Dépistage du vieillissement cardio-vasculaire : impact des nouveaux marqueurs d’imagerie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Cardiovascular aging and cardiac remodeling
Olivier Huttin
  • Fonction : Auteur
  • PersonId : 770504
  • IdRef : 127860991
Cardiovascular aging is strongly associated with myocardial fibrosis and progressive LV systolic/diastolic dysfunction including vascular stiffening. Cardiac remodeling with left ventricular parietal stress and hypertrophy take place over several years and can ultimately lead to the occurrence of heart failure. Clinical, biological or imaging tools are currently insufficient to detect early changes or to predict the onset of subsequent remodeling in an effective manner. However, if subclinical structural and functional cardiac abnormalities are not detected by conventional echocardiographic techniques, they may be evaluated by others imaging tools with the measurement of myocardial deformation parameters. We performed a systematic review suggesting that deformation imaging is associated with left ventricular volume and function changes regardless the mechanisms and deformation direction. But added strain predictive value over other clinical, biological and imaging variables remains to prove. After validation of various remodeling indices, we proved the add value of a comprehensive assessment of ventricule geometry and function to evaluate remodeling after an acute event. We confirmed the central role of myocardial deformation for infarct size quantification and detect right ventricle extension. Finally, we used vascular function measured by MRI to demonstrate the relation between ventriculo-arterial coupling and remodeling. Further studies are needed to assess the gain in information provided by strain and these new biomarkers.
Le vieillissement cardiaque est fortement associé à l’apparition d’une fibrose pouvant entrainer une dysfonction progressive du remplissage et de l’éjection ventriculaire. Le dépistage du remodelage et du vieillissement cardiovasculaire sont primordiaux afin de proposer des stratégies de prévention et de prises en charge spécifiques visant à retarder l’apparition ou ralentir la progression d’une insuffisance cardiaque à fraction d’éjection préservée. Les outils cliniques, biologiques ou d’imagerie sont insuffisamment performants à l’heure actuelle pour dépister ces modifications précoces ou prédire l’apparition de remodelage ultérieur de façon efficace. La réalisation d’une méta-analyse avec revue de la littérature, nous a permis de montrer la valeur de la déformation myocardique comme marqueur du remodelage cardiovasculaire dans le post-infarctus, mais nous a aussi éclairé sur la complexité du phénomène et le manque de preuves sur sa potentielle valeur additionnelle en pratique clinique. Après avoir validé les différents outils de quantification du remodelage dans nos cohortes, nous avons montré l’importance d’une expertise précise de la morphologie et de la fonction cardiaque lors d’un évènement aigu pour prédire un remodelage ultérieur. Nous avons précisé le rôle de la déformation myocardique dans la quantification de la taille de l’infarctus, sa sévérité et son éventuelle extension au ventricule droit. Enfin, nous avons mis en relation les paramètres de contractilité et de fonction vasculaire en montrant la valeur du couplage ventriculo artériel mesuré en IRM. Ces travaux ouvrent la voie pour une stratégie d’évaluation d’imagerie précoce en post-infarctus pouvant orienter les thérapeutiques de revascularisation et/ou de réhabilitation
DDOC_T_2017_0017_HUTTIN.pdf (14.11 Mo) Télécharger le fichier
tel-01549172 , version 1 (28-06-2017)
  • HAL Id : tel-01549172 , version 1
Olivier Huttin. Dépistage du vieillissement cardio-vasculaire : impact des nouveaux marqueurs d’imagerie. Cardiologie et système cardiovasculaire. Université de Lorraine, 2017. Français. ⟨NNT : 2017LORR0017⟩. ⟨tel-01549172⟩
465 Consultations
337 Téléchargements
