Characterization of the New Neutron Line at CERN-n_TOF and Study of the Neutron-induced Fission of 237Np - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Caractérisation de la nouvelle ligne de neutrons à n_TOF-CERN, et étude de la fission induite par neutrons de 237Np
The neutron time-of-flight (n_TOF)facility at CERN is a unique worldwide pulsedneutron source to measure the nuclear data over thewidest energy range with two beam lines currentlyexploited. One is horizontal with a ~185 metersflight path, sending neutrons to experimental area-1(EAR-1). The second one is a new line sendingneutrons vertically to experimental area-2 (EAR-2)with a ~20 meters flight path.The first part of this PhD work is dedicated to thecharacterization of the beam (flux, geometricalprofile, energy spectrum) of the new EAR-2 neutronbeam, of the utmost importance for the experimentalproposals and analyses. An experiment was carriedout at EAR-2, based on PPAC detectors looking atfission of 235U, and the beam profile and neutronflux have been obtained for the entire availableenergy range (from thermal to 200 MeV).The second part of the thesis aims to study theneutron-induced fission of 237Np. 237Np isabundantly produced in present nuclear reactor andis one of the major long-lived components ofnuclear waste which can be considered as apotential target of incineration in fast neutronreactors. Consequently its neutron-induced fissioncross section has been measured at differentfacilities. However, significant discrepancies existbetween different experiments. Especially, therecent one performed at n_TOF in 2010 is about 6%higher by comparison to the evaluation data basedon previous experiments. Therefore an experimenthas been performed at n_TOF EAR-1 to measure itsfission cross section, in a configuration allowing anaccurate control of the detection efficiency, aimingto give a definite answer to the puzzle. In this work,we found that the efficiencies for different targetelements are different, even though they havesimilar thickness, reflecting the conditions ofelectrodeposition. After application of thisefficiency correction in the energy range from 1 to 5MeV, the newly extracted fission cross section is 2-3% lower compared with our previous measurementin 2010, however they are 3-4% higher than the
L’installation n_TOF au CERN est unesource pulsée de neutrons, unique au monde pour lamesure de données nucléaires sur le spectre enénergie le plus étendu, avec deux lignesactuellement exploitées. Une ligne horizontalealimente l’aire expérimentale 1 (EAR-1) avec unebase de vol de ~185 mètres. La seconde ligne estverticale et alimente l’aire 2 (EAR-2) à ~20 mètresde la cible de productionLa première partie de ce travail de thèse concernela caractérisation du faisceau de neutrons (flux,profil géométrique, spectre en énergie) de lanouvelle ligne EAR-2, particulièrement importantepour la définition des expériences et leur analyse.Une mesure a été réalisée à EAR-2, basée sur desdétecteurs PPAC enregistrant la fission de 235U, àpartir de laquelle nous avons obtenu le profil et leflux sur la gamme en énergie accessible (thermiqueà 200 MeV).La seconde partie de la thèse a pour but l’étudede la fission de 237Np. Cet isotope est abondammentproduit dans les réacteurs nucléaires actuels et estun des constituants des déchets à vie longue. A cetitre on peut le considérer comme une ciblepotentielle pour l’incinération en réacteur rapide.Ceci a motivé des mesures récentes de sa sectionefficace de fission. Cependant des déviationsimportantes sont apparues, en particulier la mesureeffectuée à n_TOF en 2010 est 6% supérieure auxévaluations basées sur les mesures antérieures. Cecia motivé une nouvelle mesure à n_TOF avec uneconfiguration permettant une mesure précise del’efficacité de détection, pour apporter une réponseau problème. Ce travail a permis de mettre enévidence une dépendance de l’efficacité dedétection avec l’élément, résultant des conditions del’électrodéposition. Après application de cettecorrection d’efficacité dans la région 1 à 5 MeV lasection efficace de fission ainsi extraite est 2 à 3%plus petite par rapport à la mesure de 2010,cependant elle reste 3 à 4% plus forte que lesévaluations
69774_CHEN_2017_diffusion.pdf (26.41 Mo) Télécharger le fichier
tel-01619917 , version 1 (19-10-2017)
  • HAL Id : tel-01619917 , version 1
Yonghao Chen. Characterization of the New Neutron Line at CERN-n_TOF and Study of the Neutron-induced Fission of 237Np. Nuclear Experiment [nucl-ex]. Université Paris-Saclay, 2017. English. ⟨NNT : 2017SACLS204⟩. ⟨tel-01619917⟩
223 Consultations
161 Téléchargements
