Etude expérimentale et simulation numérique de propagation de fissures dans un acier inoxydable martensitique durci par précipitation sous conditions représentatives en termes de température, spectre de chargement et vieillissement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Experimental Study and Numerical Simulation of Fatigue Crack Growth in Precipitation-Hardened Martensitic Stainless Steel (15-5PH) Under Representative Conditions of the Operating Environment : Variable Amplitude Loading, Long Term Ageing and Temperature
Connecting the turbofan engine to the wing of the aircraft, the engine pylon is a true « masterpiece » of the aircraft. Indeed, it transmits all the aircraft engine efforts. It is subject to temperature variations from -40°C in cruise to 290°C-400°C during take off and landing. In addition, the engine pylon is a prey to very high vibratory stresses, which should be properly taken into account during damage tolerances analysis to avoid the loss of the aircraft. Between 290°C and 400°C, the martensite of components in precipitation-hardenable stainless steel (15-5 PH) of engine pylon undergoes microstructural transformation (« ageing »). This ageing has a significant impact on the mechanical properties, characterized by an increase in yield strength and tensile stress and drastic reduction in toughness and ductility. To complete the characterization of the effects of ageing on the mechanical properties while considering that these structures are designed according to a principle of damage tolerance, the aim of this work is to study the fatigue crack growth behavior (FCGB) of this material according to the ageing conditions and the test temperature. The approach is based on knowledge of monotonous and cyclic behavior to analyze the fatigue crack mechanisms. The cyclic behavior tests have been carried out at room temperature and 300°C at different strains imposed levels, on the 15-5PH steel in its as-received and then to the ageing conditions realized, between 300°C and 400°C and exposure times of up to 10 000h. The results highlight the lack of influence of ageing on the cyclic hardening of 15-5 PH steel, both at room temperature to 300°C. For the range of ΔK values tested, the FCGB of the 15-5PH steel under constant load amplitude is not affected by ageing. However, the extent of the stable propagation domain is itself reduced according to the degree of aging at room temperature. This reduction is due to the fall of fracture toughness due to ageing. The fracture surfaces are mainly transgranular for all conditions examined. However, the areas close to the final rupture ofsome ageing statements present islands indicative of a static failure mode at room temperature. These islands are absent to 300°C.Under the effect of repeated loads, a delayed effect on the crack velocity has been demonstrated. This delay is a function of the overload rate, overload period, the number of overloads and the baseline load ratio, but insensitive to ageing. Furthermore, are duction in the extent of the area stable propagation is also noticed at room temperature. Fatigue crack growth simulations undervariable amplitude loading were made through the incremental model for damage tolerance analysis developed by LMT-Cachan. The model results were then subject to a comparison with the PREFFAS model used at AIRBUS. The incremental model is well aware ofsome of the effects of repeated overloads. It also proves less conservative than the model PREFFAS. For taking account the effects of ageing in the incremental model, simply report the hardening observed on old material, the cyclic hardening parameters are notaffected. A methodology based on time/temperature equivalence provided by Hollomon-Jaffe - and taking into account the effects of ageing in the incremental model is finally proposed.
Reliant le moteur à turboréacteur à la voilure de l’avion, le mât-réacteur est une véritable « pièce maitresse » de l’avion. En effet, il transmet tous les efforts de l’avion au moteur. Il est soumis à des variations de températures allant de -40°C en croisière à290°C voir 400°C lors des phases de décollage. En plus, le mât-réacteur est à la merci de contraintes vibratoires très élevées qui,n’étant pas correctement maitrisées lors des analyses en tolérances aux dommages, peuvent conduire à la ruine de l’appareil. Entre290°C et 400°C, la martensite constitutive des composants en acier inoxydable martensitique durci par précipitation (15-5PH) du mât-réacteur, subit donc un vieillissement par transformation microstructurale. Ce vieillissement a un impact considérable sur les propriétés mécaniques, à savoir à une augmentation de la limite d’élasticité et de la contrainte à rupture aux dépens d’une réduction drastique de la ténacité et la ductilité. Afin de compléter la caractérisation des effets du vieillissement sur les propriétés mécaniques tout en considérant que ces structures sont dimensionnées suivant un principe de tolérance aux dommages, l’objectif de ce travail est d’étudier la résistance à la fissuration par fatigue de cet acier en fonction du vieillissement et de la température d’essai. La démarche adoptée repose sur une connaissance des comportements monotone et cyclique pour analyser les mécanismes en fissuration. Des essais de comportement cyclique ont ainsi été effectués à la température ambiante et à 300°C à différents niveaux de déformation imposés, sur l’acier 15-5PH dans son état de réception, puis pour des conditions vieillissement réalisées entre 300°C et 400°C et des temps d’exposition allant jusqu’à 10 000h. Les résultats obtenus mettent en évidence l’absence d’influence du vieillissement sur l’écrouissage cyclique de l’acier 15-5PH, aussi bien à température ambiant qu’à 300°C. Pour la plage de valeurs de ΔK balayée, le comportement en fissuration de l’acier 15-5PH sous amplitude de chargement constante n’est pas modifié par le vieillissement.Cependant, l’étendue du domaine stable de propagation est quant à elle réduite en fonction du degré de vieillissement à température ambiante. Cette réduction est due à la chute de ténacité du matériau avec le vieillissement. Les surfaces de rupture sont majoritairement transgranulaires pour toutes les conditions examinées. Toutefois, les régions proches de la rupture finale de certains états vieillis présentent des îlots de rupture statique à la température ambiante. Ces ilots sont inexistants à 300°C. Par ailleurs, sous l’effet de surcharges répétées, un effet retard sur la vitesse de fissuration a été mis en évidence. Ce retard est fonction à la fois du taux de surcharge, de la période de surcharge, du nombre de surcharge et du rapport de charge du chargement de base, mais est insensible au vieillissement. Par ailleurs, on dénote une fois de plus, une réduction de l’étendue du domaine de propagation stable à température ambiante. Des simulations de la propagation des fissures sous amplitude de chargement variable ont été effectuées à l’aide du modèle incrémental de prévisions de durées de vie en fissuration développé au LMT-Cachan. Les résultats issus de ce modèle ont ensuite fait l’objet d’une comparaison avec le modèle PREFFAS utilisé chez AIRBUS. Le modèle incrémental rend bien compte de certains effets de surcharges répétées. Il se révèle en outre moins conservatif que le modèle PREFFAS. Une méthodologie de prise en compte dans le modèle incrémental des effets de vieillissement fondée sur une équivalence temps/température de type Hollomon-Jaffe est enfin proposée.
2017ESMA0013_dimithe_aboumou.pdf (41.53 Mo) Télécharger le fichier
tel-01592546 , version 1 (25-09-2017)
  • HAL Id : tel-01592546 , version 1
Loïc Dimithe Aboumou. Etude expérimentale et simulation numérique de propagation de fissures dans un acier inoxydable martensitique durci par précipitation sous conditions représentatives en termes de température, spectre de chargement et vieillissement. Autre. ISAE-ENSMA Ecole Nationale Supérieure de Mécanique et d'Aérotechique - Poitiers, 2017. Français. ⟨NNT : 2017ESMA0013⟩. ⟨tel-01592546⟩
467 Consultations
119 Téléchargements
