Atomic processors based on Spectral Hole Burning : modelling and application to wideband radiofrequency spectrum analysis on an optical carrier
Processeurs atomiques utilisant la propriété de creusement spectral : modélisation et application à l’analyse spectrale radiofréquence large bande sur porteuse optique
The Spectral Hole Burning property, found in some rare-earth ion-doped crystals at low temperature is particularly relevant for analogic processing of radiofrequency signals. Indeed, it enables processing functions to be programmed in the crystal’s absorption spectrum.Starting with the first demonstrations of a wideband radiofrequency spectrum analyser, we aim at improving its performances, which requires an accurate modelling of the light-matter interaction and all the perturbations arising from the upgrade in TRL (Technology Readiness Level). Therefore, we have developed a model and extended its validity domain to a broad variety of SHB-based protocols.We applied this model on a particular material, namely a Tm³ ⁺:YAG crystal. After measuring experimentally the relevant intrinsic parameters of this crystal, we applied our model to a protocol which is quite similar to the one of the spectrum analyser we aim at optimizing, namely the engraving of wideband spectral gratings. The comparison of our experimental results to the simulations from our model proved its validity.Finally we applied it to the exact case of the radiofrequency spectrum analyser. With the simulations, we determined how to improve its performances, and particularly increase the dynamic range with realistic experimental parameters.
La propriété de creusement spectral, que l’on retrouve dans certains cristaux dopés aux ions de terres rares refroidis à basse température offre des possibilités prometteuses pour le traitement analogique de signaux radiofréquence. En effet, celle-ci permet de programmer des fonctions de traitement dans le spectre d’absorption du cristal.Partant des premières démonstrations de principe d’un analyseur spectral radiofréquence large bande instantanée, l’objectif est d’en améliorer les performances, ce qui requiert une modélisation précise de l’interaction laser-matière et de l’ensemble des perturbations inhérentes à la montée en maturité technologique du dispositif. Nous avons par conséquent développé un modèle et cherché à étendre son domaine de validité pour qu’il s’applique à un maximum de protocoles.Nous l’avons ensuite appliqué à un matériau en particulier, à savoir un cristal de Tm³ ⁺ :YAG. Après avoir effectué une série de mesures des différentes caractéristiques intrinsèques à ce cristal, nous avons choisi un protocole d’application relativement proche de celui de l’analyseur spectral que nous cherchons à optimiser, à savoir la création de réseaux spectraux large bande. La comparaison des résultats expérimentaux à ceux de notre modèle nous a permis de démontrer sa validité.Nous avons finalement appliqué notre modèle au cas précis de l’analyseur spectral radiofréquence. Les simulations nous ont permis de déterminer théoriquement comment optimiser ses performances, en particulier la dynamique, avec des paramètres réalistes, atteignables expérimentalement.
