On the lifecycle of Antarctic Bottom Water - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Eléments du cycle de vie de l'Eau Antarctique de Fond
Antarctic Bottom Water is the most voluminous water mass of the World Ocean, and it feeds the deepest and slowest component of ocean circulation. The processes that govern its lifecycle are therefore key to the ocean's carbon and heat storage capacity on centennial to multi-millennial timescales. This thesis aims at characterizing and quantifying processes responsible for the destruction (synonymous of lightening and upwelling) of Antarctic Bottom Water in the abyssal ocean. Using an observational estimate of the global ocean thermohaline structure and diagnostics based on the density budget of deep waters, we explore the roles of basin geometry, geothermal heating and mixing by breaking internal waves for the abyssal circulation. We show that the shape of ocean basins largely controls the structure of abyssal upwelling. The contribution of mixing powered by breaking internal waves, though poorly constrained, is estimated to be insufficient to destroy Antarctic Bottom Water at a rate comparable to that of its formation. Geothermal heating plays an important role for the upwelling of waters covering large seafloor areas. The results suggest a reappraisal of the role of mixing in deep straits and sills, but also of the fundamental role of basin geometry, for the lightening and transport of abyssal waters.
L'Eau Antarctique de Fond constitue la principale masse d'eau océanique par son volume, et nourrit la composante la plus profonde et la plus lente de la circulation océanique. Les processus qui régissent son cycle de vie sont donc clé pour la capacité de stockage de l'océan en carbone et chaleur aux échelles centennales à multi-millénaires. Cette thèse tente de caractériser et quantifier les principaux processus responsables de la destruction (synonyme d'allègement et de remontée) de l'Eau Antarctique de Fond dans l'océan abyssal. A partir d'une estimée issue d'observations de la structure thermohaline de l'océan mondial et de diagnostics fondés sur le budget de densité des eaux profondes, les rôles respectifs du chauffage géothermal, du mélange turbulent par déferlement d'ondes internes et de la géométrie des bassins sont évalués. Il est montré que la géométrie de l'océan gouverne la structure de la circulation de l'Eau Antarctique de Fond. La contribution du déferlement des ondes internes, bien que mal contrainte, est estimée insuffisante pour maintenir un rythme de destruction de l'Eau Antarctique de Fond comparable à celui de sa formation. Le chauffage géothermal a quant à lui un rôle important pour la remontée des eaux recouvrant une large surface du lit océanique. Les résultats suggèrent une réévaluation de l'importance du mélange au niveau des détroits et seuils profonds, mais aussi du rôle fondamental de la forme des bassins, pour l'allègement et le transport des eaux abyssales.
2016PA066373.pdf (18.19 Mo) Télécharger le fichier
tel-01592475 , version 1 (25-09-2017)
  • HAL Id : tel-01592475 , version 1
Casimir de Lavergne. On the lifecycle of Antarctic Bottom Water. Oceanography. Université Pierre et Marie Curie - Paris VI, 2016. English. ⟨NNT : 2016PA066373⟩. ⟨tel-01592475⟩
735 Consultations
177 Téléchargements
