Thermal energy harvesting across pavement structure, Transportation Research Board (TRB), Annual Meeting ,
DOI : 10.1109/energytech.2012.6304703
Modeling snow melting on heated pavement surfaces. Part I: Model development, Applied Thermal Engineering, vol.27, issue.5-6, pp.1115-1124, 2007. ,
DOI : 10.1016/j.applthermaleng.2006.06.017
Thermophusical optimization of asphalt paving materials, Transportation Research Board (TRB), Annual Meeting, 2011. ,
Experimental study of slab solar collection on the hydronic system of road, Solar Energy, vol.84, issue.12, pp.2096-2102, 2010. ,
DOI : 10.1016/j.solener.2010.09.008
Development and testing of a heat and mass coupled snow melting model for hydronic heated pavement, Transportation Research Board (TRB), Annual Meeting ,
Harvesting energy from asphalt pavements and reducing the heat island effect, International Journal of Sustainable Engineering, vol.34, issue.3, pp.214-228, 2009. ,
DOI : 10.1080/15693430412331291698
Capturing solar energy from asphalt pavements, International ISAP Symposium on Asphalt Pavements and Environment, 2008. ,
A review on hydronic asphalt pavement for energy harvesting and snow melting, Renewable and Sustainable Energy Reviews, vol.48, 2015. ,
DOI : 10.1016/j.rser.2015.04.029
Interplay between phononic bandgaps and piezoelectric microstructures for energy harvesting, Journal of the Mechanics and Physics of Solids, vol.57, issue.3, pp.621-633, 2009. ,
DOI : 10.1016/j.jmps.2008.11.002
Thermoelectrics: a review of present and potential applications, Applied Thermal Engineering, vol.23, issue.8, pp.913-935, 2003. ,
DOI : 10.1016/S1359-4311(03)00012-7
Study on Application of PCM in Asphalt Mixture, Advanced Materials Research, vol.168, issue.170, pp.2625-2630, 2006. ,
DOI : 10.4028/www.scientific.net/AMR.168-170.2625
The use of phase change materials to delay pavement freezing, Transport Research Arena, 2010. ,
Research on snow melting and solar energy collection for thermal conductive asphalt pavement, 2011. ,
Estimating extreme values of thermal gradients in concrete structures, Mater Struct 2011, 2011. ,
DOI : 10.1617/s11527-011-9714-0
Laboratory investigation into thermal response of asphalt pavements as solar collector by application of small-scale slabs, Applied Thermal Engineering, vol.31, issue.10, pp.1582-1587, 2011. ,
DOI : 10.1016/j.applthermaleng.2011.01.028
Design tool for the thermal energy potential of asphalt pavements, Eighth International IBPSA, 2003. ,
Using Pavement as Solar Collector: Effect on Pavement Temperature and Structural Response, Transportation Research Record: Journal of the Transportation Research Board, vol.1778, 2001. ,
DOI : 10.3141/1778-17
Structural aspects of asphalt pavement heating and cooling systems, In: 3rd International Symposium on 3D Finite Element Modeling, 2002. ,
Underground thermal energy storage with heat pumps ? an international overview, IEA Heat Pump Centre Newsletter, 1998. ,
Large scale thermal energy storage, 2000. ,
Thermal energy storage?a review of concepts and systems for heating and cooling applications in buildings: Part 1?seasonal storage in the ground, HVACR Research, vol.18, pp.515-538, 2012. ,
Opération de recherche-Rapport bibliographie -Géothermie R2I : Chaussée chauffantes, 2015. ,
Central solar heating plants with seasonal storage in Germany, Solar Energy, vol.76, issue.1-3, pp.165-174, 2004. ,
DOI : 10.1016/j.solener.2003.07.025
Solar-Assisted District Heating Plants: Status of the German Programme Solarthermie-2000, Solar Energy, vol.69, issue.6, 2000. ,
DOI : 10.1016/S0038-092X(00)00125-0
German central solar heating plants with seasonal heat storage, Solar Energy, vol.84, issue.4, pp.612-623, 2010. ,
DOI : 10.1016/j.solener.2009.05.013
15 years of rd in central solar heating in denmark, In Sol Energy, 2000. ,
Experimental investigation of using ground source heat pump system for snow melting on pavements and bridge decks, Scientific Research and Essays, vol.24, pp.3955-3966, 2010. ,
