Design and Evaluation of Cloud Network Optimization Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Optimisation des réseaux virtuels : conception et évaluation
Dallal Belabed
  • Fonction : Auteur
This dissertation tries to give a deep understanding of the impact of the new Cloud paradigms regarding to the Traffic Engineering goal, to the Energy Efficiency goal, to the fairness in the endpoints offered throughput, and of the new opportunities given by virtualized network functions.In the first part of our dissertation we investigate the impact of these novel features in Data Center Network optimization, providing a formal comprehensive mathematical formulation on virtual machine placement and a metaheuristic for its resolution. We show in particular how virtual bridging and multipath forwarding impact common DCN optimization goals, Traffic Engineering and Energy Efficiency, assess their utility in the various cases in four different DCN topologies.In the second part of the dissertation our interest move into better understand the impact of novel attened and modular DCN architectures on congestion control protocols, and vice-versa. In fact, one of the major concerns in congestion control being the fairness in the offered throughput, the impact of the additional path diversity, brought by the novel DCN architectures and protocols, on the throughput of individual endpoints and aggregation points is unclear.Finally, in the third part we did a preliminary work on the new Network Function Virtualization paradigm. In this part we provide a linear programming formulation of the problem based on virtual network function chain routing problem in a carrier network. The goal of our formulation is to find the best route in a carrier network where customer demands have to pass through a number of NFV node, taking into consideration the unique constraints set by NFV.
Le but de cette thèse est de tenté de donner une meilleure compréhension des nouveaux paradigmes de l'informatique en Nuage. En ce qui concerne l'Ingénierie du Trafic, l'économie d'énergie, de l'équité dans le partage du débit.Dans la première partie de note thèse, nous étudions l'impact de ces nouvelles techniques dans les réseaux de Data Center, nous avons formulé notre problème en un modèle d'optimisation, et nous le résolvons en utilisons un algorithme glouton. Nous avons étudié l'impact des ponts virtuels et du multi chemin sur différentes architectures de Data Centers. Nous avons en particulier étudié l’impact de la virtualisation des switches et l’utilisation du multi-chemin sur les différents objectifs d'optimisation tels que l'Ingénierie du Trafic, l'économie d'énergie.Dans notre seconde partie, nous avons essayé d’avoir une meilleure compréhension de l'impact des nouvelles architectures sur le contrôle de congestion, et vice versa. En effet, l'une des préoccupations majeures du contrôle de congestion est l'équité en terme de débit, l'impact apporté par le multi-chemin, les nouvelles architectures Data Center et les nouveaux protocoles, sur le débit des points terminaux et des points d'agrégations reste vague.Enfin, dans la troisième partie nous avons fait un travail préliminaire sur le nouveau paradigme introduit par la possibilité de virtualisé les Fonctions Réseaux. Dans cette partie, nous avons formulé le problème en un modèle linéaire, dans le but est de trouver le meilleur itinéraire à travers le réseau où les demandes des clients doivent passer par un certain nombre de NFV.
2015PA066149o.pdf (3.83 Mo) Télécharger le fichier
tel-01514276 , version 1 (26-04-2017)
  • HAL Id : tel-01514276 , version 1
Dallal Belabed. Design and Evaluation of Cloud Network Optimization Algorithms. Other [cs.OH]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066149⟩. ⟨tel-01514276⟩
336 Consultations
330 Téléchargements
