Avaliação estrutural e funcional de novos peptídeos antimicrobianos obtidos a partir de desenho racional - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Structural and functional evaluation of novel antimicrobial peptides obtained by rational design
Evaluation structurelle et fonctionnelle de nouveaux peptides antimicrobiens obtenus par conception rationnelle
Antimicrobial peptides (AMPs) have been considered as a potential novel class of antimicrobial compounds. In order to generate new potent and non-toxic antimicrobial agents, rational design strategies may be employed. In this view, we used a computational method to design three synthetic AMPs ([I5, R8] MP, EcDBS1R6 and PaDBS1R1). By determining the minimum inhibitory concentration, we found that all the peptides were active against Gram-negative and -positive bacteria. Only [I5, R8] MP was found to display antifungal activity. The determination of the peptide concentration producing 50% of cell lysis revealed low or no hemolytic activity, with no cytotoxicity towards human embryonic kidney cells HEK-293. During time-kill assays more rapid bactericidal effects were observed for PaDBS1R1 and [I5, R8] MP against E. coli compared to S. aureus. For the peptide EcDBS1R6, identical killing curves were obtained for both bacterial strains. Membrane permeabilization and depolarization studies combined with field emission gun scanning electron microscopy (SEM-FEG) revealed that a membranolytic mechanism occurs for these peptides. When analyzed by circular dichroism and nuclear magnetic resonance microscopy or by molecular dynamics simulations during interaction with a membrane model, peptides were shown to adopt an amphipathic alpha-helical conformation. In conclusion, our results indicate that the structural and functional evaluation of rationally designed synthetic AMPs represents a promising strategy for the development of potent novel antimicrobial agents.
Les peptides antimicrobiens sont considérés comme une nouvelle classe prometteuse d'agents anti-infectieux. Afin de développer de nouveaux agents efficaces et non toxiques, des stratégies de conception rationnelle peuvent être utilisées. Dans cette perspective, nous avons utilisé une approche computationnelle pour concevoir trois peptides synthétiques ([I5, R8] MP, EcDBS1R6 et PaDBS1R1). En déterminant la concentration minimale inhibitrice, nous avons montré que tous les peptides sont actifs contre les bactéries Gram-négatif et -positif. Seul [I5, R8] MP a montré une activité antifongique. La mesure de la concentration de peptide provoquant 50 % de mortalité cellulaire a permis de montrer que les peptides étaient faiblement ou non hémolytiques, sans toxicité vis-à-vis des cellules embryonnaires rénales humaines HEK-293. La cinétique bactéricide a révélé que PaDBS1R1 et [I5, R8] MP tuent rapidement E. coli en comparaison à S. aureus et que EcDBS1R6 élimine rapidement les deux souches. Des études de perméabilisation et de dépolarisation combinées à de la microscopie électronique à haute résolution (FEG-SEM) ont montré un mécanisme membranolytique des peptides. L'analyse de la structure des peptides par spectroscopie de dichroïsme circulaire et résonance magnétique nucléaire, ainsi que par modélisation moléculaire lors de leur interaction avec une membrane modèle, révèle une conformation en hélice alpha amphipatique. En conclusion, notre étude indique que l'évaluation structurale et fonctionnelle de peptides antimicrobiens synthétiques conçus de manière rationnelle représente une stratégie prometteuse pour le développement de nouveaux agents antimicrobiens.
2016PA066418.pdf (4.06 Mo) Télécharger le fichier
tel-01591166 , version 1 (21-09-2017)
  • HAL Id : tel-01591166 , version 1
Luz Noemi Irazazabal. Avaliação estrutural e funcional de novos peptídeos antimicrobianos obtidos a partir de desenho racional. Infectious diseases. Université Pierre et Marie Curie - Paris VI; Universidade de Brasília, 2016. Portuguese. ⟨NNT : 2016PA066418⟩. ⟨tel-01591166⟩
267 Consultations
657 Téléchargements
