Approche épidémiologique de la fragilité - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
The epidemiological approach of frailty
Maturin Tabue Teguo
  • Fonction : Auteur
  • PersonId : 783974
  • IdRef : 175400768
Now-a-days, geriatric syndromes have become a major public health problem owing to the population aging. In this context, frailty syndrome represents particularly a public health priority in France through PAERPA program. Frailty is defined as an extreme vulnerability of the organism to endogenous and exogenous stressors. This syndrome exposes the individual at higher risk of negative health-related outcomes as well as a transition phase between successful aging and disability. The theoretical concept of frailty is largely agreed, its practical translation still presents some limitations due to the existence of multiple tools and operational definitions. The definition most widely used is the one proposed by Fried and collaborators which essentially includes physical elements. Nonetheless, the inclusion of other non-physical components, in particular cognitive function, social vulnerability state, morbidities is currently debated. Considerable progress has been made in this field over the past ten years. The prevalence and incidence of frailty are reported in several epidemiological studies and are well known, but are quite variable. Many risk factors of frailty have been highlighted, leaving a door open towards prevention. A better knowledge of frailty epidemiology is therefore essential if we are to assess its extent and the means of controlling it. To better define frailty from an epidemiological point of view, it is essential to describe and better understand the different components of epidemiological prognostic studies: describing, prediction of health events, explaining the causal relation and proposing the action. The aim of this thesis was to the study, from an epidemiological point of view, the definition of frailty using the data of three French cohorts: PAQUID, 3C and INCUR. The results are consistent with an association between frailty and negative health-related outcomes. This association depends on the target sample, tools used and investigators.
En raison du vieillissement de la population, les syndromes gériatriques sont devenus un enjeu majeur de santé publique, et le syndrome de fragilité une priorité notamment en France avec le programme PAERPA. La fragilité permet d’identifier des personnes âgées présentant des capacités de résistance diminuées face aux agents agresseurs. Elle a pour conséquence d’accroître chez l’individu le risque de survenu d’évènements de santé défavorables (de dépendance, de chutes, d’hospitalisations, d’entrée en institution et de mortalité). Plusieurs outils de mesure sont développés mais aucune mesure de référence ne fait consensus actuellement même si des progrès considérables ont été réalisés dans ce domaine depuis une dizaine d’années. Les données épidémiologiques sur la prévalence, l’incidence et les conséquences de la fragilité ont été abondamment publiées mais se caractérisent par une grande variabilité. Ces indicateurs sont variables en fonction de l’outil de mesure utilisé, de la population étudiée, de l’examinateur et également de l’évènement de santé que l’on veut prédire. De nombreux facteurs de risque de fragilité ont été également mis en évidence et certains ouvrent des voies crédibles de recherche aidant à la prévention. Une meilleure connaissance de l’épidémiologie du syndrome de fragilité est donc une nécessité incontournable pour apprécier l’importance du phénomène et mettre en place les moyens de le contrôler. Afin de mieux définir la fragilité sur le plan épidémiologique, il est indispensable de bien comprendre la notion d’études pronostiques en épidémiologie et les principaux domaines qui la constituent c’est-à-dire : décrire la population, prédire des évènements de santé, comprendre les liens de causalité et proposer des actions. Il est donc indispensable dans les études épidémiologiques, de définir et d’utiliser avec précision les principaux domaines des études pronostiques décrit ci-dessus. Le risque ici est un passage sans précaution de la prédiction à la compréhension du concept de fragilité qui sont deux domaines différents bien que complémentaires. La définition la plus utilisée de la fragilité reste encore celle proposée par Fried et collaborateurs. Elle est basée sur la prise en compte d’éléments essentiellement physiques. Cette définition a de nombreuses limites lorsque la population cible vit en EHPAD par exemple. D’autres composantes non physiques parmi lesquelles la cognition, les vulnérabilités sociales, les comorbidités sont actuellement débattue pour mieux définir le concept de fragilité et identifier ses biomarqueurs. Cette thèse aborde d’un point de vue épidémiologique la définition du syndrome de fragilité grâce aux données des cohortes PAQUID et 3C (deux études Françaises en population) et la cohorte INCUR (une étude Française en EHPAD). Les résultats présentés dans cette thèse nous permettent d’affirmer que la relation entre la fragilité et la prédiction d’évènements défavorables de santé prend en compte la population cible, l’outil de mesure de la fragilité et l’examinateur. Ce résultats ouvrent donc des perspectives intéressantes pour la recherche sur le syndrome fragilité quelques soit les caractéristiques des populations étudiées.
TABUE_TEGUO_MATURIN_2016.pdf (7.75 Mo) Télécharger le fichier
tel-01592477 , version 1 (25-09-2017)
  • HAL Id : tel-01592477 , version 1
Maturin Tabue Teguo. Approche épidémiologique de la fragilité. Santé publique et épidémiologie. Université de Bordeaux, 2016. Français. ⟨NNT : 2016BORD0430⟩. ⟨tel-01592477⟩
722 Consultations
762 Téléchargements
