Le système binaire aluminium-iridium, du diagramme de phases aux surfaces atomiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
The Al-Ir binary system, from the phase diagram to atomic surfaces
Joris Kadok
  • Fonction : Auteur
  • PersonId : 782346
  • IdRef : 200140000
A complex metallic alloy (CMA) is an intermetallic compound whose unit cell contains a large number of atoms oftenly forming highly-symmetric clusters. From the complexity of these compounds can arise physical and chemical properties interesting for various fields of application. The aluminium-iridium binary system exhibits numerous intermetallic compounds of which half of them are actually CMAs. Despite this system being extensively studied in the literature, some uncertainies remained unsolved, leading us to reinvestigate the Al-Ir phase diagram. In addition, the "push-pull" systems Al-Au-Ir and Al-Ag-Ir, favorable for the formation of CMA according to the literature, have been explored. Thus, near a hundred of samples have been prepared by arc-melting before being analyzed with different characterizations techniques: X-ray diffraction (XRD), scanning electron microscopy (SEM), energy dispersive X-ray spectroscopy (EDS) and differential thermal analysis (DTA). From this study, 4 new intermetallic compounds could be identified: Al2.4Ir, Al72Au2.5Ir29.5, Al3AuIr and Al11SiIr6, the latter being the result of a fortuitous manipulation. The crystallographic structure of each of these compounds has been solved, revealing Al2.4Ir and Al72Au2.5Ir29.5 to be two CMAs with around one hundred of atoms in their unit cell. Calculations based on the density functional theory (DFT) brought further details about the stability of the two other Al3AuIr and Al11SiIr6 compounds. In the Al-Ir binary system, a structural variant of two well-known CMAs has been also unveiled. The crystallographic structures of the Al2.75Ir and Al28Ir9 variant have been approached, revealing 240 and 444 atoms in their respective unit cell. The CMAs oftently exhibit interesting surface properties. In order to study the Al-Ir compound surfaces, iridium adsorption on Al(100) surface followed by annealing has been investigated. The characterizations by lowenergy electrons diffraction (LEED), X-ray photoelectron spectroscopy (XPS) and scanning tunneling miscoscopy (STM) supported by ab initio calculations revealed that, from 320 C, the Al9Ir2 compound is formed at the surface but also in the substrate bulk
Un alliage métallique complexe (CMA) est un composé intermétallique dont la maille élémentaire est constituée d’un nombre important d’atomes formant bien souvent des aggrégats de haute symmétrie. De la complexité de ces composés peuvent découler des propriétés physico-chimiques intéressantes pour divers domaines d’application. Le système binaire aluminium-iridium est un système qui présente de nombreux composés intermétalliques dont la moitié sont des CMA. Malgré l’étude approfondie dont ce système a fait l’objet dans la littérature, certaines incertitudes demeuraient irrésolues, nous amenant ainsi à réexaminer le diagramme de phase Al-Ir. Nous avons également exploré les systèmes ternaires dits "push-pull" Al-Au-Ir et Al-Ag-Ir, propices à la formation de phases CMA selon certains auteurs. Au total, une centaine d’échantillons ont été préparés par fusion à l’arc puis analysés par diverses techniques de caractérisations: diffraction des rayons X (XRD), microscopie électronique à balayage (SEM), analyse dispersive en énergie (EDS) et analyse thermique différentielle (DTA). Quatre nouveaux composés intermétalliques ont ainsi été identifiés: Al2.4Ir, Al72Au2.5Ir29.5, Al3AuIr et Al11SiIr6, ce dernier étant issu d’une manipulation accidentelle. La structure cristallographique de chacun de ces composés a été résolue, révélant Al2.4Ir et Al72Au2.5Ir29.5 comme étant des CMA possédant une centaine d’atomes dans la maille. Des calculs basés sur la théorie de la fonctionnelle de la densité (DFT) sont venus apporter des précisions concernant la stabilité des composés Al3AuIr et Al11SiIr6. Pour le système Al-Ir, une variante structurale de deux CMA déjà connus de la littérature a également pu être mise en évidence. Les structures cristallographiques de la variante de Al2.75Ir et de celle de Al28Ir9 ont ainsi été approchées, présentant 240 et 444 atomes dans leur maille respective. Les propriétés de surface comptent parmi les aspects les plus intéressants des CMA, par exemple pour la catalyse hétérogène. En l’absence de monocristaux de taille macroscopique, nous avons étudié la possibilité de former des composés de surface par dépôt de Ir sur une surface Al(100) suivi de recuits. Des caractérisations par diffraction d’électrons lents (LEED), spectroscopie de photoélectrons excités par rayons X (XPS) et microscopie à effet tunnel (STM) supportés par ces calculs ab initio ont révélé qu’à partir de 320°C, le composé Al9Ir2 se formait en surface mais également dans une partie du volume du substrat
Mots clés
DDOC_T_2016_0202_KADOK.pdf (13.45 Mo) Télécharger le fichier
tel-01527988 , version 1 (26-05-2017)
  • HAL Id : tel-01527988 , version 1
Joris Kadok. Le système binaire aluminium-iridium, du diagramme de phases aux surfaces atomiques. Science des matériaux [cond-mat.mtrl-sci]. Université de Lorraine, 2016. Français. ⟨NNT : 2016LORR0202⟩. ⟨tel-01527988⟩
390 Consultations
273 Téléchargements
