Zoltan: Parallel partitioning, load balancing and data-management services . http://www.cs.sandia.gov/Zoltan, Zoltan.html, issue.1 ,
Open-palm: an open source dynamic parallel coupler, IV International Conference on Computational Methods for Coupled Problems in Science and Engineering, 2011. ,
Coupling LES, radiation and structure in gas turbine simulations, Proceedings of the Summer Program, 2010. ,
High Performance Multiscale Simulation or Crack Propagation, 2006 International Conference on Parallel Processing Workshops (ICPPW'06), p.480, 2006. ,
DOI : 10.1109/ICPPW.2006.39
Adaptive decomposition and remapping algorithms for object-space-parallel direct volume rendering of unstructured grids, Journal of Parallel and Distributed Computing, vol.67, issue.1, pp.77-99, 2007. ,
DOI : 10.1016/j.jpdc.2006.05.005
Multi-level direct K-way hypergraph partitioning with multiple constraints and fixed vertices, Journal of Parallel and Distributed Computing, vol.68, issue.5, pp.609-625, 2008. ,
DOI : 10.1016/j.jpdc.2007.09.006
URL : https://hal.archives-ouvertes.fr/hal-00803479
Benchmarking for graph clustering and partitioning, Encyclopedia of Social Network Analysis and Mining, pp.73-82 ,
Differential greedy for the 0???1 equicut
problem, Proceedings of the DIMACS Workshop on Network Design: Connectivity and Facilities Location, pp.3-21, 1997. ,
DOI : 10.1090/dimacs/040/02
A Partitioning Strategy for Nonuniform Problems on Multiprocessors, IEEE Transactions on Computers, vol.36, issue.5, pp.570-580, 1987. ,
DOI : 10.1109/TC.1987.1676942
On the sensitivity of a helicopter combustor wall temperature to convective and radiative thermal loads, Applied Thermal Engineering, vol.103, issue.Complete, pp.1450-1459, 2016. ,
DOI : 10.1016/j.applthermaleng.2016.04.054
Mesh refinement in direct transcription methods for optimal control, Optimal Control Applications and Methods, vol.10, issue.1, pp.1-21, 1998. ,
DOI : 10.1002/(SICI)1099-1514(199801/02)19:1<1::AID-OCA616>3.0.CO;2-Q
Practical Methods for Optimal Control and Estimation Using Nonlinear Programming, 2009. ,
DOI : 10.1137/1.9780898718577
The ncar climate system model, version one*, Journal of Climate, vol.11, issue.6, pp.1115-1130, 1998. ,
A heuristic for reducing fill-in in sparse matrix factorization, PPSC, pp.445-452, 1993. ,
Parallel breadth-first search on distributed memory systems, Proceedings of 2011 International Conference for High Performance Computing, Networking, Storage and Analysis, pp.1-65, 2011. ,
Hypergraph partitioning for VLSI CAD, Proceedings of the 36th ACM/IEEE conference on Design automation conference , DAC '99, pp.349-354, 1999. ,
DOI : 10.1145/309847.309955
Dynamic octree load balancing using spacefilling curves, 2003. ,
Hypergraph-based Dynamic Load Balancing for Adaptive Scientific Computations, 2007 IEEE International Parallel and Distributed Processing Symposium, pp.1-11, 2007. ,
DOI : 10.1109/IPDPS.2007.370258
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.130.5756
Hypergraph-partitioning-based decomposition for parallel sparse-matrix vector multiplication, IEEE Transactions on Parallel and Distributed Systems, vol.10, issue.7, pp.673-693, 1999. ,
DOI : 10.1109/71.780863
A repartitioning hypergraph model for dynamic load balancing, J. Parallel Distrib. Comput, vol.69, issue.8, pp.711-724, 2009. ,
On the validity of a front-oriented approach to partitioning large sparse graphs with a connectivity constraint, Numerical Algorithms, vol.12, issue.1, pp.193-214, 1996. ,
