Learning approaches for large-scale remote sensing image classification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Approches d'apprentissage pour la classification à large échelle d'images de télédétection
The analysis of airborne and satellite images is one of the core subjects in remote sensing. In recent years, technological developments have facilitated the availability of large-scale sources of data, which cover significant extents of the earth’s surface, often at impressive spatial resolutions. In addition to the evident computational complexity issues that arise, one of the current challenges is to handle the variability in the appearance of the objects across different geographic regions. For this, it is necessary to design classification methods that go beyond the analysis of individual pixel spectra, introducing higher-level contextual information in the process. In this thesis, we first propose a method to perform classification with shape priors, based on the optimization of a hierarchical subdivision data structure. We then delve into the use of the increasingly popular convolutional neural networks (CNNs) to learn deep hierarchical contextual features. We investigate CNNs from multiple angles, in order to address the different points required to adapt them to our problem. Among other subjects, we propose different solutions to output high-resolution classification maps and we study the acquisition of training data. We also created a dataset of aerial images over dissimilar locations, and assess the generalization capabilities of CNNs. Finally, we propose a technique to polygonize the output classification maps, so as to integrate them into operational geographic information systems, thus completing the typical processing pipeline observed in a wide number of applications. Throughout this thesis, we experiment on hyperspectral, atellite and aerial images, with scalability, generalization and applicability goals in mind.
L’analyse des images satellite et aériennes figure parmi les sujets fondamentaux du domaine de la télédétection. Ces dernières années, les avancées technologiques ont permis d’augmenter la disponibilité à large échelle des images, en comprenant parfois de larges étendues de terre à haute résolution spatiale. En plus des questions évidentes de complexité calculatoire qui en surgissent, un de plus importants défis est l’énorme variabilité des objets dans les différentes régions de la terre. Pour aborder cela, il est nécessaire de concevoir des méthodes de classification qui dépassent l’analyse du spectre individuel de chaque pixel, en introduisant de l’information contextuelle de haut niveau. Dans cette thèse, nous proposons d’abord une méthode pour la classification avec des contraintes de forme, basée sur l’optimisation d’une structure de subdivision hiérarchique des images. Nous explorons ensuite l’utilisation des réseaux de neurones convolutionnels (CNN), qui nous permettent d’apprendre des descripteurs hiérarchiques profonds. Nous étudions les CNN depuis de nombreux points de vue, ce qui nous permettra de les adapter à notre objectif. Parmi les sujets abordés, nous proposons différentes solutions pour générer des cartes de classification à haute résolution et nous étudions aussi la récolte des données d’entrainement. Nous avons également créé une base de données d’images aériennes sur des zones variées, pour évaluer la capacité de généralisation des CNN. Finalement, nous proposons une méthode pour polygonaliser les cartes de classification issues des réseaux de neurones, afin de pouvoir les intégrer dans des systèmes d’information géographique. Au long de la thèse, nous conduisons des expériences sur des images hyperspectrales, satellites et aériennes, toujours avec l’intention de proposer des méthodes applicables, généralisables et qui passent à l’échelle.
2017AZUR4041.pdf (7.92 Mo) Télécharger le fichier
tel-01589661 , version 1 (18-09-2017)
tel-01589661 , version 2 (22-09-2017)
  • HAL Id : tel-01589661 , version 2
Emmanuel Maggiori. Learning approaches for large-scale remote sensing image classification. Other. Université Côte d'Azur, 2017. English. ⟨NNT : 2017AZUR4041⟩. ⟨tel-01589661v2⟩
739 Consultations
655 Téléchargements
