Agence pour la Protection des Programmes, 1996. ,
Performance comparison of parallel programming environments for implementing AIAC algorithms, Journal of Supercomputing . Special Issue on Performance Modelling and Evaluation of Parallel and Distributed Systems, vol.35, issue.3, pp.227-244, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00068624
Evaluation of the asynchronous iterative algorithms in the context of distant heterogeneous clusters, Parallel Computing, vol.31, issue.5, pp.31439-461, 2005. ,
DOI : 10.1016/j.parco.2005.02.009
Calculations of dose distributions using a neural network model, Physics in Medicine and Biology, vol.50, issue.5, pp.1019-1028, 2005. ,
DOI : 10.1088/0031-9155/50/5/024
URL : https://hal.archives-ouvertes.fr/hal-00426148
Dynamic load balancing and efficient load estimators for asynchronous iterative algorithms, IEEE Transactions on Parallel and Distributed Systems, vol.16, issue.4, pp.289-299, 2005. ,
DOI : 10.1109/TPDS.2005.45
URL : https://hal.archives-ouvertes.fr/hal-00096258
A decentralized convergence detection algorithm for asynchronous parallel iterative algorithms, IEEE Transactions on Parallel and Distributed Systems, vol.16, issue.1, pp.4-13, 2005. ,
DOI : 10.1109/TPDS.2005.2
URL : https://hal.archives-ouvertes.fr/hal-00096362
Evaluation of the diet hierarchical metacomputing architecture. Parallel and Distributed Computing Practices : Special Issue on Parallel Numeric Algorithms on Faster Computers, 2002. ,
Stability of fully asynchronous discrete-time discrete-state dynamic networks, IEEE Transactions on Neural Networks, vol.13, issue.6, pp.1353-1363, 2002. ,
A LOAD-BALANCED ALGORITHM FOR PARALLEL DIGITAL IMAGE WARPING, International Journal of Pattern Recognition and Artificial Intelligence, vol.13, issue.04, pp.445-463, 1999. ,
DOI : 10.1142/S0218001499000276
A Load Balanced Parallel Ground Visualization Tool, International Journal of Pattern Recognition and Artificial Intelligence, vol.11, issue.07, pp.1113-1127, 1997. ,
DOI : 10.1142/S0218001497000512
Convergence dans les systèmes booléens asynchrones et application aux réseaux de hopfield, CalculateursParalì eles, vol.13, issue.1, pp.107-124, 2001. ,
Neural Network Based Algorithm for Radiation Dose Evaluation in Heterogeneous Environments, Conférences internationales [15] Artificial Neural Networks -ICANN 2006, pp.777-787, 2006. ,
DOI : 10.1007/11840930_81
URL : https://hal.archives-ouvertes.fr/hal-00426179
Mixing synchronism / asynchronism in discrete-state discrete-time dynamic networks, 4th International Conference on Engineering Applications and Computational Algorithms, DCDIS 2005, pp.524-529, 2005. ,
Performance comparison of parallel programming environments for implementing aiac algorithms, 18th IEEE and ACM Int. Conf. on Parallel and Distributed Processing Symposium, p.247, 2004. ,
Coupling dynamic load balancing with asynchronism in iterative algorithms on the computational grid, Proceedings International Parallel and Distributed Processing Symposium, p.40, 2003. ,
DOI : 10.1109/IPDPS.2003.1213124
Asynchronism for iterative algorithms in a global computing environment, Proceedings 16th Annual International Symposium on High Performance Computing Systems and Applications, pp.90-97, 2002. ,
DOI : 10.1109/HPCSA.2002.1019139
<title>Vectorization, matching, and simplification of image contours in uncalibrated aerial stereo-vision</title>, Image and Signal Processing for Remote Sensing VI, pp.41-48, 2000. ,
DOI : 10.1117/12.413919
Specification of a Scilab meta-computing extension, Proceedings 2000. International Workshop on Parallel Processing, pp.207-214, 2000. ,
DOI : 10.1109/ICPPW.2000.869105
Optimization and Parallelization of a Geographical Stereo Vision Code, The Sixth International Conference in Central Europe on Computer Graphics and Visualization'98, pp.65-72, 1998. ,
Parallel Geometric Transformations of Images, Fifth International Workshop on Parallel Image Analysis, pp.13-30, 1997. ,
Parallel Visualization of Texture-Mapped Digital Elevation Models, Fourth International Workshop on Parallel Image Analysis, pp.269-282, 1995. ,
