Accès aux marchés conditionnés par le financement de petits producteurs : cas du riz en Equateur - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Market access of small producers with financial conditions : the case of study of rice in Ecuador
Adriana P. Santos Ordonez
  • Fonction : Auteur
  • PersonId : 784508
  • IdRef : 204586135
The research analyzes the aspect of commercialization from the small producer perspective. According to the agricultural census, 80% of farms devoted to rice production are under 20 hectares, representing 50% of the total area occupied in rice production and generate 49% of the national total production (Chiriboga, 2008).Marketing systems are strongly linked to forms of financing, so that these mechanisms are named as an institutional trading system that allows to understand the close relationship between the actors that finance along the rice chain. In such an institutional system we observe how the act of exchange goes beyond economic term and creates a social structure of continuous and prolonged interaction.This way we can see how the economic action is embedded in the non-economic relations, institutions, and thus the exchange occurs in an institutionalized environment. The institutional system is characterized by rules, norms, conventions, trust, reciprocity, power and inequality.The aim of the thesis is to show how the small farmer faces the commercialization of its production conditioned by informal funding an institutional system that develops with the other actors in the rice value chain and determine if this system, characterized by the economic exchange in a non-economic social, which can generates benefits or losses to small farmers.
La recherche analyse l'aspect de la commercialisation du point de vue du petit producteur. Selon le recensement agricole, 80% des exploitations agricoles consacrées à la production de riz ont moins des 20 hectares, ce qui représente 50% de la surface totale occupée dans la production de riz et génèrent 49% de la production totale nationale (Chiriboga, 2008).Les systèmes de commercialisation sont fortement liés aux formes de financement, de sorte que ces mécanismes sont nommés comme un système de négociation institutionnelle qui permet d’entrapercevoir une relation étroite entre les acteurs du financement et de la commercialisation de la production. Dans un tel système institutionnel on observe comment l’acte d’échange va au-delà du terme économique et se crée une structure sociale d’interaction continue et prolongée.De cette façon on peut voir comment l'action économique est encastrée “embbeded” dans le tissu non-économique, les institutions, les relations et ainsi l'échange se produit dans un environnement institutionnalisée. Le système institutionnel est caractérisé par des règles, normes, conventions, la confiance, la réciprocité, le pouvoir et l'inégalité. L'objectif de la thèse est de montrer comment le petit agriculteur fait face à la commercialisation de sa production conditionnés par le financement dans un système institutionnel qui se développe avec les autres acteurs de la chaîne de valeur du riz et déterminer si ce système, caractérisé par un échange économique encastré dans un contexte social non économique, lui génère des bénéfices ou préjudices.
pdf2star-1507207024-Adriana-Santos.pdf (3.93 Mo) Télécharger le fichier
tel-01618324 , version 1 (17-10-2017)
  • HAL Id : tel-01618324 , version 1
Adriana P. Santos Ordonez. Accès aux marchés conditionnés par le financement de petits producteurs : cas du riz en Equateur. Sociologie. Agrocampus Ouest, 2016. Français. ⟨NNT : 2016NSARJ002⟩. ⟨tel-01618324⟩
465 Consultations
272 Téléchargements
