Development of porous materials and study of their adsorption properties of dioxins/furans
Elaboration de matériaux poreux et étude de leurs propriétés d'adsorption de dioxines/furanes
Environmental and human health protection is a scientific and ethical concern. Dioxin/furan compounds, produced from waste incineration process among other, are ones of the most dangerous pollutants due to their stability and ability to bio-accumulate. Polychlorobenzenes are often referred as model molecules of these compounds and will be used as it in this PhD work. Thanks to their microporous organized structures which confer to them remarkable adsorption capacities, zeolites and Metal-Organic Frameworks (MOFs) are interesting materials to trap these organic pollutants. Their shaping as beads for example offer the advantage to overcome problems such as clogging or excessive pressure losses that can appear for an industrial application. Therefore, the aim of this PhD is to prepare and characterize zeolite and MOF, to shape them and to study their adsorption properties for polychlorobenzenes/dioxins/furans. All zeolites and MOFs have been selected and prepared in order to optimize their structural, textural and morphological characteristics for the intended application. A study on the shaping of the FAU-type zeolite has allowed the development of beads with good mechanical and adsorption properties. The different polychlorobenzenes/dioxins/furans adsorption tests into gas and liquid phases allowed identifying the best solids for the selective adsorption of these pollutants in waste incineration plant emissions.
La protection de l’environnement et de la santé humaine représente une préoccupation éthique et scientifique primordiale. Les dioxines/furanes, produits, entre autres, par les processus d’incinération de déchets, font partie des polluants les plus dangereux de par leur stabilité et leur faculté à être bio-accumulés. Les polychlorobenzènes sont souvent référencés comme molécules modèles de ces composés et seront utilisés en tant que tels dans ces travaux de thèse. Grâce à leurs structures microporeuses organisées qui leur confèrent de remarquables capacités d’adsorption, les zéolithes et les Metal-Organic Frameworks (MOFs) représentent des matériaux de choix pour piéger ces polluants organiques. Leur mise en forme sous forme de billes par exemple offre l’avantage de s’affranchir de problèmes tels que le colmatage ou les pertes de charges trop importantes pouvant apparaître pour une application à l’échelle industrielle. C’est pourquoi, cette thèse vise à élaborer et caractériser des adsorbants zéolithiques et de type MOF, de les mettre en forme et d’étudier leurs propriétés d’adsorption vis-à-vis de polychlorobenzènes/dioxines/furanes. L’ensemble des zéolithes et MOFs ont été sélectionnés et préparés de sorte à optimiser leurs caractéristiques structurales, texturales et morphologiques pour les applications ciblées. Une étude sur la mise en forme de la zéolithe de type FAU a conduit à l’élaboration de billes présentant de bonnes propriétés mécanique et d’adsorption. Les différentes mesures d’adsorption de polychlorobenzènes/dioxines/furanes en phases gaz et liquide ont permis de mettre en évidence les meilleurs matériaux pour l’adsorption sélective de ces polluants à l’émission d’usines d’incinération de déchets.