Utilisation des réseaux de neurones pour la conception d'un code de calcul pour la dosimétrie en radiothérapie externe, Conférences nationales [25], 2005. ,
Développement d'un code de calcul dosimétrique basé sur les réseaux artificiels de neurones, In44ì emes Journées Scientifiques de la Société Française de Physique Médicale, 2005. ,
Asynchronisme etéquilibrageetéquilibrage de charge dans la grille de calcul. InÉcoleIn´InÉcole d'hiver GRID, pp.365-373, 2002. ,
Spécification de services sous CORBA pour une extension métacomputing de Scilab, RenPar'12, pp.33-38, 2000. ,
CalculsParalì eles pour la Visualisation de Terrains avec Textures, RenPar'8, Edition Spéciale, GDR-PRC Parallélisme, Réseaux et Systèmes, pp.93-96, 1996. ,
Eric Martin, and Libor Makovicka. ´ Evaluation de doses d'irradiation en milieux hétérogènes, Journées de L'ISIFC, 2005. ,
Utilisation des réseaux d'apprentissage neuronaux en radiothérapie externe, 43èmes Journées scientifiques de la SFPM, 2004. ,
Use of the neural networks in external radiotherapy. In¨Current In¨ In¨Current Topics in Monte Carlo Treatment Planning¨, 2004. ,
Utilisation des rna en dosimétrie, 20èmes Journées des LARD, 2003. ,
Prospective de la planification des traitements radiothérapeutiques basée sur les réseaux de neurones, Journées Codes de calcul en radioprotection, radiophysique et dosimétrie, 2003. ,
Parallel visualization of texture-mapped digital elevation models, Séminaire dans le cadre du projet PARALIN, Département d'Ingénierie Mathématique, 1996. ,
A convergence result on fully-asynchronous discrete-time discrete-state dynamic networks, Research report, AND Team, 2002. ,
DOI : 10.1109/tnn.2002.805751
A Scalable Approach to Network Enabled Servers, Laboratoire de l'Informatique du Parallélisme (LIP), ´ Ecole Normale Supérieure de, 2002. ,
DOI : 10.1007/3-540-45706-2_128
URL : https://hal.archives-ouvertes.fr/inria-00072087
Scilab to Scilab//: The Ouragan project, Parallel Computing, vol.27, issue.11, 2001. ,
DOI : 10.1016/S0167-8191(01)00101-6
URL : https://hal.archives-ouvertes.fr/inria-00000277
Multiresolution approach for image processing, 1996. ,
Parallel visualization of textured-mapped digital elevation models, 1996. ,
The solitaire project ? finding solutions for the game in parallel, 1994. ,
Visualisationparalì ele de MNT texturés. Master's thesis, ´ Ecole Normale Supérieure, 1995. ,
Détection de collisions sur machineparalì ele, 1994. ,
Reconstruction 3D de terrains texturés Rapport de stage de licence A self-stabilizing leader election algorithm for tree graphs, Journal of Parallel and Distributed Computing, vol.34, issue.2, pp.227-232, 1993. ,
The Java(TM) Programming Language, 2005. ,
MPICH/Madeleine: a true multi-protocol MPI for high performance networks, Proceedings 15th International Parallel and Distributed Processing Symposium. IPDPS 2001, p.51, 2001. ,
DOI : 10.1109/IPDPS.2001.924991
URL : https://hal.archives-ouvertes.fr/inria-00072625
Boolean totally asynchronous iterations, International Journal of Mathematical Algorithms, vol.1, pp.331-346, 2000. ,
Jace: a Java environment for distributed asynchronous iterative computations, 12th Euromicro Conference on Parallel, Distributed and Network-Based Processing, 2004. Proceedings., pp.350-357, 2004. ,
DOI : 10.1109/EMPDP.2004.1271465
Parallel Treatment of a Class of Differential-Algebraic Systems, SIAM Journal on Numerical Analysis, vol.33, issue.5, pp.1969-1980, 1996. ,
DOI : 10.1137/S0036142993258105
Asynchronous multisplitting methods for nonlinear fixed point problems, Numerical Algorithms, vol.15, issue.3/4, pp.315-345, 1997. ,
DOI : 10.1023/A:1019158207224
Parallel solution of linear DAEs by multisplitting waveform relaxation methods, Linear Algebra and its Applications, vol.332, issue.334, pp.332-334181, 2001. ,
DOI : 10.1016/S0024-3795(00)00199-3
Asynchronous Iterative Algorithms for Nonexpansive Linear Systems, Journal of Parallel and Distributed Computing, vol.60, issue.1, pp.92-112, 2000. ,
DOI : 10.1006/jpdc.1999.1587
Simulations of asynchronous evolution of discrete systems, Simulation Practice and Theory, vol.7, issue.4, pp.309-324, 1999. ,
