Etude expérimentale et modélisation par approche radiative d'un photoréacteur pour la production d'hydrogène - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Experimental study and radiative approach modeling of a photoreactor for hydrogen production
Ghiles Dahi
  • Fonction : Auteur
  • PersonId : 781991
  • IdRef : 200260146
To address the energy challenge of the 21 st century, a solution is the development of solar processes for the production of energy vectors by artificial photosynthesis, in particular photocatalytic synthesis of solar fuels. However high kinetic and thermodynamic performances for these processes must be reached, this requires the development of tools for optimal design, including predictive knowledge models addressing radiative transfer that is the controlling physical process at different scales. A predictive multi-scale model has therefore been developed, implemented and validated on a simple reaction for hydrogen photo-production from CdS particle slurry.On the basis of their characteristics (size, shape, etc.) and their optical properties, the radiative properties of the particles, namely absorption and scattering cross sections and phase function, were calculated using the Lorenz-Mie theory and validated by measurements of transmittances on a high accuracy optical bench. These parameters were then used as input parameters to solve rigorously the radiative transfer equation with the Monte Carlo method. The agreement between predicted and experimental transmittance, taking into account light scattering by hydrogen bubbles, is good in the absorbed spectral band.In parallel, the use of complete experimental bench centered on a small photoreactor, where incident flux densities have been validated by actinometry, yielded high accuracy hydrogen photo-production results. A first and original model of thermokinetic coupling was then formulated and validated after identification of a single lumped parameter whose reification will be approached later and used predictively with success.This work opens up a large number of research prospects because it makes possible to transpose the predictive chain to artificial photosynthesis. This work provides also guidance on the kinetic and thermodynamic optimization of photo-processes producing solar fuels.
Pour relever le défi énergétique du 21 ième siècle, une solution consiste à mettre au point des procédés solaires de production de vecteurs énergétiques par photosynthèse artificielle permettant la synthèse photo-catalytique de carburants solaires. L’obtention de performances cinétiques et énergétiques élevées pour ces procédés nécessite le développement d’outils de conception optimale tels des modèles de connaissance robustes et prédictifs considérant le transfert de rayonnement comme processus physique contrôlant le procédé à plusieurs échelles. Une chaine prédictive de modélisation, avec ses différents maillons, a donc été développée, mise en œuvre et validée sur une réaction modèle de photo-production d’hydrogène à partir d’une suspension de particules de CdS.Ainsi, à partir de leurs caractéristiques (taille, forme...) et de leurs propriétés optiques, les propriétés radiatives des particules, à savoir sections efficaces d’absorption, de diffusion et fonction de phase ont été calculées au moyen de la théorie de Lorenz-Mie et validées par des mesures de transmission sur un banc optique de précision. Ces paramètres ont ensuite été utilisés comme données d’entrée pour la résolution de l’équation de transfert radiatif, effectuée au moyen de la méthode de Monte Carlo. L’accord entre transmissions prédite et expérimentale, tenant compte éventuellement de la diffusion du rayonnement par les bulles d’hydrogène, est bon dans la bande spectrale absorbée.En parallèle, l’utilisation d’un équipement complet et d’une chaine d’acquisition de mesures autour d’un petit photoréacteur d’étude, pour lequel les densités de flux incidentes ont été validées par actinométrie, a permis d’obtenir des résultats expérimentaux de haute précision en photo-production d’hydrogène. Un premier modèle de couplage thermocinétique original a alors été formulé, validé après identification d’un seul paramètre agrégé, dont la réification sera abordée ultérieurement, et utilisé de façon prédictive avec succès.Ce travail ouvre de très nombreuses perspectives de recherche, il a ainsi permis de vérifier la possible transposition à la photosynthèse artificielle de la chaine prédictive de modélisation multi-échelles et donne des pistes quant à l’optimisation cinétique et énergétique des photo-procédés produisant des carburants solaires.
DAHI_2016CLF22782.pdf (2.65 Mo) Télécharger le fichier
tel-01511967 , version 1 (21-04-2017)
  • HAL Id : tel-01511967 , version 1
Ghiles Dahi. Etude expérimentale et modélisation par approche radiative d'un photoréacteur pour la production d'hydrogène. Autre. Université Blaise Pascal - Clermont-Ferrand II, 2016. Français. ⟨NNT : 2016CLF22782⟩. ⟨tel-01511967⟩
645 Consultations
813 Téléchargements
