modèles et méthodes pour le génération de processus de fabrication reconfigurables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
representation models and generation methods to support reconfigurable process planning for product/part variety
Conventional manufacturing process planning approaches are inefficient to handle the process planning complexity induced by product variety and manufacturing dynamics. Reconfigurable process planning (RPP) is an emerging CAPP approach targeting to the generation of process plans for a product/part family. This thesis aims to give major contributions to the representation models and generation methods to support reconfigurable process planning at two granularity levels: product family and part family. The proposed approaches for RPP are compatible with an extended concept of product/part family which is defined by using the concept of “domain”. A feature-based product/part variety model is developed to represent the required information for RPP by using modular and platform-based techniques. Mathematical models and graph-based representation models are proposed to describe the reconfigurable process plan at two granularity levels. Based on the representation models, the generation methods and algorithms are then developed for RPP. In addition, a global framework is proposed to describe how the proposed RPP models and methods work together to handle the product/part variety and manufacturing dynamics. To test the feasibility of the proposed models and methods, a gear pump family and an oil pump body family are used as illustrative examples throughout this thesis.
Les approches conventionnelles pour la génération de processus de fabrication sont inefficaces pour gérer la complexité induite par la variété des produits et la dynamique de fabrication. La génération des processus de fabrication reconfigurables (RPP) est une nouvelle méthode de CAPP qui vise à générer des processus de fabrication pour une famille de produits / pièces. Cette thèse vise à apporter une contribution majeure aux modèles de représentation et aux méthodes de génération permettant la génération des processus de fabrication reconfigurables à deux niveaux de granularité : famille de produits et famille de pièces. Les approches proposées pour le RPP sont compatibles avec une extension du concept de famille de produits / pièces qui est défini en utilisant le concept de domaine. Un modèle pour une variété fonctionnelle de produit / pièce basé sur des entités est développé afin de représenter les informations nécessaires à la gestion des processus reconfigurables en utilisant des techniques modulaires. Des modèles mathématiques et des modèles de représentation sont proposés pour décrire le processus de fabrication reconfigurable à deux niveaux de granularité. Sur la base des modèles de représentation, les méthodes de génération et les algorithmes sont ensuite détaillés dans ce cadre. En outre, un cadre global est proposé pour décrire comment les modèles et les méthodes proposés collaborent pour gérer la variété de produit / pièce et la dynamique de fabrication. Pour illustrer la faisabilité des modèles et méthodes proposés, deux familles de pompes (l’une à engrenage et l’autre à huile) sont utilisées à titre d'exemples illustratifs tout au long de ce mémoire de thèse.
XIA.pdf (88.71 Mo) Télécharger le fichier
tel-01498623 , version 1 (30-03-2017)
  • HAL Id : tel-01498623 , version 1
Qing Xia. modèles et méthodes pour le génération de processus de fabrication reconfigurables. Autre. Ecole nationale supérieure d'arts et métiers - ENSAM, 2017. Français. ⟨NNT : 2017ENAM0004⟩. ⟨tel-01498623⟩
335 Consultations
94 Téléchargements