DOI : 10.1016/S0928-4869(99)00010-5
Convergence of discrete asynchronous iterations, International Journal of Computer Mathematics, vol.20, issue.1, pp.113-125, 2000. ,
DOI : 10.1007/BF01407866
Graph problems and connectionist architectures, 1987. ,
Asynchronous Iterative Methods for Multiprocessors, Journal of the ACM, vol.25, issue.2, pp.226-244, 1978. ,
DOI : 10.1145/322063.322067
URL : http://www.dtic.mil/get-tr-doc/pdf?AD=ADA035932
A method of terminating asynchronous iterative algorithms on message passing systems, Parallel Algorithms and Algorithms, vol.9, pp.153-158, 1996. ,
ContributionàContribution`Contributionà l'algorithmique paralléle, le concept d'asynchronisme : ´ etude théorique, mise en oeuvre, et application, HDR. LAAS CNRS, 1998. ,
Asynchronous Iterative Algorithms with Flexible Communication for Nonlinear Network Flow Problems, Journal of Parallel and Distributed Computing, vol.38, issue.1, pp.1-15, 1996. ,
DOI : 10.1006/jpdc.1996.0124
Distributed asynchronous algorithms with stochastic delays for constrained optimization problems with conditions of time drift, Parallel Computing, vol.21, issue.9, pp.1431-1450, 1995. ,
A parallel asynchronous implementation of the ??-relaxation method for the linear minimum cost flow problem, Parallel Computing, vol.23, issue.8, pp.1021-1044, 1997. ,
DOI : 10.1016/S0167-8191(97)00003-3
Distributed asynchronous computation of fixed points, Mathematical Programming, vol.12, issue.1, pp.107-120, 1983. ,
DOI : 10.1007/BF02591967
Convergence rate and termination of asynchronous iterative algorithms, Conference Proceedings, 1989 International Conference on Supercomputing, pp.461-470, 1989. ,
Parallel and Distributed Computation : Numerical Methods, 1989. ,
Parallel and distributed iterative algorithms : a selective survey, Automatica, vol.25, pp.3-21, 1991. ,
Parallel and Distributed Computation, 1999. ,
Existence and stability of a unique equilibrium in continuous-valued discrete-time asynchronous Hopfield neural networks, IEEE Transactions on Neural Networks, vol.7, issue.3 ,
DOI : 10.1109/72.501720
Timing Models and Local Stopping Criteria for Asynchronous Iterative Algorithms, Journal of Parallel and Distributed Computing, vol.58, issue.3, pp.446-465, 1999. ,
DOI : 10.1006/jpdc.1999.1549
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.85.5637
On the convergence properties of the Hopfield model, Proc. IEEE, pp.1579-1585, 1990. ,
DOI : 10.1109/5.58341
A generalized convergence theorem for neural networks, IEEE Transactions on Information Theory, vol.34, issue.5, pp.1089-1092, 1998. ,
DOI : 10.1109/18.21239
URL : http://authors.library.caltech.edu/5705/1/BRUieeetit88.pdf
Parallel and Sequential Methods for Ordinary Differential Equations, 1995. ,
Multiprogrammationparalì ele générique des méthodes de décomposition de domaine, 2001. ,
Chaotic relaxation, Linear Algebra and its Applications, vol.2, issue.2, pp.199-222, 1969. ,
DOI : 10.1016/0024-3795(69)90028-7
URL : http://doi.org/10.1016/0024-3795(69)90028-7
Iterative Solution of Linear Equations on a Parallel Processor System, IEEE Transactions on Computers, vol.26, issue.9, pp.838-847, 1977. ,
DOI : 10.1109/TC.1977.1674932
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.307.2377
Derivation of a termination detection algorithm for distributed computations, Information Processing Letters, vol.16, issue.5, pp.217-219, 1983. ,
DOI : 10.1016/0020-0190(83)90092-3
Leader election in distributed computing systems ,
DOI : 10.1007/BFb0038514
Diffusion Schemes for Load Balancing on Heterogeneous Networks, Theory of Computing Systems, pp.305-320, 2002. ,
DOI : 10.1007/s00224-002-1056-4
Parallel Execution of Iterative Algorithms, 1965. ,
Distributed Termination, ACM Transactions on Programming Languages and Systems, vol.2, issue.1, pp.42-55, 1980. ,
DOI : 10.1145/357084.357087
On asynchronous iterations, Journal of Computational and Applied Mathematics, vol.123, issue.1-2, pp.201-216, 2000. ,
DOI : 10.1016/S0377-0427(00)00409-X
URL : http://doi.org/10.1016/s0377-0427(00)00409-x
