AGuIX, a theranostic nanoparticle to improve image-guided radiation therapy : a proof ofconcept in pancreatic cancer
AGuIX, une nanoparticule théranostique pour améliorer la radiothérapie guidée par l’image : preuve de concept appliquée au cancer du pancréas
Previous studies demonstrated AGuIX ability to act as an efficient radiosensitizer under the presence of preclinical radiations or monoenergetic radiation beams for multiple cancer models. The preclinical irradiation (220 kV) has been shown effective in activating high atomic number (Z) nanoparticles. The energy peak is close to the k-edge of the different high-Z elements used (50.2 keV for the gadolinium), leading to a strong photoelectric effect. Auger electrons generation and biological effects occur afterwards creating a local dose enhancement. However, clinical treatments use a higher energy beam (>6 MV). At these energy ranges, the photoelectric probability is less important, decreasing the direct interaction of the nanoparticles with the incoming photons. We performed a proof of concept on a pancreatic tumor model, known for its low survival rates, with preclinical and clinical radiation beams to evaluate the efficacy of the AGuIX. To increase the efficacy of the clinical radiation beam without modifying the nanoparticle structure in order to obtain a dose enhancement close to the one observed with the preclinical beam, we evaluated key clinical beam parameters to understand and increase the mechanisms of interaction between the incident photons and the high-Z nanoparticles. Hence, we evaluated analytically the impact of the radiation beam under different conditions of irradiation, confirming the potential of the AGuIX with a preclinical beam, and finally shown their significant efficacy under a clinical setup. This study is the first to evaluate the potential of a high-Z nanoparticle to act as radiosensitizer following low dose intravenous injections
L'efficacité des nanoparticules AGuIX a été démontré avec des irradiations précliniques ou monoénergétiques pour les cancers du cerveau, tête et cou, et poumon. L'irradiation préclinique de faible énergie (220 kV), et l'irradiation clinique (6 MV) sont adaptées pour activer les nanoparticules. L'effet radiosensibilisant des nanoparticules métalliques étant principalement causé par effet photoélectrique, il est nécessaire d'utiliser des photons d'énergie proche de la raie K du gadolinium (50.2 keV) afin de créer une interaction avec les électrons de l'atome dans le but d'amplifier localement la dose autour des nanoparticules aboutissant à des effets biologiques menant à une augmentation de la mort cellulaire. Dans le cadre de cette thèse, nous avons réalisé une preuve de concept sur le cancer du pancréas, connu pour son faible taux de survie, avec machines précliniques et cliniques. Afin de relever le défi du passage en clinique, nous avons proposé une méthode pour créer un adoucissement du faisceau d'irradiation et démontré la possibilité d'utiliser les nanoparticles AGuIX pour un essai clinique. Les travaux de recherche ont été réalisés en trois temps : un calcul analytique permettant d'obtenir une information sur l'influence des différents paramètres d'irradiation, une confirmation de l'efficacité des nanoparticules avec faisceaux précliniques, et enfin une preuve de concept avec faisceaux cliniques. Notre étude avec faisceaux cliniques est la première étude réalisée démontrant l'efficacité de nanoparticules de gadolinium passivement ciblées vers la tumeur, et démontre qu'il est possible d'obtenir des résultats cliniques similaires à ceux obtenus en préclinique