A new flexible coupler for earth system modeling developed for ccsm4 and cesm1, International Journal of High Performance Computing Applications, vol.26, issue.28, pp.31-42, 2012. ,
Dynamic load balancing for distributed memory multiprocessors, Journal of Parallel and Distributed Computing, vol.7, issue.2, pp.279-301, 1989. ,
DOI : 10.1016/0743-7315(89)90021-X
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.307.2377
Computational performance of ultra-high-resolution capability in the Community Earth System Model, International Journal of High Performance Computing Applications, vol.26, issue.1, pp.5-16, 2012. ,
DOI : 10.1177/1094342012436965
Shape-optimized mesh partitioning and load balancing for parallel adaptive FEM, Parallel Computing, vol.26, issue.12, pp.1555-1581, 2000. ,
DOI : 10.1016/S0167-8191(00)00043-0
Analysis of high performance conjugate heat transfer with the OpenPALM coupler, V International Conference on Coupled Problems in Science and Engineering, 2013. ,
DOI : 10.1088/1749-4699/8/1/015003
A procedure for placement of standard-cell VLSI circuits, IEEE Trans. on CAD of Integrated Circuits and Systems, vol.4, issue.1, pp.92-98, 1985. ,
A simple and efficient automatic fem domain decomposer, Computers & Structures, vol.28, issue.5, pp.579-602, 1988. ,
DOI : 10.1016/0045-7949(88)90004-1
A linear-time heuristic for improving network partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
Computers and Intractibility: A Guide to the Theory of NP-Completeness, 1979. ,
Dynamic load balancing in computational mechanics, Computer Methods in Applied Mechanics and Engineering, vol.184, issue.2-4, pp.485-500, 2000. ,
DOI : 10.1016/S0045-7825(99)00241-8
Graph partitioning models for parallel computing, Parallel Computing, vol.26, issue.12, pp.1519-1534, 2000. ,
DOI : 10.1016/S0167-8191(00)00048-X
An improved spectral graph partitioning algorithm for mapping parallel computations, SIAM J. Sci. Comput, vol.16, issue.2 10, 1995. ,
Coupling les, radiation and structure in gas turbine simulation, Proceedings of the Summer Program Center for Turbulence Research, p.97, 2019. ,
Greedy algorithms for kway graph partitioning, the 6th international conference on advanced computing, 1998. ,
Comparisons of coupling strategies for massively parallel conjugate heat transfer with large eddy simulation, IV International Conference on Computational Methods for Coupled Problems in Science and Engineering, p.71, 2011. ,
Mpcci -a tool for the simulation of coupled applications. Concurrency and Computation: Practice and Experience, pp.183-192, 2006. ,
Multilevel Algorithms for Multi-Constraint Graph Partitioning, Proceedings of the IEEE/ACM SC98 Conference, pp.1-13, 1998. ,
DOI : 10.1109/SC.1998.10018
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.138.6199
Parallel multilevel k-way partitioning scheme for irregular graphs, Proceedings of the 1996 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '96, pp.96-129, 1998. ,
DOI : 10.1145/369028.369103
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.133.6013
Multi-Constraint Mesh Partitioning for Contact/Impact Computations, Proceedings of the 2003 ACM/IEEE conference on Supercomputing, SC '03, pp.56-73, 2003. ,
DOI : 10.1145/1048935.1050206
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.8230
A Fast and High Quality Multilevel Scheme for Partitioning Irregular Graphs, SIAM Journal on Scientific Computing, vol.20, issue.1, pp.359-392, 1998. ,
DOI : 10.1137/S1064827595287997
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.106.4101
An Efficient Heuristic Procedure for Partitioning Graphs, Bell System Technical Journal, vol.49, issue.2, pp.291-307, 1970. ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
