Good Practice in Large-Scale Learning for Image Classification, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.36, issue.3, 2014. ,
DOI : 10.1109/TPAMI.2013.146
URL : https://hal.archives-ouvertes.fr/hal-00835810
Uncovering shared structures in multiclass classification, Proceedings of the 24th international conference on Machine learning, ICML '07, 2007. ,
DOI : 10.1145/1273496.1273499
Consistency of trace norm minimization, The Journal of Machine Learning Research, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00179522
On the equivalence between herding and conditional gradient algorithms, Proceedings of the 29th International Conference on Machine Learning (ICML-12), ICML '12, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00681128
Optimization with Sparsity-Inducing Penalties, Machine Learning, pp.1-106, 2012. ,
DOI : 10.1561/2200000015
URL : https://hal.archives-ouvertes.fr/hal-00613125
Classification with a reject option using a hinge loss, The Journal of Machine Learning Research, 2008. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, 2009. ,
DOI : 10.1137/080716542
Smoothing and First Order Methods: A Unified Framework, SIAM Journal on Optimization, vol.22, issue.2, 2012. ,
DOI : 10.1137/100818327
NESTA: A Fast and Accurate First-Order Method for Sparse Recovery, SIAM Journal on Imaging Sciences, vol.4, issue.1, 2011. ,
DOI : 10.1137/090756855
URL : https://authors.library.caltech.edu/23706/1/Becker2011p13865Siam_J_Imaging_Sci.pdf
A smoothing technique for nondifferentiable optimization problems, Optimization, pp.1-11, 1989. ,
DOI : 10.1007/BFb0083582
Stochastic optimization problems with nondifferentiable cost functionals, Journal of Optimization Theory and Applications, vol.12, issue.2, pp.218-231, 1973. ,
DOI : 10.1016/0022-247X(65)90049-1
Nonlinear Programming, 2004. ,
Convex optimization, 2004. ,
Sparse and stable Markowitz portfolios, Proceedings of the National Academy of Sciences, pp.12267-12272, 2009. ,
DOI : 10.1214/009053604000000067
URL : https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2718382/pdf
On the week convergence of an ergodic iteration for the solution of variational inequalities for monotone operators in hilbert space, J. math. Anal, 1977. ,
Theory of convex optimization for machine learning, 2014. ,
A Limited Memory Algorithm for Bound Constrained Optimization, SIAM Journal on Scientific Computing, vol.16, issue.5, pp.1190-1208, 1995. ,
DOI : 10.1137/0916069
URL : http://www.ece.northwestern.edu/~nocedal/PSfiles/limited.ps.gz
Matrix Completion With Noise, Proceedings of the IEEE, 2010. ,
DOI : 10.1109/JPROC.2009.2035722
Exact matrix completion via convex optimization, Foundations of Computational mathematics, 2009. ,
The Convex Geometry of Linear Inverse Problems, Foundations of Computational Mathematics, vol.1, issue.10, pp.805-849, 2012. ,
DOI : 10.1007/978-1-4613-8431-1
Proximal splitting methods in signal processing In Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Dual subgradient algorithms for large-scale nonsmooth learning problems, Mathematical Programming, vol.120, issue.1, 2014. ,
DOI : 10.1017/S096249291300007X
URL : https://hal.archives-ouvertes.fr/hal-00978358
A Lanczos Algorithm for Computing Singular Values and Vectors of Large Matrices, SIAM Journal on Scientific and Statistical Computing, vol.4, issue.2, 1983. ,
DOI : 10.1137/0904015
Approximate methods in optimization problems, 1970. ,
What does classifying more than 10,000 image categories tell us? In Computer Vision, 2010. ,
DOI : 10.1007/978-3-642-15555-0_6
URL : http://www.cs.princeton.edu/%7Ejiadeng/DengBergLiFeiFei_ECCV2010.pdf
ImageNet: A Large-Scale Hierarchical Image Database, CVPR09, 2009. ,
First-order methods of smooth convex optimization with inexact oracle, Mathematical Programming, vol.110, issue.3, 2014. ,
DOI : 10.1007/978-3-642-82118-9
Efficient projections onto the l 1- ball for learning in high dimensions, Proceedings of the 25th international conference on Machine learning, pp.272-279, 2008. ,
Randomized Smoothing for Stochastic Optimization, SIAM Journal on Optimization, vol.22, issue.2, 2012. ,
DOI : 10.1137/110831659
Lifted coordinate descent for learning with tracenorm regularization, Proceedings of the 15th International Conference on Artificial Intelligence and Statistics (AISTATS), 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00756802
