Heat transfer modeling of power cables in tunnels
Modélisation du transfert thermique des câbles en galerie
A critical analysis of the thermal rating of power cables in tunnels is carried out, with the study of factors of influence specific to cable laying constrains. The heat generation in the cables, due to the transiting current, is dissipated by an axial turbulent forced convection and by radiation with the tunnel walls. To characterize this cooling, an experimental mock-up tunnel has been designed, modelling various cables in a fully-developed turbulent flow. The results are compared and bolstered by 3D numerical simulations, developed under the OpenFOAM code. The studies have highlighted an important underestimation of the convective exchange by the existing standard. Their cooling law is actually a sum of the effects of racks supporting the cables, for a third, and the effect of a flow still underdeveloped for another third. The last third being the actual cooling of the cables. The impact of groups configurations is also studied, with an astonishing result for groups of two cables, which are better cooled than a single cable case, when installed close to a wall. Following the analysis, a single conservative cooling law is proposed to model all studied cases. This law has a significant impact on the permissible current in the cables, which is downgraded from 5% to 9% from previous ratings.
Une analyse critique de la modélisation des échanges thermiques des câbles d’énergie en galerie est réalisée, avec l’étude de facteurs d’influences propres aux modes de pose des câbles dans ces ouvrages. Les câbles, de plusieurs kilomètres, chauffent du fait du courant transmis dans leurs âmes. Ils sont alors refroidis par une convection forcée turbulente, dans l’axe des câbles, et échangent par rayonnement avec les parois. Pour étudier ce refroidissement, un banc d’essais expérimental a été conçu, en similitude de Reynolds, modélisant différents câbles soumis à un écoulement turbulent développé. Les résultats sont comparés et étayés par des simulations numériques 3D, développées sous l’outil OpenFOAM. Les études réalisées ont permis de mettre en évidence la mésestimation importante de l’échange convectif par la norme existante. Celle-ci propose un refroidissement qui se compose en réalité pour un tiers de l’effet de supports maintenant les câbles et d’un autre tiers d’un écoulement encore en début d’établissement. Le dernier tiers étant le refroidissement effectif des câbles. L’impact des groupements des câbles est aussi étudié, avec un résultat étonnant où un groupe de deux câbles en nappe est trouvé mieux refroidis qu’un seul, lorsque ceux-ci sont placés en proche paroi de la galerie. A l’issue des travaux, une unique loi de refroidissement conservative est proposée, permettant de modéliser tous les cas traités. Cette loi a un impact important sur l’intensité maximale admissible des câbles, qui est dégradée de 5% à 9% par rapport à précédemment pour un cas idéalisé.
