Système de formation de faisceau dans la bande 300 GHz en technologie BiCMOS 55nm pour l’imagerie THz - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Beamforming system in the 300 GHz frequency band in BiCMOS 55 nm technology for THz imaging
The sub-millimeter wave band that covers the frequency range from 300 GHz to 3 THz has an interesting properties such the ability to penetrate materials. For THz imaging, it is possible to detect objects inside packages, clothes... With the evolution of integrated technologies and the increase of the cut-off frequencies of transistors 〖(f〗_t/f_max), many circuits and systems have been fabricated around 300 GHz, especially phased arrays for beamforming applications. These systems generate a signal and steer it electronically in a direction of the space. In this work, a novel architecture of phased array is proposed. It is based on the generation of a signal in the 270-300 GHz band, while controlling its phase by using phase shifters implemented in the LO path in the 45-50 GHz band. Each bloc should be measured in a stand-alone version, in order to get an idea about whole system performances. For this, the transmitter in the 270-300 GHz band has been realized first. It consists of a sub-harmonic injection locked oscillator, a passive mixer and IF amplifiers. Then, a novel architecture of phase shifter was proposed, it is based on slow waves coupled lines. Finally, a frequency multiplier chain was performed to generate the injection signal by using a lower frequency signal (3-5 GHz). The circuits are fabricated in a 55nm BiCMOS technology from STMicroelectronics. Measurements results are in a good agreement with simulations. Once the blocks are validated, sub systems are realized in order to validate one path of the array. The perspectives of this work include the design and realization of the complete phased array with multiple paths/antennas.
La bande sub-millimétrique allant globalement de 300 GHz à 3 THz possède des propriétés similaires à la capacité de pénétration de photons non ionisants à travers des matériaux optiquement opaques. Pour l'imagerie THz, il est ainsi possible de détecter des objets cachés à l'intérieur de paquets, de vêtements ou de matelas... Avec l’évolution des technologies intégrées et l’augmentation des fréquences de coupure des transistors 〖(f〗_t/f_max), de nombreux circuits et systèmes ont été réalisés à des fréquences autour de 300 GHz, en particulier les systèmes de formation de faisceau. Ces systèmes permettent de générer un signal et de l’orienter électroniquement dans une direction définie de l’espace. Dans ce travail, une architecture originale d’un tel système est proposée. Elle repose sur la génération d’un signal dans la bande 270-300 GHz, tout en contrôlant sa phase à l’aide de déphaseurs implémentés au niveau de la voie LO dans la bande 45-50 GHz. La complexité du système impose une stratégie qui consiste à réaliser chaque bloc seul. Pour cela, l’émetteur dans la bande 270-300 GHz a été réalisé dans un premier temps. Il est composé d’un oscillateur verrouillé par injection sous-harmonique (45-50 GHz), d’un mélangeur passif et d'amplificateurs IF. Ensuite une architecture innovante de déphaseur a été réalisée, basée sur des lignes couplées à ondes lentes. Finalement, une chaîne de multiplication de fréquence a été réalisée afin de générer le signal d’injection à l’aide d’un signal basse fréquence (3-5 GHz). Les circuits ont été fabriqués en technologie BiCMOS 55 nm de STMicroelectronics. Les résultats de mesure correspondent sont en très bon accord avec les simulations, et les performances obtenues sont à l’état de l’art. Une fois les blocs élémentaires validés, des sous-systèmes ont été réalisés pour valider le bon fonctionnement d’une voie complète du réseau d'antennes. En termes de perspectives, ce travail ouvre la voie vers la conception et la réalisation d'un système complet d'orientation de faisceau contenant plusieurs voies/antennes.
ISKANDAR_2016_diffusion.pdf (13.15 Mo) Télécharger le fichier
tel-01498555 , version 1 (30-03-2017)
  • HAL Id : tel-01498555 , version 1
Zyad Iskandar. Système de formation de faisceau dans la bande 300 GHz en technologie BiCMOS 55nm pour l’imagerie THz. Micro et nanotechnologies/Microélectronique. Université Grenoble Alpes, 2016. Français. ⟨NNT : 2016GREAT072⟩. ⟨tel-01498555⟩
248 Consultations
582 Téléchargements
