Printing and poetical practices in the society in Cordova in Low Baroque (1650-1750)
Imprenta y prácticas poéticas en la sociedad cordobesa del Bajo Barroco (1650-1750)
Imprimerie et pratiques poétiques au sein de la société cordouane du Bas Baroque (1650-1750)
The present thesis, focusing on the study of the poetry printed in Cordova between 1650-1750, it´s an advance in the field opened between the positivist tradition and the innovations in the area of the interpretation, including the sociology of the texts and of the functioning of the works. In the recent years a renovation has appeared in this field, in which the present thesis registers, advancing in a consideration of character to interdisciplinary that it overcomes the existing distances between the former methodologies of the literary studies and his analysis of the texts in stylistic way, with his attention to the material processes, as those of the press and the traffic of the book and the sociology with the relations of authors and readers and the networks that they formed. For the development of the investigation I have the direction from the University of Cordova of Prof. Pedro Ruiz Perez (PHEBO) and for the specialization in press and edition and sociology with Jean-Marc Buiguès (AMERIBER) and the University of Bordeaux 3 Montaigne. This is the start point of the conceptual frame, that considers the convenience of not separating the own work camps of the analysis of the poetry, the history of the edition, the networks of sociology and the resources provided by the new technologies. The methodological model starts of these expositions and takes form of a double line of work: Creation of a bibliography (non-existent up to the date) with support in the tools of the digital humanities (databases, digitized corpuses, etc.) and, of another part, the model of analysis tested in the work on press and poetry, fields respectively developed by both mentioned directors. The conjunction of both allows an new approximation of the questions related to the production, traffic and reading of the texts and his value in a literary field in development.
La presente tesis se centra en el estudio y repertorio de la poesía impresa en Córdoba entre 1650-1750. Se plantea como un avance metodológico en el campo de la tradición positivista y la recepción poética, a partir de la bibliografía y la sociología de los textos. La investigación se inscribe en el marco de cotutela internacional entre la Universidad de Córdoba y l´Université Bordeaux Montaigne, siendo los codirectores de la misma el Prof. Pedro Ruiz Pérez (PHEBO) y el Prof. Jean-Marc Buiguès (AMERIBER), respectivamente. Este trabajo avanza sobre una consideración de carácter interdisciplinar que aúne las metodologías de la literatura, la bibliografía y las Humanidades digitales. Se focaliza la atención en la poesía impresa, atendiendo a los procesos materiales, como la manufactura de las obras mediante la imprenta, la circulación del libro y la red de relaciones sociales-literarias entre autores, lectores e impresores. Radica aquí el marco conceptual de salida, que considera la conveniencia de no separar los campos de trabajo propios del análisis de la poesía, la historia de la edición, las redes de sociabilidad y los recursos proporcionados por las nuevas tecnologías. El modelo metodológico arranca de estos planteamientos y se plasma en la elaboración del repertorio catalográfico que albergue a todas las ediciones impresas que contengan algún verso (inexistente hasta la fecha), un directorio biográfico de todos los agentes literarios que intervengan en la producción de la obra y dos bases de datos relacionales que contenga dicha información, concebidas dentro del marco de las Humanidades Digitales. Esto permitirá un nuevo acercamiento a las cuestiones relacionadas con la producción, circulación y recepción de la poesía. En resumen, esta investigación dotará de las herramientas necesarias para definir la práctica del verso en la sociedad bajobarroca cordobesa.
Cette thèse, centrée sur l'étude de la poésie imprimée à Cordoue entre 1650-1750, est conçue comme une avancée dans le champ de recherche laissé libre ente la tradition positiviste et les innovations dans le domaine de l'interprétation, notamment dans la sociologie des textes et l'exploitation des oeuvres. Cette thèse s’inscrit dans le renouvellement qui s’est produit ces dernières années dans ce domaine et qui a fait progresser les études grâce à une nouvelle dimension de nature interdisciplinaire, au-delà des clivages entre les anciennes méthodologies d'études littéraires et leur analyse des textes basée sur la stylistique, et par l’attention accordée aux processus matériels, comme l'impression et la diffusion du livre, la sociologie des relations auteurs/lecteurs, et les réseaux ainsi formés. Pour développer cette recherche, je bénéficierai d’une double direction, celle du professeur Pedro Ruiz Pérez (PHEBO) de l'Université de Cordoue (Espagne), spécialiste de poésie, et de celle du professeur Jean-Marc Buiguès (AMERIBER) de l'Université de Bordeaux Montaigne, spécialiste de l’imprimerie, de l’édition et de la sociologie des auteurs. Le cadre conceptuel de départ pose qu’il est préférable de ne pas séparer les champs de travail de l'analyse de la poésie, de l'histoire de l'édition, des réseaux de sociabilité et des ressources fournies par les nouvelles technologies. Le modèle méthodologique prend appui sur ces approches et s’articule en une double ligne de travail : le développement d’un corpus (inexistant à ce jour) basé sur les outils des humanités numériques (bases de données, corpus numérisé, etc.) et d'autre part sur le modèle d'analyse mis à l'essai dans les travaux sur l'imprimerie et la poésie, développés respectivement par les deux directeurs. La combinaison des deux permet une approche nouvelle des questions liées à la production, la circulation et la lecture des textes et à leur valeur dans un champ littéraire en développement.
