On optimal triangular meshes for minimizing the gradient error, Numerische Mathematik, vol.16, issue.1, pp.321-348, 1991. ,
DOI : 10.1007/BF01385784
Development of a high-order Residual Distribution method for Navier-Stokes and RANS equations, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-00946171
Multidimensional upwind schemes based on fluctuation-splitting for systems of conservation laws, Computational Mechanics, vol.63, issue.No. 2, pp.323-340, 1993. ,
DOI : 10.1007/BF00350091
Compact advection schemes on unstructured grids. Computational Fluid Dynamics, VKI LS 1993-04, pp.94-18557, 1993. ,
Computing with hp-ADAPTIVE FINITE ELEMENTS: Volume 1 One and Two Dimensional Elliptic and Maxwell problems, 2006. ,
DOI : 10.1201/9781420011685
Mathematical aspects of discontinuous Galerkin methods, 2011. ,
DOI : 10.1007/978-3-642-22980-0
Finite element methods for flow problems, 2003. ,
DOI : 10.1002/0470013826
Contr??le de l'approximation g??om??trique d'une interface par une m??trique anisotrope, Comptes Rendus Mathematique, vol.345, issue.9, pp.537-542, 2007. ,
DOI : 10.1016/j.crma.2007.10.008
High-order accurate, low numerical diffusion methods for aerodynamics, Progress in Aerospace Sciences, pp.192-300, 2005. ,
DOI : 10.1016/j.paerosci.2005.03.003
High-order finiteelement method for three-dimensional turbulent Navier-Stokes, 2013. ,
The Discrete Geometric Conservation Law and the Nonlinear Stability of ALE Schemes for the Solution of Flow Problems on Moving Grids, Journal of Computational Physics, vol.174, issue.2, pp.669-694, 2001. ,
DOI : 10.1006/jcph.2001.6932
Coupling an Eulerian Fluid Calculation to a Lagrangian Solid Calculation with the Ghost Fluid Method, Journal of Computational Physics, vol.175, issue.1, pp.200-224, 2002. ,
DOI : 10.1006/jcph.2001.6935
Stabilized finite element methods: II. The incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.99, issue.2-3, pp.209-233, 1992. ,
DOI : 10.1016/0045-7825(92)90041-H
Anisotropic mesh adaptation for CFD computations, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.48-49, pp.5068-5082, 2005. ,
DOI : 10.1016/j.cma.2004.11.025
Mesh generation: application to finite elements , hermes science, Europe, 2000. ,
DOI : 10.1002/9780470611166
A contribution to the construction of diffusion fluxes for finite volume and discontinuous Galerkin schemes, Journal of Computational Physics, vol.224, issue.2, pp.1049-1063, 2007. ,
DOI : 10.1016/j.jcp.2006.11.004
A sharp interface immersed boundary method for compressible viscous flows, Journal of Computational Physics, vol.225, issue.1, pp.528-553, 2007. ,
DOI : 10.1016/j.jcp.2006.12.007
A hybrid Cartesian/immersed boundary method for simulating flows with 3D, geometrically complex, moving bodies, Journal of Computational Physics, vol.207, issue.2, pp.457-492, 2005. ,
DOI : 10.1016/j.jcp.2005.01.020
Arbitrary Lagrangian Eulerian formulation for two-dimensional flows using dynamic meshes with edge swapping, Journal of Computational Physics, vol.230, issue.20, pp.7706-7722, 2011. ,
DOI : 10.1016/j.jcp.2011.06.026
Adaptive discontinuous Galerkin methods with shockcapturing for the compressible Navier-Stokes equations, International Journal for Numerical Methods in Fluids, vol.51, pp.9-101131, 2006. ,
Discontinuous Galerkin methods for compressible flows: higher order accuracy, error estimation and adaptivity. Lecture Series - Von Karman Institute for Fluid Dynamics, 2006. ,
Adaptive Discontinuous Galerkin Finite Element Methods for the Compressible Euler Equations, Journal of Computational Physics, vol.183, issue.2, pp.508-532, 2002. ,
DOI : 10.1006/jcph.2002.7206
A conservative interface method for compressible flows, Journal of Computational Physics, vol.219, issue.2, pp.553-578, 2006. ,
DOI : 10.1016/j.jcp.2006.04.001
Stabilized Methods for Compressible Flows, Journal of Scientific Computing, vol.190, issue.10, pp.343-368, 2010. ,
DOI : 10.1007/s10915-008-9233-5
Finite element methods for first-order hyperbolic systems with particular emphasis on the compressible euler equations, Computer Methods in Applied Mechanics and Engineering, vol.45, issue.1-3, pp.217-284, 1984. ,
DOI : 10.1016/0045-7825(84)90157-9
Output-based mesh adaptation for high order Navier???Stokes simulations on deformable domains, Journal of Computational Physics, vol.252, pp.468-494, 2013. ,
DOI : 10.1016/j.jcp.2013.06.007
Validation of SUPG Finite Element Simulations of Shockwave/Turbulent Boundary Layer Interactions in Hypersonic Flows, 51st AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition ,
DOI : 10.2514/6.2013-306
