Demixing Alkyl piperidines for CO2 capture : A thermodynamic approach
Alkyl pipéridine démixantes pour le captage du CO2 : approche thermodynamique
The increase of carbon dioxide (CO2) concentration in the atmosphere, since the industrial revolution has led to the rise in the average global climate temperature. To prevent the escalation of global climate temperatures the amount of CO2 emitted into the atmosphere must be reduced. One solution is carbon capture and sequestration which removes CO2 from fixed sources. The absorption/desorption cycle is well known for the treatment of acid gas, but is expensive and not as efficient for the treatment of gas from fixed/industrial sources. A solution to this problem is the use of aqueous demixing amine solvents which present a liquid-liquid phase equilibrium (LLE) as a function of temperature. This manuscript presents a study done to measure the LLE and thermodynamic properties of the alkyl piperidine family, which can be used for carbon capture processes. This work evaluates the effect of the size, position and number of alkyl substituents on the thermodynamic properties of interest in the carbon capture process. To study the LLE of aqueous demixing solutions, particularly gas loaded solutions, two novel apparatuses were developed. The results demonstrate that the changes in the amine phase diagrams are related to the chemical reactions involved with dissolution of CO2. The tertiary alkyl piperidines displayed reduced demixing temperature with the addition of CO2 due to the formation of carbonate species. The secondary alkyl piperidines display an increasing demixing temperature which is related to the formation of carbamate species which stabilizes the solution. Secondary alkyl piperidines that are severely sterically hindered, which cannot produce carbamates, behave similarly to the tertiary amine which is coherent with the preceding conclusion. The structure property relationship concerning the excess thermodynamic properties (VE, CpE et HE) of aqueous solutions were studied in depth. This revealed that the position of the substituents on the cyclic ring has a considerable and obvious influence on the intensity of the excess properties, along with the class of the amine, whether secondary or tertiary, will influence the positions of the extrema of the excess property. To conclude, a rigorous thermodynamic model based on the CO2 solubility and the enthalpy of solution for CO2 in aqueous solutions of alkyl piperidine, allowed for the determination of the carbamate formation constants of 3- and 4-methylpiperidine.
L'augmentation de la concentration de dioxyde de carbone (CO2) dans l'atmosphère depuis la révolution industrielle a conduit à l'augmentation de la température moyenne du globe. Pour limiter l’accroissement des températures atmosphériques moyennes, la quantité de dioxyde de carbone émise dans l'atmosphère doit être réduite. Une des solutions envisagée sur les sources fixes est le captage et le stockage du CO2. Ce procédé d’absorption/désorption, bien connu dans le traitement du gaz naturel, est onéreux et peu efficace pour le traitement du gaz des sources fixes et doit être optimisé. La solution proposée s’appuie sur l’utilisation de solvants démixants, présentant une séparation de phase équilibre liquide-liquide (LLE) en solution aqueuse en fonction de la température. Ce manuscrit présente une étude réalisée pour la famille des alkyl-pipéridines connues pour ses séparations de phase. Cette étude permettra d’évaluer l’influence de la taille, de la positionet du nombre de substituants sur les propriétés thermodynamiques d’intérêt pour le procédé. Pour étudier les LLE des solutions aqueuses démixantes, en particulier dans le cas des solutions chargées en gaz, deux instruments ont été mis au point. Il a été possible de démontrer que les changements opérés sur les diagrammes de phase des amines sont liés aux réactions chimiques mises en jeu lors de la dissolution du CO2. Pour les alkyl-pipéridines tertiaire on observe la température de démixtion diminue avec l’addition de CO2, allant avec la formation de carbonates. Avec les alkyl-pipéridines secondaires la température de démixtion augmente, ce qui est lié à la présence en solution de carbamates qui stabilisent la solution aqueuse. Le comportement des amines secondaires très encombrées, qui ne peuvent donc pas formées de carbamates, est similaire à celui des amines tertiaires, ce qui est cohérent avec les conclusions précédentes. Une étude approfondies des propriétés thermodynamiques d’excès (VE, CpE et HE) des alkyl-pipéridines en solution aqueuse a également permis de démontrer des relations structure - propriétés. La position du substituant sur le cycle pipéridine a une influence considérable et prévisible sur l’intensité des propriétés d’excès, alors que la nature de l’amine (secondaire ou tertiaire) va influencer la position de l’extremum de cette propriété. Enfin, une modélisation thermodynamique rigoureuses des solubilités et des enthalpies de dissolution du CO2 dans les solutions aqueuses de pipéridines a permis de déterminer les constantes de formation des carbamates dans les solutions aqueuses de 3- et 4-méthylpipéridines.
