Développement de modèles in vitro de rétinites pigmentaires à partir de cellules souches pluripotentes humaines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Development of in vitro models of retinitis pigmentosa using patient-specific pluripotent stem cells
Retinitis pigmentosa (RP) is an inherited retinal diseases characterized by a loss of photoreceptors. We focused specific forms of autosomal dominant RP with mutations in the rod visual pigment RHODOPSIN, the ubiquitous splicing factor PRPF31 and the transcription factor involved in the development of photoreceptors NR2E3. Fibroblasts from skin biopsies of patients were reprogrammed into iPS cells by a non-integrative approach. After stabilization of iPS cell lines, we verified their pluripotency property and the absence of karyotype abnormalities. Based on the retinal differentiation protocol, iPS cells carrying a mutation in the RHODOPSIN gene have been differentiated in the photoreceptor lineage. Our results showed that the photoreceptors expressing the mutated form of RHODOPSIN summarizing the process of degeneration observed in RP patients. We show that retinal pigment epithelium (RPE) cells derived from iPS cells carrying a mutation in the PRPF31 gene lack basal membranes and have cell adhesion disorders. Consequently, their phagocytic activity is disturbed, suggesting that a malfunction of the RPE could be the primary step of the development of RP caused by mutation Cys294X in the PRPF31 gene. The models developed from specific-patient iPS cells have enabled us to better understand the processes underlying the pathogenesis of some RP. These models associated with screening protocols could be used to evaluate the efficacy and toxicity of new pharmacologic compounds but also used to validate new gene therapy approaches.
Les rétinites pigmentaires (RP) sont des pathologies rétiniennes cécitantes d'origine génétique caractérisées par une perte des photorécepteurs. Nous avons ciblé des formes de RP autosomique dominante consécutives à des mutations dans le gène du pigment visuel de la RHODOPSINE, du facteur d'épissage PRPF31 et du facteur de transcription impliqué dans le développement des photorécepteurs NR2E3. Les fibroblastes, issus de biopsies de peau de patients, ont été reprogrammés en cellules iPS par une technique dite non intégrative. Après stabilisation des cellules iPS, nous avons vérifié leur propriété de pluripotence et l'absence d'anomalies caryotypiques.Les cellules iPS porteuses d'une mutation sur le gène RHODOPSINE ont été différenciées dans le lignage des photorécepteurs. Nos résultats montrent que les photorécepteurs porteurs de la mutation P347L du le gène RHODOPSINE récapitulent la dégénérescence observée chez les patients.Nous montrons que les cellules de l'épithélium pigmentaire rétinien (EPR) dérivées de cellules iPS porteuses de la mutation Cys294X du gène PRPF31 présentent des problèmes d'adhésion cellulaire due à l'absence de lame basale. Leur activité de phagocytose est alors perturbée, suggérant qu'un dysfonctionnement de l'EPR pourrait être à la base de la RP causée par la mutation Cys294X du gène PRPF31. Les modèles développés nous ont permis de mieux comprendre les processus à la base de la pathogénèse de certaines RP. Ces modèles associés à des protocoles de criblage, pourraient permettre d'évaluer l'efficacité et la toxicité de nouvelles molécules pharmacologiques, mais également être utilisés pour valider des approches de thérapie génique.
2015PA066614.pdf (13.4 Mo) Télécharger le fichier
tel-01592260 , version 1 (23-09-2017)
  • HAL Id : tel-01592260 , version 1
Angélique Terray. Développement de modèles in vitro de rétinites pigmentaires à partir de cellules souches pluripotentes humaines. Biologie cellulaire. Université Pierre et Marie Curie - Paris VI, 2015. Français. ⟨NNT : 2015PA066614⟩. ⟨tel-01592260⟩
450 Consultations
995 Téléchargements