Review of seasonal heat storage in large basins: Water tanks and gravel???water pits, Applied Energy, vol.87, issue.2, pp.390-397, 2010. ,
DOI : 10.1016/j.apenergy.2009.06.033
Seasonal thermal energy storage in germany, Proc.ISES Solar World Congress 2003, 2003. ,
Ground heat exchangers???A review of systems, models and applications, Renewable Energy, vol.32, issue.15, pp.2461-2478, 2007. ,
DOI : 10.1016/j.renene.2006.12.014
Master's Thesis within Sustainable Energy Systems and Structural Engineering Building Performance Design, Asphalt Solar Collector and Borehole Storage Design study for a small residential building area, 2010. ,
Geothermal (ground-source) heat pumps, A world overview, 2004. ,
Study of critical free-area ratio during the snow-melting process on pavement using low-temperature heating fluids. Energy Conversion and Management, pp.157-165, 2009. ,
Conductive concrete overlay for bridge deck deicing: mixture proportioning, optimization, and properties, ACI Materials Journal, vol.97, pp.172-181, 2000. ,
Snow melting and heating systems based on geothermal heat pumps at goleniow airport poland, Geothermal Training Program, vol.2, pp.431-464, 2002. ,
Snoe free-heated pavement system to eliminate ice runways, SAE Technical paper Series, 2003. ,
DOI : 10.4271/2003-01-2145
Heated bridge technology: Report on istea sec, 6005 Program, 1999. ,
Bridge deck deicing using geothermal heat pumps, Proceedings of the 4th International Heat Pumps in Cold Climated Conference, 2000. ,
Pavement snow melting, In Geo-Heat Center Quarterly Bulletin, 1999. ,
Operational characteristics of the gaia snow-melting system in ninohe, iwate, japan, Proc. World Geothermal Congress, 2000. ,
Snow-melting on sidewalks with ground-coupled heat pumps in a heavy snowfall city, Proc. World Geothermal Congress 2005, 2005. ,
Harnessing solar energy for winter road clearing on heavily loaded expressways, Proc. XIth PIARC International Winter Road Congress, 2002. ,
Pavement snow melting ,
Modeling snow melting on heated pavement surfaces. Part II: Experimental validation, Applied Thermal Engineering, vol.27, issue.5-6, pp.1125-1131, 2011. ,
DOI : 10.1016/j.applthermaleng.2006.07.029
Raodway power system. In Technical Analysis for Thermal Energy Generation, 2008. ,
Down-hole coaxial heat exchanger using insulated inner pipe for maximum heat extraction, GRC Transactions, vol.9, pp.45-49, 1985. ,
Development of the downhole coaxial heat exchanger system : Potential for fully utilizing geothermal resources, GRC Bulletin, vol.24, pp.83-92, 1995. ,
Road and bridge heating using geothermal energy. overview and examples, Proceedings European Geothermal Congress, 2007. ,
Bridgesim: outil de simulation pour le dégivrage de pont par énergie solaire, SUPSI Instory (SUPSI INSTitutional repositORY), 2008. ,
Calculation of maximum pavement temperatures from weather reports, Highway Research Board Bulletin, vol.168, pp.1-8, 1957. ,
Predicting maximum pavement surface temperature using maximum air temperature and hourly solar radiation, Transportation Research board, vol.15, pp.1-11, 1993. ,
Mathematical model for paved surface summer and winter temperature: comparison of calculated and measured temperatures. Cold Region Science and Technology, pp.1-17, 2004. ,
Temperature distribution within asphalt pavements and its relationship to pavement deflection, In Transportation Research Record National Research Council, vol.291, 1969. ,
Assessment of temperature fluctuations in asphalt pavement due to thermal environmental conditions using a two-dimensional, transient finite-difference approach, Mountain Planes Consortium Report, 2002. ,
Assessment of temperature fluctuations in asphalt pavement due to thermal environmental conditions using a two-dimensional, transient finite-difference approach, In J Mater Civil Eng, 2005. ,
Simulation Model for Calculating Pavement Temperatures Including Maximum Temperature, Transportation Research Record: Journal of the Transportation Research Board, vol.1699, pp.34-41, 2000. ,
