From valued digraphs to complete lattices : a new approach of weak order on Coxeter groups
Des graphes orientés aux treillis complets : une nouvelle approche de l'ordre faible sur les goupes de Coxeter
Weak order on a Coxeter group W is a partial order on W appearing in many areas of algebraic combinatorics. In this thesis, we propose a new general model for the study of the weak order and other related partially ordered sets (also called “posets”) and we explore various algebraic and combinatorial consequences of this construction. We begin with studying a restricted version of this model in Chapter 3. More precisely, we explain how one can associate a poset to any simple acyclic digraph together with a valuation on its vertices (also called “valued digraph”). We then prove that these posets are complete meet semi-lattices in general, complete lattices when the underlying digraph is finite, and we give an explicit formula to compute the value of their Möbius functions. Then, we show that the weak order on Coxeter groups of type A, B and A, the flag weak order, and the up-set (resp. down-set) lattices of any finite poset can be described within this theory. This description naturally leads to associate a quasi-symmetric function to any element of An And An, and we demonstrate that this function is in fact the corresponding Stanley symmetric function. In Chapter 4 we introduce the main results of this thesis. Indeed, we introduce in this chapter the generalization of the construction made in Chapter 3 to the case of any valued digraph, that is without the simplicity and acyclicity condition. Furthermore, this new definition allows us to get rid of some constraints of the definition of Chapter 3, allowing us to associate a complete lattice to each valued digraph. In particular, the meet semi-lattices of Chapter 3 are naturally extended into complete lattices. This leads us to the study of some conjectures of Dyer about the properties of an extension of the weak order having a lot of the properties conjecturally attached to Dyer’s extensions, and we prove that each one of our extensions contains Dyer’s extension as a sub-poset. We make the conjecture that one of this extension coincide with the one of Dyer, and we provide tools in order to test this conjecture. Finally, we study various consequences of out theory : we provide extensions of Cambrian semi-lattices into complete lattices (end of Chapter 4), we construct a new combinatorial model for Tamari and m-Tamari lattices (Chapter 5), and we finish with an application to tableaux combinatorics (Chapter 6)
L'ordre faible sur un groupe de Coxeter W est un ordre partiel sur les éléments de W, intervenant dans de nombreux domaines de la combinatoire algébrique. Dans cette thèse, on propose un nouveau modèle général pour l'étude de cet ordre ainsi que d'autres ensembles ordonnés affiliés, et on explore diverses conséquences aussi bien algébriques que combinatoires de cette construction. On commence, dans le chapitre 3, par étudier une version restreinte de ce modèle. Plus précisément, on explique comment on peut associer un ensemble ordonné (aussi appelé « poset » à tout graphe orienté, simple, acyclique et muni d'une valutation sur ses sommets (aussi appelé « graphe valué »). On montre ensuite que ces posets sont en général des semi-treillis inférieurs, des treillis quand le graphe est fini, et on donne une formule explicite pour les valeurs de leurs fonctions de Möbius. On prouve ensuite que l'ordre faible sur les groupes de Coxeter de type A, B et A, le « flag weak order », ainsi que le treillis des idéaux supérieurs et inférieurs de tout poset fini peuvent être décrit avec notre modèle. Cette description amène naturellement à associer une série quasi-symétrique à chaque élément de An et An et on montre que cette série est en fait la série de Stanley associée. On présente dans le chapitre 4 les résultats centraux de la thèse, en effet on y introduit la généralisation de la construction faite au chapitre précédent au cas de tout graphe valué, c'est-à-dire sans condition s'acyclicité et de simplicité. On s'affranchit également de certaines contraintes imposées par la définition du chapitre 3, ce qui nous permet d'associer à tout graphe valué un treillis complet, et non plus un semi-treillis. En particulier, les semi-treillis du chapitre 3 se retrouvent naturellement plongés dans un treillis complet. Ceci nous amène à nous intéresser à des conjectures de Dyer portant sur l'étude d'une extension de l'ordre faible sur tout groupe de Coxeter (entre autres, il est conjecturé que ces extensions sont des treillis complets). On construit alors, à l'aide de notre formalisme, des extensions de l'ordre faible ayant beaucoup des propriétés conjecturalement attachées aux extensions de Dyer, et contenant ces dernières comme sous-poset. On conjecture que l'une de ces extensions coïncide avec celle de Dyer, et on fournit des outils pour le tester. Finalement, on étudie diverses conséquences de notre théorie : la construction d'extensions des semi-treillis cambriens (fin du chapitre 4), la construction d'un nouveau modèle combinatoire pour le treillis de Tamari et m-Tamari (chapitre 5), et enfin on propose une application à la combinatoire des tableaux (chapitre 6)
