Détachement des substrats ultra-minces des matériaux semi-conducteurs par implantation d’hydrogène à hautes énergies pour les applications photovoltaïques et électroniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Detachment of ultra-thin substrates of semiconductor materials by high energy hydrogen implantation for photovoltaic and electronic applications
The motivation of this thesis was the study of an innovative process for the production of ultra-thin substrates (with thicknesses between 15 μm and 70 μm), based on the high energy hydrogen implantation, in our case in the range of 1 MeV to 2.5 MeV. Such an implantation followed by an appropriate thermal annealing, lead to the delamination of a freestanding thin layer, that we call “ultra-thin substrate”. The benefit of this delamination process is purely economic, since almost no raw material is lost. We have particularly used this process to produce ultra-thin (100) Si substrates, for the production of low-cost PV solar cells. In order to extend the process application fields, the delamination of ultra-thin substrates of two other materials (Ge and SiC) widely used in electronics has been also studied. In our work, the optimal implantation parameters (energy and fluence) and thermal annealing, leading to the delamination of large areas of Si (100) were first investigated. Subsequently, in order to validate the technological application of our process, solar cells have been performed with ultra-thin silicon substrates delaminated, with thicknesses of 50 μm and 70 μm. Results of PV performances obtained were quite close to those obtained with a reference solar cell achieved on a standard substrate. After that, in order to highlight the nature and the spatial distribution of fracture precursor defects after high energy hydrogen implantation in silicon, which had not yet done so far the subject of specific studies, characterizations have been carried out at different annealing stages, by means of TEM and FTIR. Finally, delamination results obtained with Ge and SiC, which were compared to the case of Si, helped us to learn more about delamination criteria. Indeed, we observed that, as the material rigidity increase, i.e. as the Young modulus is higher, the fluence and temperature require for the delamination will be also high.
Cette thèse a été motivée par l’étude d’un procédé innovant de production de substrats ultra-minces (d’épaisseur variant de 15 μm à 70 μm), basé sur l’implantation d’hydrogène à haute énergie, dans notre cas comprise entre 1MeV et 2.5MeV. Une telle implantation suivie d’un traitement thermique approprié, conduit au détachement d’un film mince autoporté, appelé « substrat ultra-mince ». L’intérêt de ce procédé de détachement est purement économique, car il ne génère presque aucune perte de matière première. Nous l’avons particulièrement utilisé pour produire des substrats ultra-minces de silicium (100), pour la production des cellules PV bas-coûts. Dans le but d’élargir les champs d’applications du procédé, le détachement de substrats ultra-minces de deux autres matériaux (le Ge et le SiC) très utilisés en électronique a aussi été étudié. Ainsi, dans cette étude, les paramètres optimaux d’implantation (énergie et fluence) et de recuits conduisant au détachement de grandes surfaces de Si(100) ont tout d’abord été investigués. Ensuite, l’application technologique du procédé proposé a été validée par la réalisation des cellules solaires au moyen des substrats ultrafins de Si détachés (50 μm et 70 μm d’épaisseur). Les performances PV obtenues ont été assez proches de celles obtenues avec une cellule référence réalisée sur un substrat standard. Par la suite, une étude détaillée faite par TEM et par FTIR sur les défauts étendus à différents stades de recuits a permis de mettre en lumière la nature et la distribution spatiale des défauts précurseurs de la fracture dans le Si après implantation à haute énergie. Enfin, des essais de détachements réalisés avec le Ge et le SiC, lesquels ont été comparés au cas du Si, ont permis d’en savoir plus sur les critères de détachement. En effet, plus le matériau sera rigide, i.e. plus il aura un module d’Young élevé, plus la fluence et la température de recuit nécessaires pour le détachement seront élevées.
paulinesylvia-pokamkuisseu_3524_vm.pdf (8.13 Mo) Télécharger le fichier
tel-01493989 , version 1 (22-03-2017)
  • HAL Id : tel-01493989 , version 1
Pauline Sylvia Pokam Kuisseu. Détachement des substrats ultra-minces des matériaux semi-conducteurs par implantation d’hydrogène à hautes énergies pour les applications photovoltaïques et électroniques. Autre. Université d'Orléans, 2016. Français. ⟨NNT : 2016ORLE2035⟩. ⟨tel-01493989⟩
307 Consultations
232 Téléchargements
