Réduction des vibrations de structures composites complexes par dispositifs piézoélectriques shuntés : application aux aubes de turbomachines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Vibration reduction of complex composite structures with shunted piezoelectric devices : application to turbojet blades
This thesis concerns the vibration reduction in the low frequency range of a composite fan blade of a turbojet engine with piezoelectric devices. The interest is to increase lifespan and avoid flutter phenomena by reducing the vibration amplitude. The purpose of this thesis is to study several shunted piezoelectric devices, in the low frequency range, that can be applied to a woven composite turbojet fan blade. The targeted applications are the LEAP fan blades or the “open-rotor” fan blade, both of them required to manage a complex geometry. The solutions investigated used piezoelectric elements coupled to a passive or semi-passive circuit. The core of this thesis, still a scientific obstacle at present, is to propose efficient solutions that integrate the piezoelectric elements to the fan blades in order to meet aerodynamic constraints for this type of structure, while increasing damping level on one of the first modes of vibration. The performances of such devices are directly related to a coefficient: the electromechanical coupling factor that requires to be maximized. This coefficient depends on all the features of the structure: materials used (host composite structure, piezoelectric material), but especially the placement and geometry of the piezoelectric elements. The use of piezoelectric material connected to active, semi-passive or passive circuits has been extensively studied but the experiences almost always deal with academic cases such as beams or plates. The aim is for the developed piezoelectric device, to evaluate the damping performance of a weakly damped massive structure.A part of the work is thus to develop a predictive finite element model of the structure coupled to the piezoelectric material to quantify the performance of the device. Several solutions are tested on a simple structure to evaluate the influence on the device performance of, (1) the choice of the piezoelectric material, (2) the placement and geometry of the piezoelectric elements, and (3) of the dissipative circuit. Various integration solutions in the blade are proposed and a method for characterizing the properties of woven materials is developed in the perspective of integrating the active materials in the composite preform.This study is both numerical and experimental: a demonstrator using a composite fan blade is designed and tested in the laboratory to validate the proposed concepts.
Cette thèse CIFRE (Conventions Industrielles de Formation par la REcherche), en collaboration avec Safran Aircraft Engines, concerne la réduction des vibrations de flexion en basse fréquence d'une aube de rotor de soufflante en matériau composite. L'intérêt premier est de réduire les marges au flottement en augmentant l'amortissement des aubages pour permettre l'utilisation des moteurs dans des plages de fonctionnement à haut rendement actuellement inexploitées. Les autres avantages directement liés à la réduction de vibration sont l'augmentation de la durée de vie des pièces ainsi que la réduction du bruit du moteur. L'objet de cette étude, est d'étudier différents dispositifs d'amortissement de vibrations piézoélectriques, en basses fréquences, applicables à une aube de turbomachine fabriquée en matériaux composites. Les applications principalement visées sont des aubes de rotor de soufflante ou des pales de rotor non caréné ("open-rotor"), de géométrie élancée et complexe. Les solutions étudiées utilisent des éléments piézoélectriques couplés à un circuit électrique passif ou semi-passif. Le coeur de ce travail de thèse, encore un verrou scientifique à l'heure actuelle, est de proposer des solutions performantes qui intègrent les éléments piézoélectriques aux aubes de soufflante afin de respecter les contraintes aérodynamiques imposées pour ce type de structure, tout en augmentant l'amortissement sur un des premiers modes de vibration. Les performances de ce genre de dispositifs sont directement liées à une grandeur : le facteur de couplage électromécanique, qu'il s'agit de maximiser. Il dépend de toutes les caractéristiques de la structure : les matériaux utilisés (structure composite hôte, matériau piézoélectrique), mais surtout du placement et de la géométrie des éléments piézoélectriques. L'utilisation de matériaux piézoélectriques connectés à des circuits actifs, semi-passifs ou passifs a été largement étudiée mais les expériences traitent presque toujours de cas académiques de poutres ou de plaques. L'objectif est ici, pour le dispositif piézoélectrique développé, de pouvoir évaluer les performances des shunts en terme d'atténuation sur une structure massive faiblement amortie. Une partie du travail consiste ainsi à bâtir un modèle éléments finis prédictif de la structure composite couplée aux matériaux piézoélectriques, en vue de quantifier les performances du dispositif. Plusieurs solutions sont testées sur une structure simple pour évaluer l'influence sur les performances du dispositif, (1) du choix du matériau piézoélectrique, (2) du placement et de la géométrie des éléments piézoélectriques ainsi que (3) du circuit électrique dissipatif. Différentes solutions d'intégration à l'aube sont proposées et une méthode de caractérisation des propriétés des matériaux tissés est développée dans la perspective d'intégrer les matériaux actifs à la préforme du composite. Cette étude est à la fois numérique et expérimentale : un démonstrateur, utilisant une aube en matériaux composites est conçu puis testé en laboratoire pour valider les concepts proposés.
THIERRY_2016.pdf (48.83 Mo) Télécharger le fichier
tel-01620672 , version 1 (20-10-2017)
  • HAL Id : tel-01620672 , version 1
Olivier Thierry. Réduction des vibrations de structures composites complexes par dispositifs piézoélectriques shuntés : application aux aubes de turbomachines. Vibrations [physics.class-ph]. Conservatoire national des arts et metiers - CNAM, 2016. Français. ⟨NNT : 2016CNAM1111⟩. ⟨tel-01620672⟩
685 Consultations
276 Téléchargements