DOI : 10.3141/1699-19
Predicting Asphalt Pavement Temperature with a Three-Dimensional Finite Element Method, Transportation Research Record: Journal of the Transportation Research Board, vol.1919, pp.96-110, 1919. ,
DOI : 10.3141/1919-11
URL : http://repositorium.sdum.uminho.pt/bitstream/1822/7153/1/JP%20TTANSP%20RESEARCH%20RECORD.pdf
Modeling Pavement Temperature for Use in Binder Oxidation Models and Pavement Performance Prediction, Journal of Materials in Civil Engineering, vol.23, issue.4, pp.351-359, 2011. ,
DOI : 10.1061/(ASCE)MT.1943-5533.0000169
Influence of the Thermophysical Properties of Pavement Materials on the Evolution of Temperature Depth Profiles in Different Climatic Regions, Journal of Materials in Civil Engineering, vol.24, issue.1, pp.32-47, 2012. ,
DOI : 10.1061/(ASCE)MT.1943-5533.0000357
Asphalt solar collectors: A literature review, Applied Energy, vol.102, pp.962-970, 2013. ,
DOI : 10.1016/j.apenergy.2012.08.050
URL : http://hdl.handle.net/10902/7771
Harvesting heat energy from asphalt pavements: development of and comparison between numerical models and experiment, International Journal of Sustainable Engineering, vol.78, issue.2, pp.159-169, 2011. ,
DOI : 10.1080/19397038.2010.550336
New Measurement of Thermal Properties of Superpave Asphalt Concrete, Journal of Materials in Civil Engineering, vol.17, issue.1, pp.72-79, 2005. ,
DOI : 10.1061/(ASCE)0899-1561(2005)17:1(72)
The use of a ground solar collector for swimming pool heating, Proceedings ISES Congress, pp.632-636, 1981. ,
Performance studies on solar concrete collectors, Solar Energy, vol.42, issue.1, pp.45-56, 1989. ,
DOI : 10.1016/0038-092X(89)90129-1
DEVELOPMENT AND TESTING OF CONCRETE SOLAR COLLECTORS, International Journal of Solar Energy, vol.104, issue.1, pp.27-40, 1994. ,
DOI : 10.1016/0038-092X(79)90139-7
Experimental investigation of ice and snow melting process on pavement utilizing geothermal tail water. Energy Conversion and Management, pp.1538-1546, 2008. ,
Laboratory study on solar collector of thermal conductive asphalt concrete, International Journal of pavement Research and Technology, vol.2, pp.130-136, 2009. ,
Transient analysis of snow-melting system performance, pp.403-409, 2002. ,
Numerical simulation on the thermal response of heat-conducting asphalt pavements, Physica Scripta, vol.139, pp.70-83, 2010. ,
DOI : 10.1088/0031-8949/2010/T139/014041
Effects of conductive fillers on temperature distribution of asphalt pavements, Physica Scripta, pp.21-35, 2010. ,
Numerical and Experimental Validation of Full-Depth Asphalt Slab Using Capturing Solar Energy, 2010 4th International Conference on Bioinformatics and Biomedical Engineering, 2010. ,
DOI : 10.1109/ICBBE.2010.5517215
Reduction of urban heat island effect through harvest of heat energy from asphalt pave- ments, 2008. ,
Study of ice and snow melting process on conductive asphalt solar collector, Solar Energy Materials and Solar Cells, vol.95, issue.12, pp.3241-3250, 2011. ,
DOI : 10.1016/j.solmat.2011.07.013
Analysis on optimization design and viscoelastic response of conductive asphalt pavement using snowmelt, 2010. ,
Conception d'un système pour la récupération de l'énergie thermique des chaussées : Projet d'Initiation à la Recherche et Développement, pp.2010-2011 ,
Modeling Hydronic Solar Collection on Slab of Road and Bridge and a Feature Study, 2009 International Conference on Energy and Environment Technology, 2009. ,
DOI : 10.1109/ICEET.2009.184
Effect mechanism of mixing on improving conductivity of asphalt solar collector, International Journal of Heat and Mass Transfer, vol.75, pp.650-655, 2014. ,
DOI : 10.1016/j.ijheatmasstransfer.2014.04.014
Effectiveness of pavement-solar energy system ??? An experimental study, Applied Energy, vol.138, pp.1-10, 2015. ,
DOI : 10.1016/j.apenergy.2014.10.045
Modeling of hydronic and electric-cable snow melting systems for pavements and bridge decks, 2002. ,
Thermal and hydraulic analysis of multilayered asphalt pavements as active solar collectors, Applied Energy, vol.111, pp.324-332, 2013. ,
