Directed assembly of metallic nanocrystals
Assemblage dirigé de nanocristaux métalliques
The fine control of nanoparticles bi-dimensional organization remains a main challenge for magnetic recording applications. Although the current size for a data bit is around a few tens of nanometers, it could be reduced to the nanometer scale simply through using magnetic nanoparticles. Nonetheless, intrinsic parameters of the nanoparticles such as their sizes, shapes and chemical compositions have a direct incidence on their periodic arrangement. Two different chemical routes were used to synthesize 2 nm CoPt and Co33Pt67 nanoalloys. Due to the high chemical disordering of these nanocrystals, the blocking temperature and coercive fields were lower than wished for data storage applications. In order to exhibit a higher chemical ordering, in situ annealing of these nanocrystals was carried out. It has been shown that ordering occurred around 400°C. Plus, size and shape for Co33Pt67 were kept after annealing but not for equiatomic composition. Nevertheless, only poor mesoscopic ordering between nanoparticles is observed, as reported elsewhere. This hurdle could be overcome in using organic molecules able to self-assemble on graphite and forming a porous two-dimensional supramolecular template. Thus, such template was designed and used to demonstrate that 2 nm Pt nanoparticles can locally organize in quasi-hexagonal or monoclinic lattices.
Le contrôle de l'organisation bidimensionnel de nanoparticules est primordial dans le défi que représentent l'enregistrement magnétique et l'augmentation de la capacité de stockage. Plus particulièrement, c'est ici la diminution de la taille des bits d'informations qui est ciblée. La conséquence serait alors une augmentation de la capacité de stockage de deux à trois ordres de grandeurs. Mais pour ce faire, il est nécessaire d'avoir une organisation bidimensionnelle de nanoparticules magnétiques de taille, forme et composition contrôlée. Via deux méthodes de synthèse, des nanoalliages de CoPt et Co33Pt67 de l'ordre de 2 nm ont été synthétisées. Ces derniers ont présenté alors des températures de blocage et des champs coercitifs ne permettant pas leurs utilisations dans des applications dans l'enregistrement magnétique. Cela s'explique par le fait qu'après synthèse, ces nanoparticules sont désordonnées chimiquement. Afin d'améliorer l'ordre chimique et donc les propriétés magnétiques, des recuits thermiques ont été effectués. Il a été montré que la mise en ordre a lieu vers 400°C et que, dans le cas de nanocristaux de Co33Pt67, la forme et la taille restent inchangées. Ces derniers pourraient être utilisés dans l'enregistrement magnétique à condition de pouvoir contrôler la distance interparticulaire. C'est pourquoi nous avons utilisé des molécules organiques capables de s'auto-assembler sur surface sur de longues distances et formant des réseaux nanoporeux aptes à servir de systèmes hôte et à capter les nanoparticules. Nous avons alors montré que des nanoparticules de platine possèdent une organisation quasi-hexagonale et monoclinique à moyenne distance.
