Probing AC electronic compressibility of 3D HgTe and Bi2Se3topological insulators at high electric fields : evidence for excitedmassive surface states - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Etude de la compressibilité AC des isolants topologiques 3D HgTe et Bi2Se3 : mise en évidence d'états massifs excités de surface
This thesis discusses the electronic compressibility of two representative three dimensional topological insulators: Strained mercury telluride (HgTe) and bismuth selenide (Bi2Se3).I present low temperature phase-sensitive electron admittance data over a broad frequency range. This allows to extract the quantum capacitance related to the density of states and the resistivity of the investigated materials.We show that the response of an intrinsic topological insulator is dominated by topological surface states over a large energy range exceeding the bulk material’s transport gap. This regime, named “Dirac screening” is characterized by an electron compressibility proportional to the surface Fermi level and a high mobility.Subsequently, we investigate the limits of this regime. At high energy and large perpendicular electric fields we observe the population of excited massive surface states. Experimentally, these manifest themselves in multiple signatures: A drop in the electronic diffusion constant, a peak in the conductivity, appearance of a second carrier type in magneto-transport and meta-stability in the charge-voltage relation.A theoretical model based on a quasi-relativistic treatment of the surface Hamiltonian is presented. It allows to identify the electric field and energy dependence of the massive surface states.This thesis is complemented by experimental results on Bi2Se3 grown on boron nitride, where we demonstrate the importance of clean surfaces for the study of electronic properties in topological insulators.
Dans cette thèse, j’étudie la compressibilité électronique de deux isolants topologiques tridimensionnels : Le tellurure de mercure (HgTe) sous contrainte et le séléniure de bismuth (Bi2Se3).Je présente des mesures d’admittance électronique à basse température résolues en phase sur une large gamme de fréquence. Cela permet d’extraire la capacité quantique associé à la densité d’états et la résistivité des matériaux étudiés.Nous montrons qu’un isolant topologique intrinsèque présente une réponse dominée par les états de surface topologiques sur une large gamme d’énergie qui s’étend au-delà du gap de transport du matériau massif. Ce régime, appelé « écrantage de Dirac », est caractérisé par une compressibilité électronique proportionnelle à l’énergie de surface et une haute mobilité.Dans la suite, nous nous intéressons à la limite de ce régime. Nous observons qu’à haute énergie et sous l’influence de forts champs électriques perpendiculaires, des états excités massifs de surface sont peuplés ce qui se manifeste expérimentalement de différentes façons : Une chute dans la constante de diffusion électronique, un pic de conductivité ainsi que l’apparition d’un deuxième type de porteurs en magnéto-transport et de métastabilité dans la relation charge-tension.Un modèle théorique basé sur un traitement quasi-relativiste du Hamiltonien de surface est présenté. Il permet d’identifier la dépendance en énergie et champ électrique des états massifs de surface.Cette thèse est complémenté par des résultats expérimentaux sur Bi2Se3 obtenu par croissance sur nitrure de bore mettent en évidence l’importance de la pureté des interfaces d’isolants topologiques.
fix_a6TYnshv.pdf (67 Mo) Télécharger le fichier
tel-01615846 , version 1 (12-10-2017)
  • HAL Id : tel-01615846 , version 1
Andreas Inhofer. Probing AC electronic compressibility of 3D HgTe and Bi2Se3topological insulators at high electric fields : evidence for excitedmassive surface states. Physics [physics]. Université Paris sciences et lettres, 2017. English. ⟨NNT : 2017PSLEE016⟩. ⟨tel-01615846⟩
444 Consultations
71 Téléchargements
