Assessing and Improving Code Transformations to Support Software Evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Evaluation et amélioration des transformations de code pour soutenir l'évolution logicielle
In software development, change is the only constant. Software systems sometimes evolve in a substantial way and, during this process, sequences of code transformations (e.g., create a class, then override a method) are systematically performed in the system (e.g., to some classes in the same hierarchy). Due to the repetitive nature of these transformations, some automated support is needed to ensure that these sequences of transformations are consistently applied to the entire system. In this thesis we propose to improve source code transformations to better support developers performing more complex and systematic code transformations. We cover two aspects: (i) The automated support to compose and apply sequences of code transformations. We undergo an investigation on the existence of these sequences in real-world software systems. We propose a tool to automatically apply these sequences in the systems we analyzed. (ii) The detection of design violations during a transformation effort. We undergo an investigation on cases of systematic application of refactoring transformations. We proposed a tool that recommends additional transformations to fix design violations that are detected after performing refactoring transformations. We evaluated the proposed approaches quantitatively and qualitatively in real-world case studies and, in some cases, with the help of experts on the systems under analysis. The results we obtained demonstrate the usefulness of our approaches.
Dans le domaine du développement logiciel, le changement est la seule constante. Les logiciels évoluent parfois de façon substantielle et, pendant ce processus, des séquences de transformation de code (par exemple, créer une classe, puis surcharger une méthode) sont systématiquement appliquées dans le système (e.g. à certaines classes dans une même hiérarchie). De par la nature répétitive de ces transformations, il est nécessaire d’automatiser leur support afin d’assurer que ces séquences de transformations sont appliquées de façon consistante sur la globalité du système. Dans cette thèse, nous proposons d’améliorer les transformations de code pour mieux aider les développeurs dans l’application de transformation de code systématiques et complexes. Nous couvrons deux aspects: (i) Le support automatisé pour composer et appliquer des séquences de transformations de code. Nous réalisons une recherche de l’existence de telles séquences dans de vrais logiciels. Nous proposons un outil pour appliquer automatiquement ces séquences dans les systèmes que nous avons analysés. (ii) La détection de violations de bons principes dans la conception lors d’efforts de transformation. Nous proposons un outil qui recommande des transformations additionnelles pour résoudre les violations de conception qui ont pu être détectées après avoir effectué les transformations de refactoring. Nous évaluons les approches proposées quantitativement et qualitativement sur des cas d’étude issus du monde réel, parfois avec l’aide des experts du système analysé. Les résultats obtenus montrent la pertinence de nos approches.
PhD-2017-Santos.pdf (3.1 Mo) Télécharger le fichier
tel-01545596 , version 1 (22-06-2017)
  • HAL Id : tel-01545596 , version 1
Gustavo Jansen de Souza Santos. Assessing and Improving Code Transformations to Support Software Evolution. Software Engineering [cs.SE]. Université de Lille, 2017. English. ⟨NNT : ⟩. ⟨tel-01545596⟩
246 Consultations
351 Téléchargements
