Passage à l'echelle d'un support d'exécution à base de tâches pour l'algèbre linéaire dense - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Scalability of a task-based runtime system for dense linear algebra applications
The ever-increasing supercomputer architectural complexity emphasizes the need for high-level parallel programming paradigms to design efficient, scalable and portable scientific applications. Among such paradigms, the task-based programming model abstracts away much of the architecture complexity by representing an application as a Directed Acyclic Graph (DAG) of tasks. Among them, the Sequential-Task-Flow (STF) model decouples the task submission step, sequential, from the parallel task execution step. While this model allows for further optimizations on the DAG of tasks at submission time, there is a key concern about the performance hindrance of sequential task submission when scaling. This thesis’ work focuses on studying the scalability of the STF-based StarPU runtime system (developed at Inria Bordeaux in the STORM team) for large scale 3D simulations of the CEA which uses dense linear algebra solvers. To that end, we collaborated with the HiePACS team of Inria Bordeaux on the Chameleon software, which is a collection of linear algebra solvers on top of task-based runtime systems, to produce an efficient and scalable dense linear algebra solver on top of StarPU up to 3,000 cores and 288 GPUs of CEA-DAM’s TERA-100 cluster.
La complexification des architectures matérielles pousse vers l’utilisation de paradigmes de programmation de haut niveau pour concevoir des applications scientifiques efficaces, portables et qui passent à l’échelle. Parmi ces paradigmes, la programmation par tâches permet d’abstraire la complexité des machines en représentant les applications comme des graphes de tâches orientés acycliques (DAG). En particulier, le modèle de programmation par tâches soumises séquentiellement (STF) permet de découpler la phase de soumission des tâches, séquentielle, de la phase d’exécution parallèle des tâches. Même si ce modèle permet des optimisations supplémentaires sur le graphe de tâches au moment de la soumission, il y a une préoccupation majeure sur la limite que la soumission séquentielle des tâches peut imposer aux performances de l’application lors du passage à l’échelle. Cette thèse se concentre sur l’étude du passage à l’échelle du support d’exécution StarPU (développé à Inria Bordeaux dans l’équipe STORM), qui implémente le modèle STF, dans le but d’optimiser les performances d’un solveur d’algèbre linéaire dense utilisé par le CEA pour faire de grandes simulations 3D. Nous avons collaboré avec l’équipe HiePACS d’Inria Bordeaux sur le logiciel Chameleon, qui est une collection de solveurs d’algèbre linéaire portés sur supports d’exécution à base de tâches, afin de produire un solveur d’algèbre linéaire dense sur StarPU efficace et qui passe à l’échelle jusqu’à 3 000 coeurs de calcul et 288 accélérateurs de type GPU du supercalculateur TERA-100 du CEA-DAM.
SERGENT_MARC_2016.pdf (2.55 Mo) Télécharger le fichier
tel-01483666 , version 1 (06-03-2017)
  • HAL Id : tel-01483666 , version 1
Marc Sergent. Passage à l'echelle d'un support d'exécution à base de tâches pour l'algèbre linéaire dense. Autre [cs.OH]. Université de Bordeaux, 2016. Français. ⟨NNT : 2016BORD0372⟩. ⟨tel-01483666⟩
450 Consultations
705 Téléchargements
