Cellular model of dynamic neural fields
Modèles cellulaires de champs neuronaux dynamiques
In the constant search for design going beyond the limits of the von Neumann architecture, non conventional computing offers various solutions like neuromorphic engineering and cellular computing. Like von Neumann who roughly reproduced brain structures to design computers architecture, neuromorphic engineering takes its inspiration directly from neurons and synapses using analog substratum. Cellular computing influence comes from natural substratum (chemistry, physic or biology) imposing locality of interactions from which organisation and computation emerge. Research on neural mechanisms was able to demonstrate several emergent properties of the neurons and synapses. One of them is the attractor dynamics described in different frameworks by Amari with the dynamic neural fields (DNF) and Amit and Zhang with the continuous attractor neural networks. These neural fields have various computing properties and are particularly relevant for spatial representations and early stages of visual cortex processing. They were used, for instance, in autonomous robotics, classification and clusterization. Similarly to many neuronal computing models, they are robust to noise and faults and thus are good candidates for noisy hardware computation models which would enable to keep up or surpass the Moore law. Indeed, transistor area reductions is leading to more and more noise and the relaxation of the approx. 0% fault during production and operation of integrated circuits would lead to tremendous savings. Furthermore, progress towards many-cores circuits with more and more cores leads to difficulties due to the centralised computation mode of usual parallel algorithms and their communication bottleneck. Cellular computing is the natural answer to these problems. Based on these different arguments, the goal of this thesis is to enable rich computations and applications of dynamic neural fields on hardware substratum with neuro-cellular models enabling a true locality, decentralization and scalability of the computations. This work is an attempt to go beyond von Neumann architectures by using cellular and neuronal computing principles. However, we will stay in the digital framework by exploring performances of proposed architectures on FPGA. Analog hardware like VLSI would also be very interesting but is not studied here. The main contributions of this work are : 1) Neuromorphic DNF computation ; 2) Local DNF computations with randomly spiking dynamic neural fields (RSDNF model) ; 3) Local and asynchronous DNF computations with cellular arrays of stochastic asynchronous spiking DNFs (CASAS-DNF model).
Dans la recherche permanente de solutions pour dépasser les limitations de plus en plus visibles de nos architectures matérielles, le calcul non-conventionnel offre des alternatives variées comme l’ingénierie neuromorphique et le calcul cellulaire. Comme von Neumann qui s’était initialement inspiré du cerveau pour concevoir l’architecture des ordinateurs, l’ingénierie neuromorphique prend la même inspiration en utilisant un substrat analogique plus proche des neurones et des synapses. Le calcul cellulaire s’inspire lui des substrats de calcul naturels (chimique, physiques ou biologiques) qui imposent une certaine localité des calculs de laquelle va émerger une organisation et des calculs. La recherche sur les mécanismes neuronaux permet de comprendre les grands principes de calculs émergents des neurones. Un des grands principes que nous allons utiliser dans cette thèse est la dynamique d’attracteurs d’abord décrite par Amari (champs neuronaux dynamiques, ou DNF pour dynamic neural fields), Amit et Zhang (réseaux de neurones à attracteurs continus). Ces champs de neurones ont des propriétés de calcul variées mais sont particulièrement adaptés aux représentations spatiales et aux fonctions des étages précoces du cortex visuel. Ils ont été utilisés entre autres dans des applications de robotique autonome, dans des tâches de classification et clusterisation. Comme de nombreux modèles de calcul neuronal, ils sont également intéressants du point de vue des architectures matérielles en raison de leur robustesse au bruit et aux fautes. On voit donc l’intérêt que ces modèles de calcul peuvent avoir comme solution permettant de dépasser (ou poursuivre) la loi de Moore. La réduction de la taille des transistors provoque en effet beaucoup de bruit, de même que la relaxation de la contrainte de ~ 0% de fautes lors de la production ou du fonctionnement des circuits permettrait d’énormes économies. Par ailleurs, l’évolution actuelle vers des circuits many-core de plus en plus distribués implique des difficultés liées au mode de calcul encore centralisés de la plupart des modèles algorithmiques parallèles, ainsi qu’au goulot d’étranglement des communications. L’approche cellulaire est une réponse naturelle à ces enjeux. Partant de ces différents constats, l’objectif de cette thèse est de rendre possible les calculs et applications riches des champs neuronaux dynamiques sur des substrats matériels grâce à des modèles neuro-cellulaires assurant une véritable localité, décentralisation et mise à l’échelle des calculs. Cette thèse est donc une proposition argumentée pour dépasser les limites des architectures de type von Neumann en utilisant des principes de calcul neuronal et cellulaire. Nous restons cependant dans le cadre numérique en explorant les performances des architectures proposées sur FPGA. L’utilisation de circuits analogiques (VLSI) serait tous aussi intéressante mais n’est pas étudiée ici. Les principales contributions sont les suivantes : 1) Calcul DNF dans un environnement neuromorphique ; 2) Calcul DNF avec communication purement locale : modèle RSDNF (randomly spiking DNF) ; 3) Calcul DNF avec communication purement locale et asynchrone : modèle CASAS-DNF (cellular array of stochastic asynchronous spiking DNF).
