Influence of antioxidants synthesized by plants on physico-chemical and microbiological evolution of Callovo-Oxfordian clay material
Influence des molécules antioxydantes produites par des plantes sur l’évolution physico-chimique et microbiologique de l’argilite du Callovo-Oxfordien
This study is a part of the deep disposal site development for radioactive waste in Meuse-Haute Marne (France), most specifically on the bio-physico-chemical conversion of sedimentary clay rocks (Callovo-Oxfordian, COx), excavated and stored on surface in the form of heap. During the experimental and operational phases, several million cubic meters of argillite will be excavated. Argillite stored in the open air will be exposed to meteoritic alterations, oxidizing conditions of surface and colonized biologically (plants, bacteria, fungi). The aim of the thesis is to study the impact of naturally derived antioxidants from revegetation of heap with antioxidant-producing plants on the physical, chemical or microbial weathering processes of argillite. This work was designed to (i) identify suitable naturally derived antioxidants and the plants to produce them (ii) assess the antioxidant inhibitory effects on weathering and leaching COx metals in the laboratory, (iv) field test selected plants on the heap, (iii) follow in situ physicochemical and microbiological evolution of the argillite heap planted with antioxidant producing plants. In the laboratory, percolating model antioxidants of Lamiaceae (linalool, thymol, carvacrol) through a packed column of argillite showed variable water weathering/leaching rate depending on the metal elements present; very low for aluminum (<1 ‰), between 1-3% for other metals (Ca, Mg, Fe ...) and reach more than 60% for sodium. With thymol at 20 mg/l for 3 months, it was found that there are a decrease in sulfur leached amount and the metal elements from the sulfides (Fe, As) and carbonates (Ca, Sr) and inhibition of bacterial and fungal microflora growths. However, intake of artificial root exudates in columns stimulates microbial growth, improves the availability of aluminum, iron and provides sequestration of calcium. Among the tested plants, lavender and lavandin were selected. Two successive plantation tests were carried out in situ on a heap of old argillite (10 years) for one year. The lavandin grew better than lavender and was retained for the second study in situ. The comparison of the planted part of the COx heap with bare COx showed (i) a significant reduction in the quantities of calcium, strontium, iron and sulfur leached (ii) a significant reduction (by two orders of magnitude) to the amount of eroded material on the slope planted compared to unplanted (iii) a significant rate of mycorrhiza roots and microbial growth. In conclusion, although the naturally derived antioxidants did not significantly inhibit the alteration of argillite, the lavandin is an excellent plant for phytostabilisation of heap and for production of antioxidants.
Cette étude s’inscrit dans le contexte du stockage profond de déchets radioactifs sur le site de Meuse-Haute Marne (Andra) et plus précisément de l’évolution bio-physico-chimique de roches sédimentaires argileuses (Callovo-Oxfordien, COx), excavées et stockées en surface sous forme de verses. Durant la phase préparatoire et la phase d’exploitation, plusieurs millions de mètres cubes d’argilites seront excavées. L’argilite stockée à l’air libre sera ainsi exposée durant plusieurs décennies aux altérations météoritiques et aux conditions oxydantes de surface et à la colonisation biologique (plantes, bactéries, champignons). L’objectif de la thèse était d’étudier l’impact de molécules antioxydantes et de la végétalisation des verses par des plantes produisant ces molécules, sur les processus d’altération physiques, chimiques ou microbiens de l’argilite du COx. Ce travail visait à (i) identifier des molécules antioxydantes et des plantes d’intérêt (ii) évaluer les effets inhibiteurs des substances antioxydantes sur l’altération des minéraux et la lixiviation des métaux du COx au laboratoire, (iv) tester la cultivabilité des plantes sélectionnées sur les verses, (iii) suivre in situ l’évolution physico-chimique et microbiologique de l’argilite d’une verse plantée ou non. Des expériences de percolation en colonnes avec des molécules antioxydantes « modèles » des Lamiacées (linalol, thymol, carvacrol) ont montré des taux d’altération/lixiviation très variables en fonction de l’élément. Ils étaient très faibles pour l’aluminium (<1‰), compris entre 1-3% pour les autres métaux (Ca, Mg, Fe…) et atteignaient plus de 60% pour le sodium. Avec le thymol à 20 mg/l ont été observés sur 3 mois une diminution des taux de lixiviation du soufre et des éléments métalliques constitutifs des sulfures (Fe, As) et carbonates (Ca, Sr) et une diminution de l’abondance microbienne bactérienne et fongique. Cependant, l’apport d’exsudats racinaires synthétiques dans les colonnes a stimulé le développement microbien et amélioré la disponibilité de l’aluminium et du fer et la séquestration du calcium. Parmi les plantes testées, la lavande et le lavandin ont été sélectionnés. Deux essais successifs de plantations ont été menés in situ sur une verse d’argilite âgée (10 ans) durant un an. Le lavandin s’est mieux développé que la lavande et a été conservé pour la deuxième étude in situ. La comparaison de la partie plantée de la verse avec la partie nue a montré (i) une diminution significative des quantités de calcium, strontium, fer et soufre lixiviées (ii) une réduction importante de la quantité de matériel érodé (de deux ordres de grandeur) sur le talus planté par rapport au non planté (iii) un développement microbien et un taux de mycorhization important des racines. En conclusion, même si les molécules antioxydantes n’inhibent pas significativement l’altération de l’argilite, le lavandin s’est révélé une plante tout à fait pertinente pour la phytostabilisation des verses et la production de molécules antioxydantes in situ a été montrée
Science des sols