Collaborative Filtering Recommender Systems, Foundations and Trends?? in Human???Computer Interaction, vol.4, issue.2, pp.81-173, 2011. ,
DOI : 10.1561/1100000009
An algorithm for quadratic programming, Naval Research Logistics Quarterly, vol.3, issue.1-2, 1956. ,
DOI : 10.2140/pjm.1955.5.183
A Linearly Convergent Conditional Gradient Algorithm with Applications to Online and Stochastic Optimization ArXiv e-prints, pp.1301-4666, 2013. ,
DOI : 10.1137/140985366
Faster rates for the frank-wolfe method over strongly-convex sets, Proceedings of the 32nd International Conference on Machine Learning, 2015. ,
Support vector machines with a reject option, Advances in neural information processing systems, pp.537-544, 2009. ,
On Lower Complexity Bounds for Large-Scale Smooth Convex Optimization. ArXiv e-prints, pp.1307-5001, 2013. ,
Large-scale image classification with trace-norm regularization, 2012 IEEE Conference on Computer Vision and Pattern Recognition, 2012. ,
DOI : 10.1109/CVPR.2012.6248078
URL : https://hal.archives-ouvertes.fr/hal-00728388
Conditional gradient algorithms for machine learning, NIPS Workshop on Optimization for ML, 2012. ,
Conditional gradient algorithms for normregularized smooth convex optimization, Mathematical Programming, Series A, pp.1-30, 2014. ,
DOI : 10.1007/s10107-014-0778-9
URL : https://hal.archives-ouvertes.fr/hal-00978368
The Elements of Statistical Learning, 2008. ,
Sparse Approximate Solutions to Semidefinite Programs, LATIN 2008: Theoretical Informatics, pp.306-316, 2008. ,
DOI : 10.1007/978-3-540-78773-0_27
Projection-free online learning, ICML, 2012. ,
Fundamentals of Convex Analysis, 1993. ,
DOI : 10.1007/978-3-642-56468-0
Convex Analysis and Minimization Algorithms II (Grundlehren Der Mathematischen Wissenschaften), 1996. ,
Robust statistics, 1981. ,
DOI : 10.1002/0471725250
Combining social-based and information-based approaches for personalised recommendation on sequencing learning activities, International Journal of Learning Technology, vol.3, issue.2, 2007. ,
DOI : 10.1504/IJLT.2007.014842
Group lasso with overlap and graph lasso, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, pp.433-440, 2009. ,
DOI : 10.1145/1553374.1553431
URL : http://www.cs.mcgill.ca/~icml2009/papers/471.pdf
Revisiting Frank-Wolfe: Projection-free sparse convex optimization, ICML, pp.427-435, 2013. ,
A Simple Algorithm for Nuclear Norm Regularized Problems, ICML 2010: Proceedings of the 27th international conference on Machine learning, 2010. ,
First order methods for nonsmooth convex large-scale optimization . Optimization for Machine Learning, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00981863
Distributed cosegmentation via submodular optimization on anisotropic diffusion, 2011 International Conference on Computer Vision, pp.169-176, 2011. ,
Estimating the Largest Eigenvalue by the Power and Lanczos Algorithms with a Random Start, SIAM Journal on Matrix Analysis and Applications, vol.13, issue.4, 1992. ,
DOI : 10.1137/0613066
On the global linear convergence of frank-wolfe optimization variants, Advances in Neural Information Processing Systems, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01248675
Block-Coordinate Frank-Wolfe Optimization for Structural SVMs, ICML 2013, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00720158
Sequential kernel herding: Frank-wolfe optimization for particle filtering, AISTATS, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01099197
Probabilistic low-rank matrix completion on finite alphabets, Advances in Neural Information Processing Systems 27, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01081805
The Complexity of Large-scale Convex Programming under a Linear Optimization Oracle. ArXiv e-prints, 2013. ,
Linear differential operators, 1961. ,
Nonsmooth analysis of eigenvalues, Mathematical Programming, pp.1-24, 1999. ,
DOI : 10.1007/s10107980004a
Optimization with first-order surrogate functions, Proceedings of The 30th International Conference on Machine Learning, pp.783-791, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00822229
A wavelet tour of signal processing: the sparse way Academic press, 2009. ,
Portfolio selection. The journal of finance, 1952. ,
Automatic code generation for real-time convex optimization. Convex optimization in signal processing and communications, 2009. ,
DOI : 10.1017/cbo9780511804458.002
