L'évolution organisationnelle de l'administration départementale dans le contexte de la numérisation généralisée - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Organizational evolution of the local administration in the context of generalized digitalization
This thesis examines the local French administration and its territorial de/reconstructions in relation to the digitalization process in a changing environment in which the efficiency of the public action is of main concern. Contrary to other studies, this research is based on a dynamic definition of the territory as a framework for collective action and on a broad concept oforganizational process which produces a weaving where lines of de/re/territorialisation get entangled. These lines are studied as a manner of being and acting and are thus involved in the process of structuring effective organizations. This process is observed from the perspective that the propensity to efficiency is found underlying or manifest in the form of digital media and its joint arrangement. The de/re/territorialisation mechanisms linked to digitalization were investigated during a three years fieldwork. If the coexistence of organizational coding and decoding are making the territory alive, actual and becoming at the same time, the tendency to higher code enhancing through digitalization challenges the capacity to renew the potential of efficiency.
Cette thèse examine l’organisation départementale et ses dé/recompositions territoriales en lien avec le numérique dans un contexte changeant où la question de l’efficacité de l’action publique se pose davantage. A la différence d’autres travaux, cette recherche s’appuie sur une définition dynamique du territoire comme cadre de l’action collective et sur une conception élargie du processus organisationnel comme tissage enchevêtrant des lignes de dé/re/territorialisation qui seraient des modes d’être et d’agir et qui seraient alors impliquées dans le processus de structuration des organisations efficaces. Ce dernier est étudié sur la base d’un modèle selon lequel la propension à l’efficacité se retrouve cristallisée de manière manifeste ou latente dans les supports numériques et leurs configurations associées. Les phénomènes de dé/re/territorialisation du et par le numérique sont analysés au sein d’un Département où nous avons été immergéependant trois ans. Si la coexistence du codage et décodage organisationnel rend le territoire vivant, à la fois actuel et en devenir, la tendance à la radicalisation des codes via le numérique questionne la capacité à renouveler le potentiel d’efficacité.
2017theseDrambaMpartielle.pdf (48.54 Mo) Télécharger le fichier
tel-01497754 , version 1 (29-03-2017)
  • HAL Id : tel-01497754 , version 1
Mihaela Drâmbӑ. L'évolution organisationnelle de l'administration départementale dans le contexte de la numérisation généralisée. Sciences de l'information et de la communication. Université Rennes 2, 2017. Français. ⟨NNT : 2017REN20015⟩. ⟨tel-01497754⟩
651 Consultations
255 Téléchargements
