Maternal and Neonatal Tolerance of Antiretroviral Treatment During Pregnancy in the HAART Era
Tolérance maternelle et néonatale des antirétroviraux pendant la grossesse à l’ère des multithérapies
Our objective was to study potential associations between antiretroviral treatment and obstetrical or neonatal complications in a population of HIV-positive pregnant women. Most of the analyses were conducted with data from the French Perinatal Cohort (ANRS-EPF), an ongoing multicenter national cohort with more than 20 000 mother-infant pairs included since 1986. In the recent years, most women receive combination antiretroviral therapies (cART ; 98% en 2013) and the trasnsmission rate is consistently under 1% : 0.6% (IC95% : 0.4%-0.8% for 2005-2013). Risk of preterm birth was significantly associated with cART, when compared to NRTI monotherapy or dual therapy, and with timing of treatment, higher for women treated at conception than for those initiating treatment during pregnancy. The occurrence of liver enzyme elevation was frequent (17%), and was associated both with preterm birth and with PI-based treatment, when compared to NNRTIs. LEE could be an intermediate factor between cART and preterm birth. The second part of this work was a study of congenital birth defect in the cohort, and showed an association between first trimester-exposure to efavirenz and neurological defects, but this concerned small numbers (n=4), and reached significance only in a sensitivity analysis. This association encourages us to maintain awareness concerning this molecule, considered teratogenic by the FDA but more and more largely prescribed. We also reported an association between first-trimester exposure to zidovudine and congenital heart defects. In a third part, we studied heart function, differences in contractility and septum thickness of the left ventricle was found, among girls exposed to a combination containing zidovudine and lamivudineThese results do not question the great progress of antiretroviral treatment in the prevention of mother-to-child transmission, but they encourage us to continue epidemiologic surveillance of potential side effects, in order to optimize prescriptions for an improved benefit/risk ratio.
L’objectif de cette thèse était d’étudier les associations potentielles entre les traitements antirétroviraux reçus par les femmes enceintes infectées par le VIH et les complications pouvant survenir au cours de la grossesse ou être diagnostiquées dans la période néonatale. Ce travail est issu en majeure partie des données de l’Enquête Périnatale Française (ANRS-EPF), cohorte nationale multicentrique ayant inclus plus de 20 000 couples mères-enfants depuis 1986. Actuellement, presque toutes les femmes sont traitées par combinaisons antirétrovirales puissantes (cART ; 98% en 2013) et le taux de transmission est inférieur à 1% : 0.6% (IC95% : 0.4%-0.8% pour la période 2005-2013). La première partie portait sur le risque d’accouchement prématuré dont le taux a augmenté significativement entre la période 1990-1993 et 2005-2009, passant de 9.2% à 14.3%. Le risque d’accouchement prématuré était significativement associé au traitement par cART, par rapport aux monothérapies et bithérapies d’INTI, et au traitement débuté avant la conception par rapport aux traitements débutés en cours de grossesse. La survenue d’une cytolyse hépatique était fréquente (17%), et était liée à la fois à la prématurité, et au type de traitement, plus fréquentes avec les IP qu’avec les inhibiteurs non nucléosidiques de la transcriptase inverse. La perturbation du bilan hépatique pourrait être un facteur intermédiaire dans la relation entre traitements et accouchement prématuré. La seconde partie portait sur les malformations congénitales. D’une part, elle a permis de mettre en évidence une association entre exposition à l’efavirenz au premier trimestre de grossesse et les malformations neurologiques, bien que concernant peu de cas (n=4) et n’atteignant la significativité que dans une analyse de sensibilité. Cette association incite à maintenir une vigilance chez les enfants exposés in utero à cette molécule classée tératogène par la FDA mais prescrite de plus en plus largement. D’autre part, l’exposition au premier trimestre à la zidovudine était associée à la survenue de malformations cardiaques. La troisième partie a complété cette étude par une analyse de la fonction cardiaque, des modifications infracliniques de la contractilité et de l’épaisseur des parois du ventricule gauche ont été mises en évidence chez les enfants exposés in utero à une combinaison de traitement contenant la zidovudine et la lamivudine. Ces résultats ne remettent pas en question l’efficacité majeure des traitements antirétroviraux pour la prévention de la transmission de la mère à l’enfant du VIH, mais incitent à la poursuite d’une surveillance épidémiologique des effets indésirables potentiels, de manière à optimiser les prescriptions pour un meilleur rapport bénéfice/risque.