Wavefront diffusion and LMSR: Algorithms for dynamic repartitioning of adaptive meshes ,
The Hungarian method for the assignment problem, Naval Research Logistics Quarterly, vol.3, issue.1-2, pp.83-97, 1955. ,
DOI : 10.1002/nav.3800020109
The Model Coupling Toolkit: A New Fortran90 Toolkit for Building Multiphysics Parallel Coupled Models, International Journal of High Performance Computing Applications, vol.19, issue.3, pp.277-292, 2005. ,
DOI : 10.1177/1094342005056115
Ten organising principles for coupling in multiphysics and multiscale models, ANZIAM Journal, vol.48, pp.1090-1111, 2009. ,
DOI : 10.21914/anziamj.v48i0.138
A multilevel algorithm for partitioning graphs, ACM/IEEE conference on Supercomputing, pp.13-14, 1995. ,
A spectral technique for correspondence problems using pairwise constraints, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1482-1489, 2005. ,
DOI : 10.1109/ICCV.2005.20
Accelerating shape optimizing load balancing for parallel FEM simulations by algebraic multigrid, Proceedings 20th IEEE International Parallel & Distributed Processing Symposium, pp.57-57, 2006. ,
DOI : 10.1109/IPDPS.2006.1639295
Parallel load balancing for dynamic execution environments, Computer Methods in Applied Mechanics and Engineering, vol.189, issue.4, pp.1295-1309, 2000. ,
DOI : 10.1016/S0045-7825(99)00378-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.30.2520
PLUM : Parallel Load Balancing for Adaptive Unstructured Meshes, Journal of Parallel and Distributed Computing, vol.52, issue.2, pp.150-177, 1998. ,
DOI : 10.1006/jpdc.1998.1469
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.158.9552
Dynamic partitioning of non-uniform structured workloads with spacefilling curves. Parallel and Distributed Systems, IEEE Transactions on, vol.7, issue.3, pp.288-300, 1996. ,
Transient dynamics simulations, Proceedings of the 1996 ACM/IEEE conference on Supercomputing (CDROM) , Supercomputing '96, 1996. ,
DOI : 10.1145/369028.369087
Partitioning Sparse Matrices with Eigenvectors of Graphs, SIAM Journal on Matrix Analysis and Applications, vol.11, issue.3, pp.430-452, 1990. ,
DOI : 10.1137/0611030
Multiple-way network partitioning, IEEE Transactions on Computers, vol.38, issue.1, pp.62-81, 1989. ,
DOI : 10.1109/12.8730
URL : https://urresearch.rochester.edu/fileDownloadForInstitutionalItem.action?itemId=6153&itemFileId=9759
Think Locally, Act Globally: Highly Balanced Graph Partitioning, Proceedings of the 12th International Symposium on Experimental Algorithms (SEA'13), pp.164-175, 2013. ,
DOI : 10.1007/978-3-642-38527-8_16
URL : http://algo2.iti.kit.edu/documents/kahip/highly_balanced.pdf
Multilevel Diffusion Schemes for Repartitioning of Adaptive Meshes, Journal of Parallel and Distributed Computing, vol.47, issue.2, pp.109-124, 1997. ,
DOI : 10.1006/jpdc.1997.1410
Effects of tropical cyclones on ocean heat transport in a high resolution coupled general circulation model, Journal of Climate, vol.24, pp.4368-4384, 2011. ,
Partitioning of unstructured problems for parallel processing, Computing Systems in Engineering, vol.2, issue.2-3, pp.135-148, 1991. ,
DOI : 10.1016/0956-0521(91)90014-V
How good is recursive bisection?, SIAM J. Sci. Comput, vol.18, pp.1436-1445, 1995. ,
Partitioning and Dynamic Load Balancing for the Numerical Solution of Partial Differential Equations, Numerical Solution of Partial Differential Equations on Parallel Computers, pp.55-88, 2006. ,
DOI : 10.1007/3-540-31619-1_2
Monte Carlo modeling of radiative transfer in a turbulent sooty flame, International Journal of Heat and Mass Transfer, vol.47, issue.3, pp.555-572, 2004. ,
