Dépôt et caractérisation de couches minces de SiCxNy.H par CVD assistée par plasma micro-ondes ECR avec précurseurs organosiliciés - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Synthesis and characterization of SiCxNy.H thin films by ECR microwave plasma assisted CVD using organosilicon precursors
Amanda Thouvenin
  • Fonction : Auteur
  • PersonId : 777228
  • IdRef : 200138766
Si, C and N based thin films are multifunctional materials with optical, electronical and mechanical properties showing great potential for photovoltaic and microelectronic applications and more. Those properties exhibit a strong dependency upon the structure of the thin film. Several goals were set for this thesis work: the development of a ECR microwave plasma assisted CVD deposition reactor using organosilicon precursors (hexamethyldisilazane or HMDSN and tetramethylsilane or TMS), the characterization of SiCN thin films deposited in this reactor, and the development of diagnosis tools suited for the analysis of the growing film. Two in situ characterization techniques have been developed. The interferential baseline extraction from FT-IR spectra enables the determination of thin film optical parameters (refractive index and thickness) in the infrared range. This diagnosis is applied as well with post-deposition analysis as with real time in situ control of the deposition process. Moreover, the development of a reflectometry diagnosis has allowed to monitor and control the deposition process in the visible range. Influence of substrate temperature, precursor flow and plasma power as well as thin film ageing has been studied. Those analyses have enabled the derivation of optimal deposition conditions leading to denser films with better oxidation resistance. Then, the variation of nitrogen concentration in the gaseous mixture has led to the synthesis of a wide variety of thin film compositions ranging from SiC to SiN like thin films with a large range of refractive index. Finally, using an innovative hybrid system coupling an ECR microwave plasma with the pulverization of a Si target, Si-richer thin films have been synthesized allowing for denser thin films with higher refractive indices owing to an increase in Si-C bonding.
Les films à base de Si, C et N sont des matériaux multifonctionnels aux propriétés optiques, électroniques et mécaniques attractives pour des applications dans le domaine du photovoltaïque et de la microélectronique entre autres. Il existe une forte dépendance de ces propriétés par rapport à la structure. Ce travail de thèse a plusieurs objectifs. Le premier objectif est la mise au point d’un procédé de dépôt de films minces de SiCxNy:H dans un réacteur CVD assistée par plasma micro-ondes ECR avec les précurseurs organosiliciés héxaméthyldisilazane (HMDSN) et tétraméthylsilane (TMS). Le second objectif est la caractérisation des dépôts synthétisés dans ce nouveau réacteur et le développement d’outils de diagnostic afin d’étudier le dépôt en cours de croissance. Deux techniques de caractérisation in situ ont été développées. Un procédé d’extraction de la ligne de base interférentielle des spectres FT-IR permet la détermination des paramètres optiques dans l’infrarouge (indice de réfraction et épaisseur) du film sondé. Ce diagnostic est adapté aussi bien à une analyse post-dépôt qu’au contrôle de procédé in situ en temps réel. De plus, la mise au point de la technique de réflectométrie a permis le suivi et le contrôle des dépôts lors de leur croissance dans le domaine visible. L’influence de la température de dépôt, du flux de précurseur et de la puissance injectée dans le plasma ainsi que le vieillissement des films à l’air ont été étudiés dans un premier temps. Ces études ont permis l’établissement des paramètres de dépôts optimaux et la détermination des conditions menant aux dépôts les plus denses avec la meilleure résistance à l’oxydation. Dans un second temps, l’étude de l’influence du taux d’azote dans le mélange gazeux a permis la synthèse de films avec une composition variée allant d’un type SiC:H à un type SiN:H et ainsi d’obtenir une large gamme d’indices de réfraction. Enfin, l’utilisation d’un procédé de dépôt hybride couplant le plasma ECR micro-ondes dans un mélange gazeux contenant TMS à la pulvérisation d’une cible de Si, a mené à la synthèse de films plus riches en silicium améliorant la densité de liaisons Si-C et entraînant la hausse de l’indice de réfraction des films
DDOC_T_2016_0196_THOUVENIN.pdf (7.4 Mo) Télécharger le fichier
tel-01527978 , version 1 (26-05-2017)
  • HAL Id : tel-01527978 , version 1
Amanda Thouvenin. Dépôt et caractérisation de couches minces de SiCxNy.H par CVD assistée par plasma micro-ondes ECR avec précurseurs organosiliciés. Physique des plasmas [physics.plasm-ph]. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0196⟩. ⟨tel-01527978⟩
247 Consultations
1643 Téléchargements
