Development of a new metaheuristic optimization method for topology optimization of structures and metamaterials
Développement d'une nouvelle méthode metaheuristique pour l'optimisation topologique des structures et des metamatériaux
Based on a recent research concerning the PageRank algorithm used by the famous search engine Google, a new Inverse-PageRank-Particle Swarm Optimizer (I-PR-PSO) is developed, in order to improve the performances of classic PSO. After having been tested and validated on a benchmark
of classical mathematical functions, this algorithm has been validated on constrained optimization, applied on classical trusses of the literature. Interfaced with the Evolutionary Structural Optimization algorithm, this algorithm has shown its performances on topology optimization, applied to structural mechanics. Finally, using the performances of our newly developed algorithm, we have developed metamaterials. In electromagnetics, a frequantial cloaking device has been developed, minimizing the effective permeability of the considered Representative Volume Element. In mechanics, we have developed a metamaterial made of steel which exhibits hyper-elastic - or, at least, non linear -mechanical behaviour. Combining great displacements and rotations at microscale, the developed metamaterial exhibits great deformations at the macroscale as well.
L’optimisation offre la possibilité, dans de nombreux domaines, d’améliorer les performances d’un système donné, qu’il soit physique ou mathématique. Depuis quelques décennies, les méthodes d’optimisation metaheuristiques ont fait leurs preuves, notamment dans le domaine de la mécanique.
Du grec meta signifiant "un niveau au dessus", les metaheuristiques permettent de s’affranchir du calcul des sensibilités souvent problématique quant à la résolution de problèmes d’optimisation complexes et/ou NP difficiles. En outre, elles ont la capacité à analyser simultanément l’ensemble du
domaine des solutions, ce qui leur permet converger efficacement vers l’optimum global de la fonction objectif considérée. Notre travail propose le développement d’une nouvelle méthode metaheuristique intelligente, basée conjointement sur l’algorithme d’optimisation par essaim particulaire PSO, et l’algorithme PageRank développé par MM. Brin et Page, et utilisé par le moteur de recherche Google. Cet algorithme, appelé Inverse-PageRank-PSO (I-PR-PSO), a été validé sur un benchmark de fonctions mathématiques, puis en optimisation contrainte sur des treillis mécaniques. Interfacée
avec l’algorithme Evolutionary Structural Optimization (ESO), elle a été adaptée à l’optimisation topologique et a permis de trouver des résultats dont les topologies sont régulières et les temps de calcul minimisés. Dans le domaine des metamatériaux, nous avons développé une cape d’invisibilité
électromagnétique fréquentielle, c’est à dire un metamatériau dont les parties réelle et imaginaire de la perméabilité effective sont négatives. En appliquant notre algorithme I-PR-PSO aux metamatériaux mécaniques, nous avons montré qu’il est possible de développer un metamatériau constitué d’acier qui présente des grandes déformations à l’échelle macroscopique, dûes notamment aux grands déplacements présents dans le Volume Elémentaire Représentatif à l’échelle microscopique.