Asynchronous iterations with flexible communication for linear systems. CalculateursParalì eles, Réseaux et Systèmes répartis, pp.421-429, 1998. ,
A comparison result for multisplittings and waveform relaxation methods, Numerical linear algebra with applications, pp.335-346, 1995. ,
DOI : 10.1002/nla.1680020403
Elections in a Distributed Computing System, IEEE Transactions on Computers, vol.31, issue.1, pp.47-59, 1982. ,
DOI : 10.1109/TC.1982.1675885
The potential for parallelism in ordinary differential equations, 1986. ,
Massive parallelism across space in ODEs, Applied Numerical Mathematics, vol.11, issue.1-3, pp.27-43, 1991. ,
DOI : 10.1016/0168-9274(93)90038-S
PVM : A Users' Guide and Tutorial for Networked Parallel Computing, 1994. ,
DOI : 10.1063/1.4823450
Tight analyses of two local load balancing algorithms, Proceedings of the Twenty-Seventh Annual ACM Symposium on the Theory of Computing, pp.548-558 ,
Decreasing energy functions as a tool for studying threshold networks, Disc. Appl. Math, vol.12, pp.261-277, 1985. ,
OmniOrb web page ,
Using MPI : portable parallel programming with the message passing interface, 1994. ,
Parallel Asynchronous Algorithms for the K Shortest Paths Problem, Journal of Optimization Theory and Applications, vol.20, issue.1, pp.91-108, 2000. ,
DOI : 10.1023/A:1004676705907
Solving ordinary differential equations II : Stiff and differential-algebraic problems, pp.5-8, 1991. ,
Distributed dynamics in neural networks, Physical Review E, vol.47, issue.3, pp.2155-2161, 1993. ,
DOI : 10.1103/PhysRevE.47.2155
Methods of conjugate gradients for solving linear systems, Journal of Research of the National Bureau of Standards, vol.49, issue.6, pp.409-436, 1952. ,
DOI : 10.6028/jres.049.044
Neural networks and physical systems with emergent collective computational abilities., Proc. Nat. Acad. Sci, pp.2554-2558, 1982. ,
DOI : 10.1073/pnas.79.8.2554
Neurons with graded response have collective computational properties like those of two-state neurons., Proc. Nat. Acad. Sci, pp.3088-3092, 1984. ,
DOI : 10.1073/pnas.81.10.3088
Analysis of a graph coloring based distributed load balancing algorithm, Journal of Parallel and Distributed Computing, vol.10, issue.2, pp.160-166, 1990. ,
DOI : 10.1016/0743-7315(90)90025-K
Accelerated diffusion algorithms for dynamic load balancing, Information Processing Letters, vol.84, issue.2, pp.61-67, 2002. ,
DOI : 10.1016/S0020-0190(02)00238-7
Dynamics of Discrete Time, Continuous State Hopfield Networks, Neural Computation, vol.3, issue.3, pp.459-468, 1994. ,
DOI : 10.1109/31.62410
A Global Asymptotic Stability Result for a Class of Totally Asynchronous Discrete Nonlinear Systems, Mathematics of Control, Signals, and Systems, vol.12, issue.2, pp.143-166, 1999. ,
DOI : 10.1007/PL00009848
Superlinear convergence of asynchronous waveform relaxation methods for nonlinear ODEs, Proceedings of the 9th international colloquium on differential equations, 1999. ,
An iteration method for the solution of the eigenvalue problem of linear differential and integral operators, Journal of Research of the National Bureau of Standards, vol.45, issue.4, pp.255-282, 1950. ,
DOI : 10.6028/jres.045.026
The wavefront relaxation method for time-domain analysis of large scale integrated circuits, IEEE Trans. Computer-Aided Design of Integrated Circuits and Systems, issue.1, pp.131-145, 1982. ,
Test set for ivp solvers, 1996. ,
A chaotic asynchronous algorithm for computing the fixed point of a nonnegative matrix of unit spectral radius, Journal of the ACM, vol.33, issue.1, pp.130-150, 1986. ,
DOI : 10.1145/4904.4801
Distributed Algorithms, 1996. ,
Contrôle amorti des synchronisations pour le test d'arrêt des méthodes itératives, pp.177-182, 2002. ,
Dynamics of analog neural networks with time delay, Advances in Neural Information Processing Systems I. Morgan Kauffman, 1989. ,
Dynamics of iterated-map neural networks, Physical Review A, vol.40, issue.1, pp.501-504, 1989. ,
DOI : 10.1103/PhysRevA.40.501
Analysis and synthesis techniques for Hopfield type synchronous discrete time neural networks with application to associative memory, IEEE Transactions on Circuits and Systems, vol.37, issue.11, pp.1356-1366, 1990. ,
