Harvesting energy in pavements to de-freeze its surface
Récupération d'énergie dans les chaussées pour leur maintien hors gel
Winter maintenance operations for road networks are an important issue for maintaining the mobility in degraded situations, but generate high direct and indirect exploitation costs, particularly related to the intensive use of road de-icing and environmental impact. We study a road structure free of this penalty, thanks to a bonding drainage asphalt layer, circulated by a hot fluid, to prevent the deposition of snow or ice formation on the road surface. As part of an integrated vision of promoting the use of renewable energy, such device could be used to recuperate the thermal energy available in the road surface during the hot period, to transport it to a storage location (e.g. geothermal) and use it during cold period. We study here the heat exchanger function between the fluid and the road, the external storage function to the road being not addressed. The considered pavement structure has three asphalt layers.The bearing layer and the base layer are formed of conventional materials with hydrocarbon-based binders. The material of the bonding layer has a porosity of 20% and based on the use of a binder resistant to a prolonged circulation of the coolant. The road structure is assumed to have a slope of about 2 to 3%. An instrumented experimental road is implemented to collect data on the thermo-hydraulic response of the pavement structure. A thermo-hydraulic 2D model is designed to simulate the temperature field in the road structure when the fluid is injected at the upslope side of the road with a target temperature. This model is calibrated from experimental data collected on the experimental road subjected to meteorological solicitations. Initially, the sensibility of the distribution of the surface temperature of the road toward various model parameters (hydraulic conductivity, transversal slope, thermal conductivities, heat capacities) is analysed, in order to study the optimization of control procedures allowing to keep positive the road surface temperature at any point (e.g. determination of the minimum fluid injection temperature, under given meteorological data). In a second time, pavement thermal parameters is identified using control optimal method in order to validated unidimensionnel thermal model applied on July experimental data. In third time, hydraulic model is validated experimentaly using a laboratory mockup in saturated and unsaturated conditions. In a fourth time, thermo-hydraulic bidimensionnal model is validated numerically using mesured data of experimental pavement. Finally, harvest energy in summer period using thermal reglementation RT2012 data and heating energy in winter period using RT2012 and Massif Interdepartmental Road Direction (DIR MC) are calculated in order to evaluate system performance.
Les opérations de maintenance des routes en conditions hivernales sur réseaux routiers constituent un enjeu important pour maintenir l’offre de mobilité en situation dégradée. Elles génèrent des coûts d’exploitation directs et indirects élevés, liés en particulier à l’utilisation intensive de fondants routiers. Par ailleurs, leur impact environnemental doit être pris en considération. Nous étudions ici une structure de chaussée non soumise à ce type d’astreinte, grâce à la présence d’une couche de liaison drainante dans laquelle circule un fluide chaud, permettant ainsi d’éviter le dépôt de neige ou la formation de glace en surface. Dans le cadre d’une démarche en faveur de l’emploi d’énergie renouvelable, un tel dispositif pourrait permettre de récupérer l’énergie thermique disponible en surface de chaussée en période chaude, de l’acheminer vers un lieu de stockage (ex : géothermie) et de l’utiliser en période froide. Nous étudions ici la fonction d’échangeur de chaleur entre le fluide et la chaussée, la fonction de stockage externe à la chaussée n’étant pas abordée hormis dans la revue bibliographique. La structure de chaussée considérée comporte trois couches d’enrobés. La couche de roulement et la couche de base sont constituées de matériaux classiquement utilisés dans les chaussées, à base de liants hydrocarbonés. Le matériau de la couche de liaison possède une porosité supérieure à 20%. La structure de chaussée est supposée avoir un dévers de l’ordre de 2%. Une chaussée expérimentale instrumentée a été mise en oeuvre pour recueillir des grandeurs thermo-physiques de la chaussée. Un modèle thermo-hydrique 2D est d2veloppé numériquement pour calculer la distribution de température dans le corps de chaussée lorsque l’on injecte un fluide à température d’entrée donnée, en haut de dévers. Les paramètres du modèle sont identifiés à partir des données expérimentales recueillies sous diverses sollicitations climatiques. On analyse dans un premier temps la sensibilité de la distribution de température en surface de chaussée aux différents paramètres du modèle (conductivité hydraulique, dévers, conductivités thermiques, chaleurs massiques), afin d’optimiser les procédures nécessaires au contrôle sous contraintes de températures positives en tout point. Dans une deuxième partie, des données expérimentales recueillies durant une période estivale d’un mois ont servi à valider le modèle thermique 1D. Une maquette de laboratoire a également permis d’identifier des paramètres en milieu saturé et non saturé. La dernière partie de thèse est consacrée au calcul des quantités énergétiques récupérables pendant la période estivale à l’aide des données de la réglEmentation thermique RT2012. Elles sont comparées aux quantités énergétiques de chauffage nécessaires pendant la période hivernale en s’appuyant sur des données de la RT2012 et des données de la Direction Interdépartementale des Routes Massif (DIR MC) ; l’objectif final étant de déterminer les performances énergétiques du système.
