ANALYSE DES DEFORMATIONS ACTUELLES DANS LE RIF (MAROC) : APPROCHE MORPHOTECTONIQUE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Analysis of the present-day deformation of the Rif Mountain (Morocco) : Morphotectonics Approach
Antoine Poujol
  • Fonction : Auteur
  • PersonId : 968011
In order to identify and quantify the Rif (Morocco) present-day deformation, especially those related to active faults (location, geometry, kinematic), we perform a morphotectonic study. The studied area and faults are located in the Northern part (conjugate faults of Al-Hoceima Bay: Trougout, Boujibar and Rouadi), the Eastern part (Nekor fault) and the Southern part of the chain (Rif frontal thrust between Fes and Meknes cities). Morphotectonic tools (DEMs at different scales, satellite and aerial pictures), field studies and Quaternary dating methods (U/Th, OSL, 14C and in-situ cosmogenic isotopes 10Be, 3He, 36Cl) allow us to characterize transtensional deformation in the Northern Rif. Horizontal and vertical slip rates along the N-S-oriented Trougout major fault are ~1.6 mm/yr and ~2 mm/yr respectively. In the Southern part, the Rif frontal thrust shows a shortening rate of ~1.8 mm/yr into Fes and Meknes area. In the Eastern part, the deformation is focused on the Nekor left-lateral strike-slip major fault with ~1.5 mm/yr. Incision features and raised marine terraces involve an uplift of the chain about ~0.2 mm/yr. The overall deformation in the Rif seems to be continuous since the Messinian-Pliocene time. These new morphotectonic constraints are consistent with the GPS measurements showing southwestward overall motion of most of the Rif belt with respect to stable Africa, associated to clockwise rotation. Finally, we propose a geodynamic model in which the Rif, the Alboran sea and the Betics belong to a single microplate bounded by the strike-slip faults of the Betics on the North, the Rif frontal thrust on the South, the Nekor and TASZ (Trans Alboran Shear Zone) strike-slip faults on the East and North-East, and the western Rif folded structures on the West.
L'objectif de cette étude est d'identifier et de quantifier les déformations actuelles dans la chaine du Rif (Maroc), notamment celles associées aux failles actives (localisation, géométrie, cinématique). Pour ce faire, nous mettons en œuvre pour la première fois dans cette région, une approche morphotectonique. Les sites et failles sélectionnés et étudiés se situent dans la partie Nord (les failles conjuguées de la baie d'Al-Hoceima: Trougout, Boujibar et Rouadi), l'Est (la faille de Nékor) et le Sud (front chevauchant sud rifain entre Fes et Meknes). A partir des outils de la morphotectonique (MNTs à différentes résolutions, images satellitaires, photographies aériennes), d'analyses de terrain et grâce aux méthodes de datation du Quaternaire (U/Th, OSL, 14C et isotopes cosmogéniques produits in-situ 10Be, 3He, 36Cl), cette étude met en évidence et quantifie une déformation transtensive dans la partie Nord de la chaine. Les vitesses de glissement horizontales et verticales le long de la faille principale d’orientation méridienne de Trougout sont de ~1.6 mm/an et ~2 mm/an, respectivement. Dans la partie Sud, nous montrons que le front rifain entre Fez et Meknes est actif avec une vitesse de raccourcissement de ~1.8 mm/an. La déformation dans la région Est se localise principalement sur la faille du Nékor avec une vitesse décrochante senestre de ~1.5 mm/an. Par ailleurs, la présence de nombreuses figures d'incision et de surfaces marines soulevées au niveau du littoral Nord témoignent d'une surrection généralisée de la chaine de l'ordre de ~0.2 mm/an. L'ensemble de cette déformation semble être constante depuis la période du Messino-Pliocène. Ces résultats sont cohérents avec les données GPS qui montrent un déplacement de ~5mm/an vers le SW de l’ensemble du Rif associé à un mouvement rotatif horaire, dans le référentiel Afrique stable. D’un point de vue géodynamique, nous proposons que le Rif, la mer d'Alboran et les Bétiques appartiennent à une même microplaque limitée au Nord par les failles décrochantes des Bétiques, au Sud par le chevauchement rifain, à l'Est et au Nord-Est par les failles décrochantes de Nékor et de la TASZ (Trans Alboran Shear Zone) et à l'Ouest par les structures plissées bordières du Rif.
Thèse_Antoine-Poujol.pdf (163.54 Mo) Télécharger le fichier
tel-01170466 , version 1 (01-07-2015)
  • HAL Id : tel-01170466 , version 1
Antoine Poujol. ANALYSE DES DEFORMATIONS ACTUELLES DANS LE RIF (MAROC) : APPROCHE MORPHOTECTONIQUE. Tectonique. Université Montpellier 2, 2014. Français. ⟨NNT : ⟩. ⟨tel-01170466⟩
Collections
AGROPOLIS
1447 Consultations
4007 Téléchargements
