Synthesis of hybrid asymetric nanoparticles and study of their compatibilizing effect in polymer blends
Synthèse de nanoparticules hybrides asymétriques et étude de leur effet compatibilisant dans des mélanges de polymères
Polymers materials usually named « plastics » are widely present in our daily life. Their intrinsic properties often need to be improved in order to respect regulations, standards and others specifications governing their commercial use. Thus, two main strategies are used. The first one consists in incorporating solid fillers to improve some mechanical properties. The second one is based on the mixing of two polymers with specific characteristics to obtain a new material combining the properties of the two initial polymers used. The main goal of this work is to synthesize nanoparticles able to combine the both strategies presented before. To do this, a protocol of synthesis by miniemulsion based on an intern phase separation process was employed and hybrid asymmetric nanoparticles were obtained. These hybrid asymmetric nanoparticles correspond to a silica core (around 50 nanometers diameter) with only one hemisphere grafted by polystyrene (PS) chains resulting in a PS nodule (around 80 nanometers diameter). Then, these asymmetric silica/PS nanoparticles were incorporated into a polystyrene/polyamide-6 (PS/PA6) blend and their migration to the matrix/nodule interface was highlighted by scanning electron microscope (SEM). Experimental and theoretical investigations were focus on the phenomena involved in this migration. To evaluate the compatibilizing effect of silica/PS nanoparticles, several PS/PA6 nanocomposites with various contents of nanoparticles were prepared. A significant decrease of PA6 nodules size as function of nanoparticles concentration was observed by SEM and diffraction particle size analyzer which prove an emulsifying effect for silica/PS nanoparticles. Finally, the rheological tests at the melted state combined with an adjusted Palierne model method, show a decrease of the apparent interfacial tension of the blend as function of the silica/PS nanoparticles content.
Les matériaux polymères appelés communément "Plastiques" sont très présents dans notre vie quotidienne. Leurs propriétés intrinsèques nécessitent souvent d'être améliorées pour répondre aux normes et autres cahiers des charges régissant leur utilisation. Ainsi, deux grandes stratégies sont aujourd'hui utilisées. La première consiste à incorporer des renforts (exemple de la fibre de verre) pour augmenter certaines propriétés mécaniques. La seconde consiste à mélanger deux polymères distincts possédant chacun des caractéristiques spécifiques pour obtenir un matériau combinant les propriétés des deux polymères de base, Il s'agit alors de "compatibilisation". L'objectif de ce travail de thèse est de fabriquer des nanoparticules capables de combiner les notions de renfort et de compatibilisation précédemment évoquées. Pour ce faire, une stratégie de synthèse en miniémulsion reposant sur un phénomène de séparation interne de phase a permis de produire des nanoparticules hybrides asymétriques. Ces dernières sont formées d'un cœur de silice d'environ 50 nanomètres de diamètre dont l'un des hémisphères seulement a été greffé par des chaînes de polystyrène (PS) formant un nodule d'environ 80 nanomètres de diamètre. Ces nanoparticules asymétriques silice/PS ont ensuite été introduites dans un mélange de polystyrène et de polyamide-6 (PS/PA6). La migration des nanoparticules silice/PS à l'interface de ce mélange a été vérifiée par microscopie électronique à balayage (MEB). Les phénomènes mis en jeu dans cette migration ont été étudiés de façon approfondie via une étude modèle. Des nanocomposites PS/PA6 comportant différents taux de charges de nanoparticules asymétriques ont été réalisés pour vérifier l'effet compatibilisant de ces dernières. Ainsi, une nette diminution des tailles des phases dispersées de PA6 a pu être mise en évidence par MEB et par granulométrie à diffraction laser correspondant à un effet émulsifiant. Enfin, des essais rhéologiques à l'état fondu qui finalisent cette étude et ont permis de montrer via l'utilisation d'un modèle de Palierne ajusté, une diminution de la tension interfaciale apparente du mélange liée au taux de charges en nanoparticules silice/PS.