Development and validation of a SUPG finite element scheme for the compressible Navier???Stokes equations using a modified inviscid flux discretization, International Journal for Numerical Methods in Fluids, vol.3, issue.3, pp.265-293, 2008. ,
DOI : 10.1002/fld.1635
Conception et analyse de schémas distribuant le résidu d'ordre très élevé. Application à la mécanique des fluides, 2009. ,
Fluid-structure interactions using the ALE formulation AIAA paper 1999-0660, 1999. ,
Conservative interpolation of aerodynamic loads for aeroelastic computations, 41st Structures, Structural Dynamics, and Materials Conference and Exhibit, 1449. ,
DOI : 10.2514/6.2000-1449
Adaptive embedded unstructured grid methods, International Journal for Numerical Methods in Engineering, vol.60, issue.3, pp.641-660, 2004. ,
DOI : 10.1002/nme.978
Derivation and validation of a novel implicit second-order accurate immersed boundary method, Journal of Computational Physics, vol.227, issue.13, pp.6660-6680, 2008. ,
DOI : 10.1016/j.jcp.2008.03.031
A comparison of hp-adaptive strategies for elliptic partial differential equations, ACM Transactions on Mathematical Software (TOMS), vol.41, issue.12, 2014. ,
IMMERSED BOUNDARY METHODS, Annual Review of Fluid Mechanics, vol.37, issue.1, pp.239-261, 2005. ,
DOI : 10.1146/annurev.fluid.37.061903.175743
Flutter, tumble and vortex induced autorotation. Theoretical and Computational Fluid Dynamics, pp.165-170, 2004. ,
An isoparametric approach to high-order curvilinear boundary-layer meshing, Computer Methods in Applied Mechanics and Engineering, vol.283, pp.636-650, 2015. ,
DOI : 10.1016/j.cma.2014.09.019
A multiple grid scheme for solving the Euler equations, 5th Computational Fluid Dynamics Conference, pp.1565-1571, 1982. ,
DOI : 10.2514/6.1981-1025
The immersed boundary method, Acta Numerica, vol.11, pp.479-517, 2002. ,
An Adaptive Discontinuous Galerkin Technique with an Orthogonal Basis Applied to Compressible Flow Problems, SIAM Review, vol.45, issue.1, pp.53-72, 2003. ,
DOI : 10.1137/S00361445023830
Anisotropic adaptive simulation of transient flows using discontinuous Galerkin meth- ods ,
Contributions to the development of residual discretizations for hyperbolic conservation laws with application to shallow water flows ,
URL : https://hal.archives-ouvertes.fr/tel-00651688
A high-order discontinuous Galerkin method for the unsteady incompressible Navier???Stokes equations, Journal of Computational Physics, vol.222, issue.1, pp.391-407, 2007. ,
DOI : 10.1016/j.jcp.2006.07.029
High Order ENO and WENO Schemes for Computational Fluid Dynamics, Lecture Notes in Computational Science and Engineering, vol.9, pp.439-582, 1999. ,
DOI : 10.1007/978-3-662-03882-6_5
Higher-order finite element methods, 2003. ,
Efficient implementation of high order inverse Lax???Wendroff boundary treatment for conservation laws, Journal of Computational Physics, vol.231, issue.6, pp.2510-2527, 2012. ,
DOI : 10.1016/j.jcp.2011.11.037
Algorithms for interface treatment and load computation in embedded boundary methods for fluid and fluid-structure interaction problems, International Journal for Numerical Methods in Fluids, vol.41, issue.1, pp.1175-1206, 2011. ,
DOI : 10.1002/fld.2556
URL : https://hal.archives-ouvertes.fr/hal-00651118
Techniques for high-order adaptive discontinuous Galerkin discretizations in fluid dynamics, 2009. ,
A perspective on high-order methods in computational fluid dynamics, Science China Physics, Mechanics & Astronomy, vol.228, issue.20130318, pp.1-6, 2016. ,
DOI : 10.1007/s11433-015-5706-3
High-order methods for the Euler and Navier???Stokes equations on unstructured grids, Progress in Aerospace Sciences, pp.1-41, 2007. ,
DOI : 10.1016/j.paerosci.2007.05.001
High-order computational fluid dynamics tools for aircraft design, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.231, issue.1151, pp.372-2014, 2022. ,
DOI : 10.1098/rsta.1969.0031
Highorder cfd methods: current status and perspective, International Journal for Numerical Methods in Fluids, issue.8, pp.72811-845, 2013. ,
Adjoint-based error estimation and mesh adaptation for hybridized discontinuous Galerkin methods, International Journal for Numerical Methods in Fluids, vol.98, issue.2, pp.76811-834, 2014. ,
DOI : 10.1002/fld.3959
A simple error estimator and adaptive procedure for practical engineerng analysis, International Journal for Numerical Methods in Engineering, vol.7, issue.18, pp.337-357, 1987. ,
DOI : 10.1002/nme.1620240206
The superconvergent patch recovery anda posteriori error estimates. Part 2: Error estimates and adaptivity, International Journal for Numerical Methods in Engineering, vol.8, issue.7, pp.1365-1382, 1992. ,
DOI : 10.1002/nme.1620330703