DOI : 10.1016/j.ijheatmasstransfer.2003.06.003
The oasis3 coupler: a european climate modelling community software, Journal of Geosci. Model Dev, pp.373-388, 2013. ,
Dynamic load balancing with a spectral bisection algorithm for the constrained graph partitioning problem, High-Performance Computing and Networking, pp.392-397, 1995. ,
DOI : 10.1007/BFb0046658
A Two-Dimensional Data Distribution Method for Parallel Sparse Matrix-Vector Multiplication, SIAM Review, vol.47, issue.1, pp.67-95, 2005. ,
DOI : 10.1137/S0036144502409019
Dynamic load-balancing with variable number of processors based on graph repartitioning, 2012 19th International Conference on High Performance Computing, 2012. ,
DOI : 10.1109/HiPC.2012.6507501
URL : https://hal.archives-ouvertes.fr/hal-00722731
Graph Repartitioning with both Dynamic Load and Dynamic Processor Allocation, International Conference on Parallel Computing -ParCo2013, Advances of Parallel Computing, pp.243-252, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00857881
Multilevel mesh partitioning for heterogeneous communication networks, Future Generation Computer Systems, vol.17, issue.5, pp.601-623, 2001. ,
DOI : 10.1016/S0167-739X(00)00107-2
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.880
Multiphase mesh partitioning, Applied Mathematical Modelling, vol.25, issue.2, pp.123-140, 2000. ,
DOI : 10.1016/S0307-904X(00)00041-X
URL : http://doi.org/10.1016/s0307-904x(00)00041-x
Parallel climate model (PCM) control and transient simulations, Climate Dynamics, vol.16, issue.10-11, pp.16755-774, 2000. ,
DOI : 10.1007/s003820000079
Direct numerical simulation of turbulence/radiation interaction in premixed combustion systems, Proceedings of the Combustion Institute, pp.639-646, 2005. ,
DOI : 10.1016/j.proci.2004.08.138
Physical study of radiation effects on the boundary layer structure in a turbulent channel flow, International Journal of Heat and Mass Transfer, vol.61, pp.654-666, 2013. ,
DOI : 10.1016/j.ijheatmasstransfer.2013.02.041
URL : https://hal.archives-ouvertes.fr/hal-01344924
A Multiscale Approach for the Coupled Simulation of Blood Flow and Thrombus Formation in Intracranial Aneurysms, Procedia Computer Science, vol.18, pp.1006-1015, 2013. ,
DOI : 10.1016/j.procs.2013.05.266
PaToH: A Multilevel Hypergraph Partitioning Tool, 1999. ,
Coupling-aware graph partitioning algorithms: Preliminary study, 2014 21st International Conference on High Performance Computing (HiPC), 2014. ,
DOI : 10.1109/HiPC.2014.7116879
URL : https://hal.archives-ouvertes.fr/hal-01069578
Graph Operators for Couplingaware Graph Partitioning Algorithms In CIMI Workshop on Innovative clustering methods for large graphs and block methods ,
New graph partitioning techniques for load balancing of coupled simulation. womENcourage 2015, septembre 2015 ,
URL : https://hal.archives-ouvertes.fr/hal-01258036
A k-Way Greedy Graph Partitioning with Initial Fixed Vertices for Parallel Applications, 2016 24th Euromicro International Conference on Parallel, Distributed, and Network-Based Processing (PDP), p.8, 2016. ,
DOI : 10.1109/PDP.2016.109
URL : https://hal.archives-ouvertes.fr/hal-01277392
Graph partitioning techniques for load balancing of coupled simulations, SIAM Workshop on Combinatorial Scientific Computing (CSC16) , octobre 2016. Poster. [Not cited ,
URL : https://hal.archives-ouvertes.fr/hal-01399392
Comparison of Methods for Graph Partitioning with Initial Fixed Vertices, Parallel Computing Journal (under submission), 2016. [Not cited ,
