Contribution à la caractérisation du bruit de frottement des étoffes : application au prêt-à-porter (cas du vêtement furtif) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Contribution to the characterization the frictional noise of fabrics : application to ready-to-wear (case of furtive clothe)
This work aims to characterize and analyze the frictional noise of textile materials generated during the activity of a subject (walking and running). This work contributes to the physical characterization of frictional noise characterized by physical parameters of sound (noise) and thanks to a new method of treatment of the acoustic signal, Stokwell-transform. Sensory evaluation of frictional noise was conducted by trained panelists using the Quantitative Descriptive Analysis method. In this context, the influence of the weave patterns of raw cotton fabrics on sound properties was analyzed. Correlations between the mechanical parameters of the fabric which describe the surface and the compressional proprieties of fabrics (measured by the Kawabata Evaluation System) and the sound level of the frictional noise were conducted. Correlations between the noise level and sensory descriptors were also conducted. The sounds of a man's jacket, fabricated in two types of prototypes with sleeves variants were analyzed in situation case, in an anechoic room. According to the treatment of acoustic signal, the twill 3 weave pattern is the noisiest one with a most important level sound and highest amplitude for the two types of movement (walking and running). The satin 4 weave pattern, which is the less noisy, presents a sound level and its highest amplitude is the less important. The frequency of highest amplitude is less important for twill 3 than satin 4. The results obtained by sensory analysis are coherent with the results obtained by instrumental characterization. The subjects participating to sensory evaluation of frictional noise of these fabrics perceived that the noise of satin 4 as the most muffled and most homogeneous noise, while the noise of twill 3 was perceived as the most dynamic and the most disharmonic one. Proposed models express that the sound level increases with the surface roughness and decreases with the resilience and the compression energy. The more sound level is important, the more the noise is perceived as polyphonic and scratching. The noise generated by the friction of the jacket with the two types of sleeves is similar whatever the evaluation.
Ce travail a pour objectif de caractériser et analyser le bruit de frottement des étoffes textiles généré lors de l’activité d’un individu (marche et course). Le présent travail apporte une contribution pour la caractérisation physique du bruit de frottement grâce à des paramètres physiques du son (bruit) et grâce à une nouvelle méthode de traitement du signal sonore des étoffes textiles, la transformée en S (transformée de Stokwell). L’évaluation sensorielle du bruit a été menée grâce à des panélistes entraînés en appliquant la méthode d’Analyse Descriptive Quantitative. Dans ce cadre, l’influence de l’armure d’étoffes en coton écru sur les propriétés sonores a été analysée. La corrélation entre les paramètres mécaniques des tissus qui décrivent l’état de surface et la compression de l’étoffe (mesurés par la chaîne de mesure Kawabata Evaluation System) et le niveau sonore global du bruit de frottement a été effectuée. Une corrélation entre le niveau sonore et les descripteurs sensoriels a été également menée. Le bruit d’une veste d’homme, confectionnée en deux types de prototypes présentant des variantes de manches, a été analysé en situation réelle, dans une chambre anéchoïque.Selon le traitement des signaux sonores, l’armure sergé 3 est la plus bruyante avec un niveau sonore, une amplitude du maximum les plus importants, pour les deux vitesse de frottement (marche et course), et une fréquence de maximum se trouvant dans la zone fréquentielle pour laquelle l’oreille humaine est la plus sensible. L’armure satin 4 est la plus ‘furtive’ avec un niveau sonore, une amplitude du maximum la moins importante et une fréquence correspondant importante et moins perceptible. Les résultats obtenus par l'analyse sensorielle sont cohérents avec les résultats obtenus en terme instrumental. Les panélistes qui participent à l'évaluation du bruit de frottement des étoffes textile ont perçu le bruit du satin 4 comme le bruit le plus sourd et le plus homogène, alors que le bruit du sergé 3 a été perçu comme le bruit le plus énergique et le plus disharmonique. Les modèles établis expriment que le niveau sonore augmente en fonction de la rugosité de surface et diminue en fonction de la résilience et de l'énergie de compression. Ainsi, plus que le niveau sonore est important, plus que le bruit est perçu plus polyphonique et plus grattant. Les bruits générés par le frottement de la veste avec les deux types de manche sont similaires en termes instrumental et sensoriel.
2016MULH8214_these_YOSOUF.pdf (13.31 Mo) Télécharger le fichier
tel-01548624 , version 1 (27-06-2017)
  • HAL Id : tel-01548624 , version 1
Khaldon Yosouf. Contribution à la caractérisation du bruit de frottement des étoffes : application au prêt-à-porter (cas du vêtement furtif). Autre. Université de Haute Alsace - Mulhouse, 2016. Français. ⟨NNT : 2016MULH8214⟩. ⟨tel-01548624⟩
747 Consultations
224 Téléchargements