Algorithmes de relaxation chaotique ?? retards, Revue fran??aise d'automatique, informatique, recherche op??rationnelle. Analyse num??rique, vol.9, issue.R1, pp.52-82, 1975. ,
DOI : 10.1051/m2an/197509R100551
URL : http://archive.numdam.org/article/M2AN_1975__9_1_55_0.pdf
A new class of asynchronous iterative algorithms with order intervals, Mathematics of Computation of the American Mathematical Society, vol.67, issue.221, pp.237-255, 1998. ,
DOI : 10.1090/S0025-5718-98-00885-0
Asynchronous Relaxations for the Numerical Solution of Differential Equations by Parallel Processors, Parallel processing for scientific computing, pp.43-58, 1985. ,
DOI : 10.1137/0908012
P M 2 : Parallel multithreaded machine. A computing environment for distributed architectures In Parallel Computing : State-of-the-Art and Perspectives, ParCo'95, pp.279-285, 1996. ,
Algorithmique discrète et réseaux d'automates, 1986. ,
The CORBA Reference Guide : Understanding the Common Object Request Broker Architecture, 1997. ,
A distributed solution of the distributed termination problem, Information Processing Letters, vol.17, issue.1, pp.43-46, 1983. ,
DOI : 10.1016/0020-0190(83)90089-3
An efficient dynamic load balancing using the dimension exchange method for balancing of quantized loads on hypercube multiprocessors, Proceedings 13th International Parallel Processing Symposium and 10th Symposium on Parallel and Distributed Processing. IPPS/SPDP 1999, pp.708-713, 1999. ,
DOI : 10.1109/IPPS.1999.760553
Th??or??mes de Perron-Frobenius et Stein-Rosenberg bool??ens, Linear Algebra and its Applications, vol.19, issue.3, pp.237-250, 1978. ,
DOI : 10.1016/0024-3795(78)90013-7
URL : http://doi.org/10.1016/0024-3795(78)90013-7
Discrete Iterations, A Metric Study, 1986. ,
Les Systèmes Dynamiques Discrets, 1995. ,
A case study in programming for parallel processors, Communications of the ACM, vol.12, issue.12, pp.645-655, 1969. ,
Iterative Methods for Sparse Linear Systems, 1996. ,
DOI : 10.1137/1.9780898718003
Finite termination of asynchronous iterative algorithms, Parallel Computing, vol.22, issue.1, pp.39-56, 1996. ,
DOI : 10.1016/0167-8191(95)00059-3
Parallel asynchronous distributed computations of optimal control in large state space markov decision processes, ESANN, pp.325-330, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00099718
Guaranteed convergence in a class of Hopfield networks, IEEE Transactions on Neural Networks, vol.3, issue.6, pp.951-961, 1992. ,
DOI : 10.1109/72.165596
Leader election in asynchronous distributed systems, IEEE Transactions on Computers, vol.49, issue.3, pp.283-284, 2000. ,
Perspectives on asynchronous computations for fluid flow problems, 2000. ,
DOI : 10.1016/B978-008043944-0/50818-0
Neural networks for computation: number representations and programming complexity, Applied Optics, vol.25, issue.18, pp.3033-3046, 1986. ,
DOI : 10.1364/AO.25.003033
Some convergence results for asynchronous algorithms, Numerische Mathematik, vol.20, issue.3, pp.325-340, 1982. ,
Parallel synchronous and asynchronous iterative methods to solve Markov chain problems, Supercomputer, vol.10, issue.3, pp.28-39, 1993. ,
Systems of logic based on ordinals : a dissertation, 1938. ,
Quasi-synchronism : a step away from the traditional fault-tolerant real-time system models, Bulletin of the Technical Committee on Operating Systems and Application Environments (TCOS), pp.35-39, 1995. ,
On the dynamics of discrete-time, continuous-state Hopfield neural networks, II : Analog and Digital Signal Processing, pp.747-749, 1998. ,
DOI : 10.1109/82.686695
Absence of Cycles in Symmetric Neural Networks, Neural Computation, vol.2, issue.1, pp.1235-1249, 1998. ,
DOI : 10.1006/jmaa.1995.1138
Load Balancing in Parallel Computers : Theory and Practice, 1996. ,
Iterative methods for solving partial difference equations of elliptic type, Transactions of the American Mathematical Society, vol.76, issue.1, 1950. ,
DOI : 10.1090/S0002-9947-1954-0059635-7
A historical overview of iterative methods, Computer Physics Communications, vol.53, pp.1-17, 1989. ,