Real-Time Convex Optimization in Signal Processing, IEEE Signal Processing Magazine, vol.27, issue.3, 2010. ,
DOI : 10.1109/MSP.2010.936020
URL : http://www.stanford.edu/~boyd/papers/pdf/sig_proc_mag.pdf
MovieLens Unplugged: Experiences with a Recommender System on Four Mobile Devices, ACM SIGCHI Conference on Human Factors in Computing Systems, 2003. ,
DOI : 10.1007/978-1-4471-3754-2_16
Proximit?? et dualit?? dans un espace hilbertien, Bulletin de la Société mathématique de France, vol.79, pp.273-299, 1965. ,
DOI : 10.24033/bsmf.1625
Information-based complexity of mathematical programming, 1983. ,
Tekhnicheskaya Kibernetika (the journal is translated to English as Engineering Cybernetics, Soviet J. Computer & Systems Sci, p.1 ,
A method of solving a convex programming problem with convergence rate, Soviet Mathematics Doklady, pp.372-376, 1983. ,
Introductory lectures on convex optimization: A basic course, 2004. ,
DOI : 10.1007/978-1-4419-8853-9
Smooth minimization of non-smooth functions, Mathematical Programming, 2005. ,
DOI : 10.1007/s10107-004-0552-5
URL : http://dial.uclouvain.be/downloader/downloader.php?pid=boreal:4894&datastream=PDF_01&disclaimer=ae9d96a001442217ab652bd3df962abdbef8b43ca2512b82abc499488659738c
Gradient methods for minimizing composite objective function, CORE DISUSSION PAPER, vol.76, 2007. ,
DOI : 10.1007/s10107-012-0629-5
Smoothing Technique and its Applications in Semidefinite Optimization, Mathematical Programming, vol.16, issue.1, pp.245-259, 2007. ,
URL : http://dial.uclouvain.be/downloader/downloader.php?pid=boreal:4801&datastream=PDF_01&disclaimer=62e9ccb2bf13ebab29489ad5220c97fbc2cd7924b4ce607c36eb3ab804140423
Gradient methods for minimizing composite functions, Mathematical Programming, vol.51, issue.1, 2013. ,
DOI : 10.1109/TIT.2005.864420
Prisma: Proximal iterative smoothing algorithm, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00855993
Ergodic convergence to a zero of the sum of monotone operatorsin hilbert space, J. Math. Anal. Appl, 1979. ,
A smoothing approach for composite conditional gradient with nonsmooth loss, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01096630
Convex analysis (princeton mathematical series), 1970. ,
3D Hand Pose Detection in Egocentric RGB-D Images, Computer Vision-ECCV 2014 Workshops, 2014. ,
DOI : 10.1007/978-3-319-16178-5_25
URL : http://arxiv.org/pdf/1412.0065
Cosegmentation of Image Pairs by Histogram Matching - Incorporating a Global Constraint into MRFs, 2006 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Volume 1 (CVPR'06), 2006. ,
DOI : 10.1109/CVPR.2006.91
Convergence rates of inexact proximal-gradient methods for convex optimization, Advances in neural information processing systems, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00618152
Large-Scale Convex Minimization with a Low- Rank Constraint, ICML, 2011. ,
Maximum-margin matrix factorization, Advances in neural information processing systems. NIPS, 2004. ,
Greedy approximation in convex optimization. Constructive Approximation, 2012. ,
DOI : 10.1007/s00365-014-9272-0
Convex tensor decomposition via structured schatten norm regularization, Advances in neural information processing systems, 2013. ,
Simultaneous Variable Selection, Technometrics, vol.47, issue.3, 2005. ,
DOI : 10.1198/004017005000000139
Ranking with ordered weighted pairwise classification, Proceedings of the 26th Annual International Conference on Machine Learning, ICML '09, 2009. ,
DOI : 10.1145/1553374.1553509
URL : https://hal.archives-ouvertes.fr/hal-01297974
The nature of statistical learning theory, 2005. ,
Theory of pattern recognition, 1974. ,
Object cosegmentation, CVPR 2011, 2011. ,
DOI : 10.1109/CVPR.2011.5995530
Cofi rank -maximum margin matrix factorization for collaborative ranking, NIPS, 2007. ,
On ordered weighted averaging aggregation operators in multicriteria decisionmaking. Systems, Man and Cybernetics, IEEE Transactions on, 1988. ,
Model selection and estimation in regression with grouped variables, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.58, issue.1, pp.49-67, 2006. ,
DOI : 10.1198/016214502753479356
Accelerated training for matrix-norm regularization: A boosting approach, NIPS, 2012. ,
The composite absolute penalties family for grouped and hierarchical variable selection. The Annals of Statistics, pp.3468-3497, 2009. ,
DOI : 10.1214/07-aos584
URL : http://doi.org/10.1214/07-aos584
