L'intervention dans l'organisation en clinique de l'activité : le dispositif "DQT" RENAULT à l'usine de Flins - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Activity clinic intervention into organization : "Dialog on the quality of work" device in Flins Renault Factory
This thesis contributes to explore a way of organizational transformation from the perspective of a joint development of health and efficiency. It is based on the institution of conflict criteria on the quality of work. This thesis comes from an experiment conducted with the Renault company in the Flins factory, using a developmental methodology in occupational psychology, under the terms of the Activity Clinic. This experiment resulted in the development and the establishment of a dialogue process on the Quality of operators Work. The object of our research consists to examine the practical results produced by this methodology, since the genesis of the device to its institution into the organization. We study four main dimensions at the center of intervention and sustainable transformation of organizations issues: the conflict criteria on the quality of work, the function of affective conflict in activity, and the dialogic performance and professional authority as conditions for performance and health. We conclude on the perspectives opened by this work : firstly, on the conflict criteria’s energy on the quality of work in the occupational psychology intervention ; Secondly, on the role of professional dialogues based on the quality of work in the revitalization process of contemporary organizations.
Cette thèse contribue à explorer une voie possible de transformation organisationnelle au service de la santé et de la performance par l’institution du conflit de critères sur la qualité du travail. Ce travail est issu d’une expérimentation réalisée avec l’entreprise Renault à l’usine de Flins dans le cadre d’une méthodologie développementale en psychologie du travail, sous les modalités de la clinique de l’activité. Cette expérimentation a donné lieu au développement et à l’institution d’un dispositif de Dialogue sur la Qualité du Travail (DQT) des opérateurs. Notre travail de recherche prend pour objet l’examen minutieux de ces résultats obtenus, de la genèse du dispositif à son institution dans l’organisation. Nous étudions alors quatre dimensions au centre des enjeux d'intervention et de transformation durable des organisations : le conflit de critères sur la qualité du travail, la fonction du conflit affectif dans l’activité, la performance dialogique de l’organisation et l'autorité professionnelle comme conditions de la performance concrète et de la santé. Nous concluons sur les perspectives ouvertes par cette thèse : d’une part la force motrice du conflit de critères sur la qualité du travail dans l’intervention en psychologie du travail, d’autre part la fonction de l’institution du dialogue sur ce conflit de critères pour la revitalisation des organisations contemporaines.
BONNEFOND_JeanYves2016.pdf (4.21 Mo) Télécharger le fichier
tel-01546345 , version 1 (23-06-2017)
  • HAL Id : tel-01546345 , version 1
Jean-Yves Bonnefond. L'intervention dans l'organisation en clinique de l'activité : le dispositif "DQT" RENAULT à l'usine de Flins. Sociologie. Conservatoire national des arts et metiers - CNAM, 2016. Français. ⟨NNT : 2016CNAM1084⟩. ⟨tel-01546345⟩
1366 Consultations
3646 Téléchargements