DOI : 10.1016/j.apenergy.2013.05.013
Application of a porous interlayer for road temperature control, XIV International Winter Road Congress, Institute for road and traffic engineering, 2014. ,
Méthodes numériques pour les ecoulements souterrains et couplage avec le ruissellement, Ecole Nationale des Ponts et Chaussées, 2008. ,
Déterminations Théoriques et Expérimentale des Coefficients de Diffusion et de Thermodiffusion en Milieu Poreux, 2010. ,
Institut nationnal des sciences appliquées de toulouse, Département de sciences et technologies pour l'ingénieur, 2005. ,
Les fontaines publiques de la ville de Dijon, V. Dalmont, p.1856 ,
The Finite Element Method in Heat Transfer and Fluid Dynamics, 2010. ,
Finite Differences Methods in Heat Transfer, Boca Raton, 1994. ,
The Numerical Solution of One-Dimensional Phase Change Problems Using an Adaptive Moving Mesh Method, Journal of Computational Physics, vol.161, issue.2, pp.537-557, 2000. ,
DOI : 10.1006/jcph.2000.6511
A Simple and Effective Self-adaptive Moving Mesh for Enthalpy Formulations of Phase Change Problems, IMA Journal of Numerical Analysis, vol.11, issue.1, pp.55-78, 1991. ,
DOI : 10.1093/imanum/11.1.55
An explicit, adaptive grid algorithm for one-dimensional initial value problems, Applied Numerical Mathematics, vol.26, issue.1-2, pp.3-12, 1997. ,
DOI : 10.1016/S0168-9274(97)00076-7
Global Sensitivity Analysis: The Primer, 2008. ,
DOI : 10.1002/9780470725184
Sensitivity estimates for nonlinear mathematical models, Mathematical Modelling and Computational Experiments, 1993. ,
The role of sensitivity analysis in the corroboration of models and its link to model structural and parametric uncertainty, Reliability Engineering and System Safety, 1977. ,
Sensitivity analysis, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00386559
Sensitivity analysis as an ingredient of modeling. statistical science, Statistical Science, 2000. ,
On the Relative Importance of Input Factors in Mathematical Models, Journal of the American Statistical Association, vol.97, issue.459, pp.702-709, 2002. ,
DOI : 10.1198/016214502388618447
Induction healing of porous asphalt concrete, Master of Science in Materials Science Wuhan University of Technology, U.S. Army Engineer Research and Development Center (ERDC) Construction Engineering Research Laboratory (CERL): ASPRS 2006 Annual Conference, 2012. ,
Classifying infrastructure using thermal ir signatures, Proceedings European geothermal Congress 2007, U.S. Army Engineer Research and Development Center (ERDC) Construction Engineering Research Laboratory (CERL): AS- PRS 2006 Annual Conference, 2006. ,
Performance hygrothermique des bâtiments -Calcul et présentation des données climatiques -Partie 4 : données horaires pour l'évaluation du besoin énergétique annuel de chauffage et de refroidissement, 2006. ,
Hydrothermal study of roads with de-freezing surface, obtained by the circulation of a warm uid in a bonding porous asphalt layer, RILEM Bookseries, vol.10, 2016. ,
rapport de stage M2: Instrumentation d'une chaussée pour un suivi thermique, 2013. ,
Understanding pavement-surface energy balance and its implications on cool pavement development, Energy and Buildings, vol.85, pp.389-399, 2014. ,
Inverse Heat Transfer Problems, 2012. ,
DOI : 10.1007/978-3-642-76436-3
Parameter Estimation in Engineerin and science. Wiley series in probability and mathematical statistics, 1977. ,
A three-dimensional inverse heat conduction problem in estimating surface heat flux by conjugate gradient method, International Journal of Heat and Mass Transfer, vol.42, issue.18, pp.3387-3403, 1999. ,
DOI : 10.1016/S0017-9310(99)00020-4
Hydrothermal modeling of porous pavement for its surface de-freezing, Applied Thermal Engineering, vol.107, pp.493-500, 2016. ,
DOI : 10.1016/j.applthermaleng.2016.06.138
Fabac accelerated loading test of bond between cement overlay and asphalt layers, in pavement cracking, pp.671-681, 2008. ,
