Revisiting Wide Superscalar Microarchitecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Révision de larges unités superscalaires
For several decades, the clock frequency of general purpose processors was growing thanks to faster transistors and microarchitectures with deeper pipelines. However, about 10 years ago, technology hit leakage power and temperature walls. Since then, the clock frequency of high-end processors did not increase. Instead of increasing the clock frequency, processor makers integrated more cores on a single chip, enlarged the cache hierarchy and improved energy efficiency. Putting more cores on a single chip has increased the total chip throughput and benefits some applications with thread-level parallelism. However, most applications have low thread-level parallelism. So having more cores is not sufficient. It is important also to accelerate individual threads. Moreover, reducing the energy consumption has become a major objective when designing a high-performance microarchitecture. Some microarchitecture features have been introduced in superscalar cores mainly for reducing energy. An example of such feature is the loop buffer, which is now implemented in several superscalar microarchitectures. The purpose of a loop buffer is to save energy in the core's front-end (instruction cache, branch predictor, decoder, etc.) when executing a loop with a body small enough to fit in the loop buffer. If the clock frequency remains constant, the only possibility left for higher single-thread performance in future processors is to exploit more ILP. Certain microarchitecture improvements (e.g., better branch predictor) simultaneously improve performance and energy efficiency. However, in general, exploiting more ILP has a cost in silicon area, energy consumption, design effort, etc. Therefore, the microarchitecture is modified slowly, incrementally, taking advantage of technology scaling. And indeed, processor makers have made continuous efforts to exploit more, with better branch predictors, better data prefetchers, larger instruction windows, more physical registers, and so forth. In this thesis, we try to depict what future superscalar cores may look like in 10 years and explore the possibility of exploiting loop behaviors to reduce energy consumption beyond the front-end. Some propositions have been published for loop accelerators or for unconventional superscalar core back-ends. I argue that the instruction window and the issue width can be augmented by combining clustering and register write specialization A major difference with past research on clustered microarchitecture is that I assume wide issue clusters, whereas past research mostly focused on narrow issue clusters. Going from narrow issue to wide issue clusters is not just a quantitative change, it has a qualitative impact on the clustering problem, in particular on the steering policy. We propose, in the second part of this thesis, two independent and orthogonal energy optimizations exploiting loops. The first optimization detects redundant micro-ops producing the same result on every iteration and removes these micro-ops completely. The second optimization focuses on the energy consumed by load micro-ops, detecting situations where a load does not need to access the store queue or does not need to access the level-1 data cache.
Depuis plusieurs décennies, la fréquence des processeurs à usage général n'a cessé d'augmenter grâce aux transistors de plus en plus rapides et aux micro-architectures avec des pipelines plus profonds. Cependant il y a environ 10 ans, à cause des courants de fuite et de la température, la finesse de gravure des processeurs a atteint sa limite physique. Depuis, au lieu d'augmenter la fréquence du processeur, les fabricants ont intégré plus de cœurs sur une seule puce, agrandi la hiérarchie de caches et amélioré l'efficacité énergétique. Cependant, il est également important d'accélérer les processeurs individuellement.La réduction de la consommation énergétique est donc devenue un objectif majeur lors de la conception d'une micro-architecture pour la haute performance. Certaines fonctionnalités ont été introduites dans les unités superscalaires principalement pour réduire la consommation énergétique. Un exemple de fonctionnalité est le tampon de boucles ("loop buffer"), qui est maintenant mis en œuvre dans plusieurs micro-architectures superscalaires. Le but d'un tampon de boucle est d'économiser l'énergie dans le bloc avant du microprocesseur (cache d'instructions, prédicteur de branchements, décodeur, etc.) lors de l'exécution d'une boucle avec un corps assez petit pour tenir dans cette mémoire tampon spécifique. Si la fréquence du processeur reste constante, la seule possibilité laissée libre pour l'amélioration des performances des applications séquentielles dans les futurs processeurs est d'augmenter l'exploitation du parallélisme d'instructions. Certaines améliorations des micro-architectures (e.g., une meilleure prédiction de branchement) améliorent simultanément la performance et l'efficacité énergétique. Cependant, améliorer l'exploitation du parallélisme d'instructions a généralement un coût: augmentation de la surface de silicium, de la consommation d'énergie, des efforts de conception, etc. Par conséquent, la micro-architecture est modifiée lentement, incrément par incrément. En effet, les fabricants de processeurs ont fait des efforts continus afin d'exploiter davantage l'ILP avec de meilleurs prédicteurs de branchements, de meilleurs pré-chargeurs de données, de plus grandes fenêtres d'instructions, ajout de registres physiques, et ainsi de suite. Cette thèse décrit ce que devraient être les unités superscalaires dans les 10 ans à venir et explore la possibilité d'exploiter le comportement des boucles afin de réduire la consommation énergétique au-delà du bloc avant. Certaines propositions ont été publiées notamment sur les accélérateurs de boucles et sur les unités superscalaires à bloc arrière non conventionnel. Il est soutenu que la taille de la fenêtre d'instructions peut être augmentée en combinant le regroupement (clustering) et la spécialisation des registres d'écriture (register write specialization). Une différence majeure avec les précédentes études sur les micro-architectures en grappe est l'utilisation de grappes larges (wide issue clusters), contrairement aux études passées qui étaient principalement axées sur des petites grappes (narrow issue cluster). Le passage de petites grappes à des grappes larges n'est pas qu'un changement quantitatif, mais a aussi un impact qualitatif sur le problème de regroupement, et en particulier sur la politique de pilotage (steering policy). La seconde contribution propose deux optimisations indépendantes et orthogonales concernant la consommation énergétique et exploitant les boucles. La première optimisation détecte les micro-opérations redondantes produisant le même résultat à chaque itération puis supprime définitivement ces micro-opérations. La seconde optimisation se concentre sur la diminution de l'énergie consommée des micro-opérations de chargement, en détectant les situations où un chargement n'a pas besoin d'accéder à la file d'attente des enregistrements ou n'a pas besoin d'accéder au cache de données de niveau.
MONDELLI_Andrea.pdf (2.57 Mo) Télécharger le fichier
tel-01597752 , version 1 (28-09-2017)
tel-01597752 , version 2 (18-01-2018)
  • HAL Id : tel-01597752 , version 2
Andrea Mondelli. Revisiting Wide Superscalar Microarchitecture. Hardware Architecture [cs.AR]. Université de Rennes, 2017. English. ⟨NNT : 2017REN1S054⟩. ⟨tel-01597752v2⟩
528 Consultations
2376 Téléchargements
