Modélisations, Simulations, Synthèses pour des réseaux dynamiques de capteurs sans fil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Modeling, simulations and synthesis for dynamic wireless sensor networks
The integration of environment and information systems is progressing quickly since 10 years. This allows to monitor natural, physical or societal evolutions; to capture their logic and sometimes to control their effects. This integration is feasible thanks to many technical and scientific progresses: sensors, wireless communications, system on chips, batteries, distributed systems and geo-localization. The benefits are important for climate change monitoring and resource savings.In this context, we have firstly achieved a learning of technologies and several practical system realizations. We have produced a navigation software (QuickMap) allowing to interface gis databases and tile servers similar to OpenStreetMap, taking care of sensor locations and outputs. QuickMap is also a nice frontend to produce cellular systems oriented to physical simulations.Using the NetGen platform, we have produced a simulation framework allowing to schedule mobile moves with sensor field activities. A case study was leo satellites visiting remote sensor systems, with investigations on two algorithms suitable for data collection and control.Finally we have addressed the question of observation system virtualization by using an high level, process oriented virtual machine (tvm) to control the wireless link, a step forward to make the distributed and local behaviours homogeneous in terms of programming and simulation.Many of our developments are currently involved in active projects.This thesis was funded by a grant of Brest Metropole Oceane (BMO) and was achieved in a wireless research group at University of Brest, Lab-STICC laboratory.
L’intégration de l’environnement et des systèmes d’information progresse très vite depuis 10 ans. Cette intégration permet de suivre des évolutions naturelles, physiques, sociétales ; de les mesurer, de les comprendre ; quelquefois de les contrôler. On peut assimiler cette intégration à des besoins, tels que les changements climatiques ou les économies de ressources ; mais aussi à des progrès technologiques dans les domaines des systèmes miniatures, des communications sans fil et des capteurs.Dans ce contexte, nous avons d’abord effectué un apprentissage technologique, en réalisant plusieurs petits systèmes et des logiciels applicatifs de bas et de haut niveau. Nous nous sommes attaqués à la partie frontale des chaînes logicielles, celle qui permet de passer des bases de données pour Systèmes d’Information Géographique à l’implantation et l’exploitation de systèmes distribués de capteurs. QuickMap est ainsi un logiciel de navigation multi-services, incluant OpenStreetMap, construit pour le placement des capteurs et la spécification de systèmes de cellules physiques.Sur la plateforme NetGen, nous avons réalisé un simulateur concurrent associant un ou plusieurs mobiles à un ou plusieurs champs de capteurs. Une application est l’étude des interactions entre satellite en orbites basses, réseaux de capteurs lointains et stations de contrôle.Le séquencement par le temps permet d’associer plusieurs activités aériennes et au sol, en bénéficiant de hautes performances.Enfin, les questionnements méthodologiques ont amené à considérer la possibilité de virtualisation, à la fois du capteur, en le recouvrant d’une machine virtuelle, et à la fois du système d’observation distribué, en utilisant la plateforme NetGen.Nous avons maquetté un capteur et son interface radio en termes de processus communicants, en cherchant à réduire la complexité et la diversité de la programmation des petits systèmes matériels.Plusieurs de nos réalisations sont effectives et servent à des projets de recherche actifs.Cette thèse a été réalisée à l’Université de Brest, laboratoire Lab-STICC, grâce à une allocation de la communauté brestoise BMO.
These-2016-SICMA-Informatique-LUCAS_Pierre_Yves.pdf (21.76 Mo) Télécharger le fichier
tel-01547613 , version 1 (27-06-2017)
  • HAL Id : tel-01547613 , version 1
Pierre-Yves Lucas. Modélisations, Simulations, Synthèses pour des réseaux dynamiques de capteurs sans fil. Autre [cs.OH]. Université de Bretagne occidentale - Brest, 2016. Français. ⟨NNT : 2016BRES0114⟩. ⟨tel-01547613⟩
448 Consultations
605 Téléchargements
