Simulation of a large-scale airlift pump taking into account uncertainties. Application to the optimization of a new urban geothermal system
Simulation en présence d'incertitude d'un gazosiphon de grande échelle. Application à l'optimisation d'un nouveau système géothermique urbain
This PhD thesis is part of the ANR project « Uncertain Flow Optimization » (UFO). The project is devoted to the development and application of efficient uncertainty quantification methods for flow analysis and optimization. In this framework, these methods are applied to the study of a large-scale airlift pump. The airlift pump is selected to be part of an innovative geothermal system, which can be exploited within an urban environment. We wish to quantify and optimize the energy potential of this new system with numerical tools. They provide both good accuracy and efficiency properties. The airlift two-phase flow simulation is based on a quasi one-dimensional drift flux model, which is implicitly solved. The solver is validated by comparison with relevant experimental airlift studies from the literature. However, these studies remain below the kilometric-targeted pipe length. Thanks to the analysis of two uncertainty quantification methods, a non-intrusive approach relying on polynomial chaos expansion and a new semi-intrusive method developed ahead of the UFO project, we perform airlift pump simulations taking into account physical and modelling uncertainties. This numerical tool is inserted into a simplified model of the complete urban geothermal system that involves surface devices, such as an air compressor. Finally, a robust preliminary optimization process is performed for two versions of the proposed geothermal urban system. They are designed respectively for heat recovery and electricity production.
Cette thèse s’inscrit dans le cadre du projet ANR « Uncertain flow optimization » (UFO) consacré au développement et à l’application de méthodes efficaces de quantification d’incertitudes pour l’analyse et l’optimisation d’écoulements. Dans ce contexte, ces méthodes sont appliquées à des gazosiphons de grande échelle utilisés comme pompe. Plus particulièrement, on s’intéresse à de tels gazosiphons choisis pour constituer l’organe central d’un système géothermique innovant, compatible avec un environnement urbain. On souhaite en quantifier le potentiel énergétique par voie numérique avec la recherche d’un compromis entre justesse des résultats et efficacité optimale. La simulation de l’écoulement diphasique produit dans le gazosiphon est fondée sur un modèle quasi-1D à flux de dérive et s’appuie sur une démarche de résolution implicite. Les résultats sont validés sur les études expérimentales les plus pertinents de la littérature, dont aucune toutefois n’atteint les longueurs requises de l'ordre du kilomètre. Le code de simulation du gazosiphon fait ensuite l’objet d’une démarche de prise en compte d’incertitudes physiques et de modélisation, précédée par une analyse de deux méthodes de quantification d’incertitude : une méthode non-intrusive de type chaos polynomial, et une méthode plus récente dite semi-intrusive qui fut développée en amont du projet UFO. Cet outil est intégré dans une modélisation simplifiée du système géothermique urbain dans son ensemble impliquant les composants en surface, notamment le compresseur d'air. Il en résulte une optimisation énergétique robuste préliminaire de deux variantes du système géothermique urbain proposé, respectivement de récupération de chaleur et de production d’électricité.
